01-16-2012, 11:52 AM
#61 |
Oddometer: 1,236
Interesting, I couldn't mount it because the swingarm was hitting the muffler...I'll have to try again. I need to get some 10mm washers to shim the sides of the eyelets.
Current bikes:2006 DL650, 2006 Ural Past bikes: XT225, TTR125, CRF50 1974 DT125,1970 TS250,1985 v45, 1989 zx600c, 1978 GS400x, 1999 GS500E, 2001 GS500E 2005 Z750s, 1977 GS400e, 1982 GS1100ez, 1997 GSX600, 2007 VFR800, 2003 KLR650, 2003 FJR1300, 2006 DL1000, 2000 KLR650, 1999 WR360, 2008 DL650, 2005 DR650,2008 EX650r, 1996 CR500, 1982 GS450T |
01-17-2012, 12:21 PM
#62 |
Oddometer: 1,236
Has anyone found a better looking coolant overflow? Or relocated the stock one? I really don't like the location. I also need to figure out a new place to mount the ignition. I assume the two bolts on the bottom need to be drilled out?
01-17-2012, 01:39 PM
#63 | ||
Stuck @ Home! >=^(
Oddometer: 1,082
jdrocks coolant tank and revisions. http://www.advrider.com/forums/showp...&postcount=674 http://www.advrider.com/forums/showp...&postcount=839 http://www.advrider.com/forums/showp...&postcount=845 http://www.advrider.com/forums/showp...&postcount=847
Manic Cycles=My Facebook Page |
01-17-2012, 01:52 PM
#64 | |
Oddometer: 1,236
Good work, thanks. That's kind of what I want to do. I'm going to see if anyone makes something already suited to the purpose.
01-17-2012, 02:08 PM
#65 | |
Stuck @ Home! >=^(
Oddometer: 1,082
You're welcome.I am planning to sell one of my bikes soon and pick up a crashed 07 650R.I hope the owner doesn't sell it before I get there.I been doing a lot of thread rereading on the Ninja conversions.
01-17-2012, 05:14 PM
#66 | |
Lampin' it
Oddometer: 4,139
ose stupid bolts.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
01-19-2012, 12:08 PM
#67 |
Riding to the horizon.
Oddometer: 387
+1 Same story here. Terrible bolts, super hard but surrounded by cheese-soft al. Woops.
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS |
01-19-2012, 12:10 PM
#68 |
Oddometer: 1,236
Great, looks like I have something to look forward to. It looks like my stem nuts/wheel spacers will be here today(hopefully). At that point, the front end should bolt on. Spacers for the rear wheel and I am good to go. I might throw the stock ninja wheel on and take it for a spin once it is rolling.
01-19-2012, 06:41 PM
#69 |
Oddometer: 1,236
01-20-2012, 11:45 AM
#70 |
Oddometer: 387
I demand photographic evidence that this bike exists. Can I get an amen?
01-20-2012, 12:54 PM
#71 | |
Oddometer: 1,236
M30x1.25 M26x1.25 They're pissing me off.
01-20-2012, 01:32 PM
#72 | |
Gravel Runner
Oddometer: 2,766
"It is for a yz450 but is aftermarket, likely Pro Taper or Ohlins. bottom nuts (qty 2) are M30x1.25 Top nut is M26x1.25 I ordered both of these nuts from a roketta parts site but the nuts that arrived had such boogered up threads, they wouldn't fit." are you sure you have the correct pitch? be unusual for threads to be so bad you couldn't chase them to get started. contact Protaper or Ohlin? |
01-20-2012, 03:57 PM
#73 |
Oddometer: 983
I just rechecked my build thread for info on the YZ stems. stock is 30 and 28 mm diameters. if you cant find the right nuts, it might be easier to get a stock yz triple and have the stems pressed again
http://advrider.com/forums/showpost....77&postcount=7 FYI, looks like a crf450 flywheel puller has m30 threads. its a lead, anyway. not sure if it left or right but its 1.25 http://www.mopedbutze.eu/gx/Werkzeug...a-CRF-450.html |
01-20-2012, 03:58 PM
#74 | ||
Stuck @ Home! >=^(
Oddometer: 1,082
01-20-2012, 06:41 PM
#75 |
Oddometer: 1,236
The reason I am using this stem is because I was able find conversion bearings. I was not able to for the stock YZ stem.
