Old 10-26-2011, 09:06 AM   #16
pjm204 OP
Oddometer: 2,012
Originally Posted by sailah View Post
Assuming the frame is similar to the fz1, it's a great choice. No swingarm through the motor means you can adapt dirt bike swingarm. The pipes do stick out but r6 header should be a close fit or go custom. Front end is as easy as the other build s. The motor is peaky but should haul ass. The limiting factor for some is getting the 650 ninja rear travel to match the 10+" of usd forks. Having an easily replaceable swingarm from a ktm with no linkage streamlines the process and matches travel front and rear.
now about those pics...
Haha pics won't happen until Friday/Saturday. I'm in texas currently. But I should make progress this weekend. Everything I need is on its way.
Rear wheel, Front end, rear shock, oil pan.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 10-26-2011, 10:09 PM   #17
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,887
ok im in
b0mb3r is online now   Reply With Quote
Old 10-27-2011, 04:31 AM   #18
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,771
i shall poke around for a cadaver
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 10-27-2011, 06:11 AM   #19
pjm204 OP
Oddometer: 2,012
I just want to let you know, I think you owe this build partly to me haha. I almost bought that bike from the Flea Market if it is the one I'm thinking of. You got a great deal. I'm just kidding though, the bike went to the right place!
if you look at my build thread I used 1" 0.065 wall DOM for everything bent except the bottom tubes of the subframe which are 1.25".
I just used my 1.25" die this week to make the lower frame spars.
The 1" is the best one to have, my heavens they are expensive though right??
Old 10-27-2011, 06:57 AM   #20
Grainbelt
marginal adventurer
Grainbelt's Avatar
Oddometer: 27,098
Every time one of these threads pops up I wonder if somewhere, some Kawi employee is thinking about the old KLE500 and wondering what went wrong.
Grainbelt is offline   Reply With Quote
Old 10-27-2011, 07:19 AM   #21
pjm204 OP
Oddometer: 2,012
I dunno, it lasted 16 years, couldn't have been too big of a failure. Sad we never got it here. This engine is a little more potent though, should prove to be a very fun/capable bike.
My only concern is how much the steering will be reduced with the USD forks, hopefully the 25mm offset will help.
Old 10-27-2011, 08:25 AM   #22
Tonibe63
Oddometer: 17
Lack of power and petrol tank too small.
We have them over here in the UK and values seem to hold up well but they don't get much of a following.
Now if Kawasaki put decent suspension on the Versys they would have a fantastic bike but then I suppose the price would go up towards BMW/Triumph XC level and to command that sort of money you need good 'brand' image which they just don't have.
Tonibe63 is offline   Reply With Quote
Old 10-27-2011, 08:43 AM   #23
Ridin'nFishin
Oddometer: 514
I know this idea would be more work/money.
Could a different swing arm be adapted to give the Versys more travel to match the travel of the converted front suspension?
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 10-27-2011, 10:12 AM   #24
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,727
Upgrading the shock allows for more travel.The up travel will be limited by the rear frame and liner/fender pan.Check JDRocks build thread.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 10-27-2011, 10:55 AM   #25
pjm204 OP
Oddometer: 2,012
In order to use a different swingarm you would need to change the frame since the shock is mounted on the right side instead of in the center of the frame
Old 10-27-2011, 11:10 AM   #26
Ridin'nFishin
Oddometer: 514
Yes, I have read all his threads.
Old 10-27-2011, 11:13 AM   #27
Ridin'nFishin
Oddometer: 514
This can be done with more time, work and money?
Old 10-27-2011, 11:43 AM   #28
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,756
So youre the guy...
I thought he was dealing with some guy in tn who couldn't get his act together, but could be he was dealing with multiple guys. I just told him I'd pay his asking price in cash and ready to roll. It makes it even more funny that I had bought a ninja to do your build and it ended up being stolen hence looking for another donor.
For the guy asking about swingarm s, it's def doable. You would probably need to replace or modify the subframe extensively to either run a ktm swinger without linkage, reengineer a link suspension or build your own swingarm that either uses the stock location for the to p mount or build a custom mount. Def can do it, and the money isn't really that much more, I have maybe $50 for a ktm swinger, $300 for a ktm shock and $20 in steel and brackets.
Don't know if it's going to work yet but I do have 12" travel front and rear with a sweet shock.
I'm just going to have to find a ninja and try it.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 10-27-2011, 11:50 AM   #29
pjm204 OP
Oddometer: 2,012
So youre the guy...
I would agree that the money is not the issue here. It just requires a lot more work. You'd then want to strip the frame down to repaint it after all the welding. I'm going to try and keep my frame/subframe uncut. I wish the subframe was bolt on.
I would have paid the asking price too but I couldn't get there in time. And at the time I had no where to store a project. But your bike turned out great.
Old 10-27-2011, 01:09 PM   #30
Ridin'nFishin
Oddometer: 514
Your bike is bad ass, that for sure.
There have been some great builds here and I enjoy reading and thinking of the easy way to ride one of these bikes. Bolt on everything no welding is the easy way. I just don't think it can be done without some kind of mods done to the swing arm. I don't know maybe make the swing arm a inch or two longer?
All the builds I have looked at are great, some greater than others, (JDrocks)
Times are GMT -7.   It's 04:16 PM.
