01-23-2012, 03:59 AM
#76 | |
Oddometer: 458
i have the same, the low setting is too high and the LED indicators are far too dim. set on high they nearly burn my hands there is so much heat coming off them! |
01-23-2012, 12:51 PM
#77 |
Unbunch yer panties!
Oddometer: 1,104
Recently bought and installed these and also find them plenty warm. Most days, the lowest setting is too warm and I cycle the grips on and off; thye hld heat pretty well even turned off. Ambient temps 30-40 f so it's not like it's warm out.
BUT-I recently dropped the bike in a mud puddle way out on a ride and got my gloves wet; my hands stayed warm in damp Klim adventure gloves 90 minutes home in 20 deg temps. Took setting 2 to do it, tho... Overall quite happy, and hey they were on sale! Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
05-05-2012, 10:35 AM
#78 |
Exchange your GPS Track!
Oddometer: 2,529
Ktm diagram? Does anybody has the old style "start/on"
Wiring diagram? I put some on my 640 and I keep on blowing fuses when I go to the on setting The box didn't come with instructions wires seems straight forward but something is cooking. Thx |
05-05-2012, 11:22 AM
#79 |
They call me......Ronski
Oddometer: 556
Here's another option for the original Hi/Low OEM heaters. I replaced the switch with an infinitely adjustable electronic controller.
![]() What a Difference! I can set the heat level anywhere I want, which makes a remarkable improvement in my riding experience. The install story is here- http://www.advrider.com/forums/showp...77&postcount=2
Ronski Enduro Racer & Google Earth Adventurer |
05-06-2012, 06:40 AM
#80 | |
Addlepated
Oddometer: 2,061
I'm gonna do this project soon. The more I use the newer KTM/Oxford 4 LED controller, the less I like it. The single green LED (lowest setting) is nearly impossible to see during the day. I like the infinite adjustment knob a lot.
FYYFF! http://www.youtube.com/watch?v=NtpUv4VBDhA Bikes 2012 BMW K13S | 2009 KTM 990 Adventure (SOLD!) | 2003 Suzuki DRZ400E |
05-06-2012, 07:30 AM
#81 | |
Life is a trip
Oddometer: 3,107
My 0.02
Cheers.
There is always a reason!! |
05-06-2012, 08:15 AM
#82 | |
Oddometer: 2,529
See the pic below for the connector I have. The red is connected to the + on my relay, Then I had the grips connected to the 2 double connector - one grip wire on each connector and then the ground on the green. That's the only way everything would connect... Unless there is an assembly issue.... I can fix that I have these connectors but I can't figure out what to do... |
05-06-2012, 08:20 AM
#83 |
Oddometer: 2,529
For info this is the controller I have.
http://www.advrider.com/forums/showthread.php?t=281986 It's not on Ktm twin website anymore |
05-06-2012, 08:26 AM
#84 |
Oddometer: 2,529
Thank you!!! You got me searching moreand found this... With wire diagram which explains just what you said about the ground!!!
http://www.advrider.com/forums/showthread.php?t=201107 |
05-06-2012, 09:33 AM
#85 | |
V-Twin
Oddometer: 260
because that dimmer is suited for only 0.8A as readable on the outside and not +4A, that thing must really getting hot.
'10 990SMT |
05-06-2012, 06:37 PM
#86 |
Back Home
Oddometer: 1,546
How long have you left them on at the low setting. I too thought they where too hot at low but after about 5 minutes they settle into a nice temperature. Maybe KTM thinks you need a bust of heat before cooling down to something reasonable.
05-07-2012, 03:04 PM
#87 | |
Oddometer: 1,104
Steve
05-07-2012, 07:08 PM
#88 | |
Oddometer: 556
It doesn't even get warm when in use.
