Old 03-12-2012, 04:20 AM   #106
pjm204 OP
Oddometer: 2,012
Headlights have been ordered. You'll have to wait until the weekend to see what I've decided upon. All I can say is that they're bright and I didn't cheap out.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is online now   Reply With Quote
Old 03-12-2012, 10:34 AM   #107
pjm204 OP
Oddometer: 2,012
Just ordered a spring from Cannon. 15.0kg/mm in lime green. I was considering ordering the progressive spring for the road star that goes from 825lb to 1250lb but I'm not overly familiar with progressive springs for off road use.
I weigh in at about 160, so with gear and no passenger, I'm under 200lbs. Anyone think 15.0 was a bad choice?
Old 03-12-2012, 01:01 PM   #108
pjm204 OP
Oddometer: 2,012
After a little thinking, I realized that if I switch the two spacers on the right side I would be able to use the caliper spacer idea jdrocks showed below. Right now I have a nut on each side as the spacer but this weekend I will cut out the spacer as shown. Thanks jdrocks(again)
Originally Posted by jdrocks View Post
that's one way to do it, but it's easy to do with a caliper spacer in combination with your axle spacer(s). like this, then you caliper bracket has full engagement with the antirotation lug.
Old 03-12-2012, 08:36 PM   #109
ktmklx
ktmklx's Avatar
Oddometer: 700
Originally Posted by pjm204 View Post
HAHAHA...I plan to beat the piss out of this bike off road. I'm hoping to do the Pine Barrens 300 and Rally West Virginia on it. So I will look into a beefier spring for it since you and I are roughly the same weight
You may wnat to think twice about those foot pegs, I think more than one fella has broken them off in the dirt.
ktmklx is offline   Reply With Quote
Old 03-13-2012, 04:16 AM   #110
pjm204 OP
Oddometer: 2,012
Yea, I'm sure there will be some revisions to the bike as I go along. This weekend I just want to get it on the road/dirt.
Old 03-18-2012, 07:42 PM   #111
pjm204 OP
Oddometer: 2,012
Well this weekend the dirt ninja got its maiden voyage. I rode from Philadelphia to Rahway, NJ. Once I got there, I proceeded to lengthen the kickstand, make a spacer for the rear caliper, and mount the front fender. I cobbled the stock headlight back on without the stock headlight cowling just so I could ride it home. Sadly my 8" baja designs headlight failed to be delivered(what part of leave by garage, I am home do you not understand FEDEX?)
I then met rode with 2 friends to the Deleware water gap to go camping...we ripped down some fire roads. All I can say is, this bike is awesome. The R1 shock is obviously too soft, new spring is on the way. Next weekend more work will get done. I do think I am going to mod the swingarm to allow more adjustment of the rear wheel.
Pics to follow
Old 03-18-2012, 08:01 PM   #112
pjm204 OP
Oddometer: 2,012
Please forgive the horrible headlight.
Old 03-19-2012, 02:36 PM   #113
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,748
Looks killer, glad you got it rolling.
Congrats
When is the WV rally? Maybe I'll roll down there to meet up
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-19-2012, 04:49 PM   #114
ktmklx
ktmklx's Avatar
Oddometer: 700
Lookin good. What is the front fender from? Black with green accents, that bike will be a looker.
Old 03-19-2012, 07:51 PM   #115
pjm204 OP
Oddometer: 2,012
The WV rally is the last weekend in July. See www.rallywv.com for details. I'd be happy to ride there with you.
The fender is a universal SM fender from polisport. It was under $10 from motorcycle superstore, fit perfectly, and required no drilling, the mounting plate adjusts. There will be some more green on the bike. My spring is going to be black, sadly. Might do the crash bars lime green.
Old 03-21-2012, 02:18 PM   #116
pjm204 OP
Oddometer: 2,012
Well the ugly way I have the stock headlight mounted will be gone this weekend. My 8" Baja Designs headlight arrived last night, it is beautiful. Hopefully my spring/mirrors will arrive as well.
Old 03-21-2012, 06:53 PM   #117
elgato gordo
KTMRFS
elgato gordo's Avatar
Oddometer: 510
Great looking build, sounds like it handles good too. What kind of mods do you have in mind for the swingarm?
elgato gordo is offline   Reply With Quote
Old 03-21-2012, 08:11 PM   #118
pjm204 OP
Oddometer: 2,012
my intent is to cut some clearance away at the brace in front of the tire, then weld a plate over it.
Old 03-25-2012, 02:50 AM   #119
pjm204 OP
Oddometer: 2,012
Pics will arrive tonight. Yesterday I mounted the headlight and aux lights. Today I will mount the ignition and cluster. Then either mod the swingarm for more wheel clearance or build crash bars.
Old 03-26-2012, 07:00 AM   #120
pjm204 OP
Oddometer: 2,012
Headlight/aux lights are all mounted. Gauges are mounted. Mirrors put on. Still need to figure out what I am going to do with that huge ignition. It was dangling under the bike and I kind of forgot about it. I need to find someone to swap my springs also so I can put the R1 shock back on.
Times are GMT -7.   It's 07:05 AM.
