Old 10-27-2011, 01:12 PM   #31
pjm204 OP
Oddometer: 2,011
http://advrider.com/forums/showthread.php?t=632255
So far that has been my favorite Ninja Mutant. I plan to steal a few ideas from there, hopefully the headers since that was very smart.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 10-27-2011, 01:24 PM   #32
Ridin'nFishin
Oddometer: 496
Great build!
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 10-31-2011, 11:10 AM   #33
pjm204 OP
Oddometer: 2,011
Well I lost power this weekend so all I did was changed the tires on the V-strom...sorry for the lack of progress. I got to look at all the beautiful parts that had arrived.
Old 11-08-2011, 05:26 AM   #34
pjm204 OP
Oddometer: 2,011
Alright, so this upcoming weekend I should be moving most of my stuff to my new house, hopefully the ninja tags along into the new garage. If it does, I'll start stripping off bodywork and taking pictures.
Old 11-26-2011, 04:45 PM   #35
elgato gordo
KTMRFS
elgato gordo's Avatar
Oddometer: 510
21 vs 19 front
PJM204
Just found these build threads and have found them very interesting. One thing I have seen on is that 21 inch front tires are only available in narrow 3.00in wide. With this heavy of a bike would a larger tire be better like the 19 inch would offer. Some are even using rear dirt tires for the front. Seem much better in soft dirt. Not sure of the negative impacts.
Good luck with the build!
elgato gordo is offline   Reply With Quote
Old 11-26-2011, 08:47 PM   #36
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,667
Originally Posted by elgato gordo View Post
PJM204
JDRocks has stated in his thread that he gets 10,000+ miles out of some of his front tires on a 21 inch V-Strom front wheel.Plus it all depends on if you're running street or dual sport tires and if they are bias ply or radial construction.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 11-27-2011, 10:25 AM   #37
jdrocks
Gravel Runner
Oddometer: 4,516
Originally Posted by ben2go View Post
JDRocks has stated in his thread that he gets 10,000+ miles out of some of his front tires on a 19 inch V-Strom front wheel.Plus it all depends on if you're running street or dual sport tires and if they are bias ply or radial construction.
better now.
jdrocks is online now   Reply With Quote
Old 11-27-2011, 04:29 PM   #38
pjm204 OP
Oddometer: 2,011
Sorry to say that there is little to report at this time. I unboxed and shelved all of the parts in my new garage. I'll get started on it sooner or later...and once I get started I'll move quickly.
Old 11-27-2011, 06:34 PM   #39
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,667
Originally Posted by jdrocks View Post
better now.
Yes.I got caught up.
Old 12-28-2011, 03:12 PM   #40
pjm204 OP
Oddometer: 2,011
Alright so I finally got working on the build. I stripped off all of the plastics, took off the wheels, suspension is off.
Mocked up the front and rear ends and I'm currently waiting to make some parts. Sadly the conversion bearings I would need (25mm x 55mm x 14mm) don't seem to be available anywhere. So I need to make a sleeve for the stem to fit the ninja bearings. The rear KTM wheel looks like it will work out perfectly with some spacers.
Here is what I need to make/buy/alter to get it rideable:
25mm ID x 35mm OD steering stem sleeve
several 20mm spacers for rear axle
Bore out R1 shock bushings
Weld extension for brake caliper hanger
Future tasks:
Make headers
Fit muffler
Cut down oil pan drain
Sort headlight/fairing
etc etc
Old 12-28-2011, 04:21 PM   #41
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,667
Have a search around here. http://www.mcmaster.com/# They have turned up some good,and cheap, parts for mods.
Old 12-29-2011, 03:20 PM   #42
elgato gordo
KTMRFS
Oddometer: 510
What do you think about removing the stem from the ninja triples and press it into the YZ triples. You would either have to neck down the stem from the ninja of open up the hole in the YZ triples.
Seems odd the street bikes use big diameter steering stems but smaller diameter fork legs.
Future tasks:
Make headers
Fit muffler
etc etc
Old 12-29-2011, 04:10 PM   #43
pjm204 OP
Oddometer: 2,011
The ninja stem is too big to use in the YZ triples unfortunately, not enough meat left after I open up the yz triples.
I dropped off the triple at a machine shop to bore out the hole to accept the ohlins stem I have. He is also boring out the holes in the R1 shock. I bought the conversion bearings and wheel bearings...so tomorrow the bike should be a roller again. Just need wheel spacers...anyone have a source for materials to make a few 20mm wheel spacers? (I checked mcmaster)
Old 12-29-2011, 04:16 PM   #44
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,705
I have an aluminum supply place near me I can pick some rod up from their scrap bin. Send me the dimensions you want, my treat.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 12-29-2011, 04:41 PM   #45
pjm204 OP
Oddometer: 2,011
Haha, I think you just want an excuse to use that lathe. I may take you up on the offer if I can't figure something out over the weekend. I'm trying to get the bike rideable by the end of the weekend.
Times are GMT -7.   It's 10:02 AM.
