Old 12-25-2011, 09:09 PM   #61
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,800
KTM 4 Position Model
Just ordered mine from KTMTwins. Once the snow melts I'll give them a try
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 12-26-2011, 02:19 AM   #62
Damaged Goods
Damaged Goods's Avatar
Oddometer: 6
Originally Posted by sonoran View Post
Flikr seems to alias the actual link instead of providing a direct link to the jpg. Try photobucket instead.
As for the grips I really like them except the LED's are very hard to see in daylight, especially if you are wearing sunglasses. They need to be brighter. A small nit for an otherwise solid product.
Hi Guys 1st post, long time lurker etc
I think the LED's will b like this, so that @ nite they don't draw ur vision towards them & become a distraction, Vehicle Manufacturers will be wary of poss lawsuit's resulting from this
Dabid
Damaged Goods is offline   Reply With Quote
Old 12-26-2011, 02:48 AM   #63
Damaged Goods
Oddometer: 6
Originally Posted by bikepsych View Post
Compared to heated gloves, which would be the better choice? Heated Gloves or Heated Grips? I had heated grips on my VStrom before. They sure heated up my palms, but the thumbs and back of the hand still got cold.
BG
Due to my being a 'softy' I have Heated Gloves, the heating elements are on the back so they stop the 'wind-chill'. If i had 'hand protectors i would poss use heated grips but this way when i swop between bikes, i only need a plug on ea bike = cheaper plus i can get a battery for in my pocket to run the gloves if i'm not on the bike
Old 12-27-2011, 11:45 AM   #64
Senor Siesta
Accipere Via Longa
Senor Siesta's Avatar
Oddometer: 169
Blinking Continuously?
I just finished installing the KTM brand hetaed grips, really excited to extend my rides on these colder days. I do have a problem with the current set-up...all the LEDs are blinking. Hold the button down for 3 seconds and the unit turns off...
Not sure if I hooked it up wrong (ACC2: Black/Red (bike) to Red (Grip) and Brown (Bike) to Black(grip)) or if I am not operating the button right...as in this moron cant push a button. LOL
Any ideas? And many apologies for blatant highjacking...
Thanks from the Siesta's garage of Noobdom
Senor Siesta screwed with this post 12-27-2011 at 12:07 PM
Senor Siesta is offline   Reply With Quote
Old 12-27-2011, 01:52 PM   #65
GordonFreeman OP
Gamer
GordonFreeman's Avatar
Oddometer: 1,595
Mine blink for several seconds after switching on. Number of LEDs blinking = the last heat level setting. Stops blinking after a few moments and are steady on until I change the level. You obviously have pwr, do the grips get hot?
________________________
You run into ODS in the morning, you ran into ODS. You think you run into ODS all day, YOU'VE got ODS. (Paraphrasing Raylan Givens)
GordonFreeman is offline   Reply With Quote
Old 12-27-2011, 03:54 PM   #66
Senor Siesta
Accipere Via Longa
Oddometer: 169
If only it could be that easy. The LEDs continue to blink long enough for the engine to warm. The grips are not getting warm. Is there a fault table for the grips? I remember reading about a constant blue LEd meaning not enough power?
In any case thanks for the suggestions.
Addendum:
After one or two beers and a little head scratching, I came upon the problem, didn't hook the grips to power correctly. Beer really does make everything better...
Thanks Gordon for the suggestions, sometimes stoopid needs a minute to clear...
Senor Siesta screwed with this post 12-27-2011 at 04:11 PM Reason: Found the problem...
Old 12-29-2011, 07:01 AM   #67
ktmmac
Oddometer: 30
Has anyone else had problems getting grips go stick. Tried proper grips adhesive, eco stick, araldite. They keep coming loose. Help please
Sent from my HD7 T9292 using Board Express
ktmmac is offline   Reply With Quote
Old 12-30-2011, 12:20 AM   #68
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,006
You definitely need heat shrink tube.
Mine had some adhessive on them but I would never rely on it. Heat shrinking tube is the way to go over the glue. Just make sure you clean the bars properly with alcohol or cleaning benzine. Sticky glues can get soft when warmed up and start sliding in the summer.
Another fix could be to wrap tightly with small tie wraps. In this case make sure the locking of the wraps are at the points your hand leaves free when holding the gas side.
Cheers.
Old 12-31-2011, 05:28 PM   #69
ok64
Oddometer: 142
Does anybody know if there is a way to just buy the new switch?
Check out www.ADVSPOT.com, my site with lots of links to Adventure products and information. (I don't sell anything) Send me a PM if you have a link you want to add.
ok64 is offline   Reply With Quote
Old 12-31-2011, 05:31 PM   #70
slickwill
Exhiled
Oddometer: 209
Originally Posted by Dotbond View Post
Bought a few of the Symtec ones with the rocker switch from California Sport Touring for various bikes. No issues here.
I have the Symtec kit with rocker switch from MotorcycleGear.com. No complaints.
slickwill is offline   Reply With Quote
Old 12-31-2011, 05:34 PM   #71
slickwill
Exhiled
Oddometer: 209
I used hairspray, my wife's AussieMega to be exact, haven't had a single issue.
Old 12-31-2011, 05:43 PM   #72
daveknievel
daveknievel's Avatar
Oddometer: 758
aquanet hairspray or 3M super 77 spray adhesive.
daveknievel is offline   Reply With Quote
Old 01-02-2012, 12:41 PM   #73
muscly
muscly's Avatar
Oddometer: 74
heat
I needed more than the heated grips , and mounted these ....... it works really well.
Why I love Offroad bikes?
Because 99,999% of the earth,
are not pavement.
muscly screwed with this post 01-04-2013 at 10:04 AM
muscly is offline   Reply With Quote
Old 01-02-2012, 07:25 PM   #74
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,239
I used Symtecs with a micro switch from Aircraft Spruce.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 01-22-2012, 05:35 PM   #75
Senor Siesta
Accipere Via Longa
Oddometer: 169
Have the KTM Grips for a few weeks, these have made commuting and weekend rides pretty nice. Cozy, real cozy.
2007 990 ADV
2005 Bonneville
Times are GMT -7.   It's 09:03 AM.
