Old 10-24-2011, 08:20 PM   #1
GordonFreeman OP
Gamer
GordonFreeman's Avatar
Oddometer: 1,622
Heated Grips
Are you happy with them and where did you buy? Thanks.
________________________
You run into ODS in the morning, you ran into ODS. You think you run into ODS all day, YOU'VE got ODS. (Paraphrasing Raylan Givens)
GordonFreeman is offline   Reply With Quote
Old 10-24-2011, 08:42 PM   #2
Qwik
Adrenaline Addict
Oddometer: 6,891
KTM Factory type on mine and I love em. Great on a cold day. No complaints
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 10-24-2011, 09:35 PM   #3
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
I've had a few different kinds, BMW factory, Kimpex, and the lastest which are Dual Stars. The Dual Stars so far have been a let down. Every other grip I've had got much hotter.
v8toilet is offline   Reply With Quote
Old 10-24-2011, 10:51 PM   #4
timbo45
timbo45's Avatar
Oddometer: 174
heated grips
I bought mine from kurt at blackdog and they suck . The right one gets hot but the left one barely gets hot. I even tried insalating it but no go just barely warm. I talked to Kurt from blackdog at the KTM rally in lake tahoe he said their was a bad batch but he didnt offer a refund. So I guess I will try another brand.
timbo45 screwed with this post 10-25-2011 at 09:11 AM
timbo45 is offline   Reply With Quote
Old 10-24-2011, 11:11 PM   #5
ok64
Oddometer: 142
I've installed the KTM part which is probably OEM'ed from somebody else. The "start" setting works well. Both grips are powered in parallel. The "on" setting, both grips powered in serial, is not really warm but just takes the cold out of it. I'm thinking about adding a switch from Symtec: http://www.symtec-inc.com/Internal-H...etric_p_7.html
I've seen it offered separately for $89 somewhere. It provides 4 settings rather than the factory 2.
ok64 is offline   Reply With Quote
Old 10-25-2011, 12:09 AM   #6
timbo45
timbo45's Avatar
Oddometer: 174
Heated grips
How are the KTM brand do they work well
Old 10-25-2011, 12:35 AM   #7
ok64
Oddometer: 142
Those are the ones I have. See my reply above yours.
Old 10-25-2011, 01:18 AM   #8
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 772
Bought a few of the Symtec ones with the rocker switch from California Sport Touring for various bikes. No issues here.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 10-25-2011, 02:37 AM   #9
Masa
Masa's Avatar
Oddometer: 303
Got my bike with KTM (part 60112064144) grips and working great. These have a four level power controller, with dim indicator lights. Long press turns heater on/off and short cycles between levels. I've only couple of weeks experience, but temperatures have been close to freezing and I usually keep them on the second level. Highest level melts my gloves..
Masa is offline   Reply With Quote
Old 10-25-2011, 04:00 AM   #10
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
I've never had heated grips before.
My 2006.5 Adv came with Oxford grips installed...
I love them, a gift from the motorcycling gods!
Get some you won't regret it!
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 10-25-2011, 04:31 AM   #11
Hipster
Hipster's Avatar
Oddometer: 1,813
+1 for Symtec heated grips, they're more expensive than other element grip heaters but, they work well.
Hipster is offline   Reply With Quote
Old 10-25-2011, 04:47 AM   #12
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,305
Looks great.
I wonder if we can install the new 4 level controller in our old Daytona grips, the ones with the 2 level switch, where position 1 means melt and position 2 does nothing...
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 10-25-2011, 04:57 AM   #13
WR Dave
WR Dave
Oddometer: 14
I second the Oxford grips, the newer ones have the four settings which works well. I still have a set of the older ones which is variable by the potentiometer and you can dial in the exact amount of heat you need. Those black KTM ones look exactly like the 4 position Oxford heaters on my other bike. I live in Canada, heated grips is not an option to be without. WR Dave
WR Dave is offline   Reply With Quote
Old 10-25-2011, 04:57 AM   #14
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Hot Grips are the best! http://www.hotgrips.com
I have them on all my motorcycles, ATVs, and snowmobiles.
Be sure to add Warm N' Safe's Heat-Troller, in either the sub-surface or surface mount variety, and you'll have grips that can go from barely warm to "melt your gloves hot" in just a few seconds. http://www.warmnsafe.com/index.php?m...cPath=65_71_81
ktm950se
ktm950se is offline   Reply With Quote
Old 10-25-2011, 04:58 AM   #15
DirtyRoadie
Oddometer: 208
Good question GOTI , I have the older KTM branded grips. The grips look identical but the older style controller has three settings, off, start (which is like hanging onto an exhaust header) and on (which is barely warmer than off). But back to the original question; YES by all means get heated grips if you ride in the cold. They are the next best thing to round tires.
DirtyRoadie is offline   Reply With Quote
Times are GMT -7.   It's 06:18 PM.
