Old 06-07-2014, 06:47 AM   #1
Roger Baker OP
FasterGS
Roger Baker's Avatar
Oddometer: 6
Up in Smoke
Couple of weeks ago, I started my 2004 GS 1150 Adventure and went in the house to change shoes and jacket. (DON'T DO THIS) In about 12 min. a neighbor was beating on my door to inform me that my motorcycle was on fire. I found my motorcycle with fire coming out the front wiring and oil all over my garage!! Pushed it out in the yard and put the fire out and stood there wondering "Did I take out FULL coverage??". Thank GOD I did! I had just changed to Progressive insurance 2 months earlier and dreaded making the call. Well there was a good vibe from the beginning because my adjuster's name was Jesse (like the bags). While I hated it, my bike was totaled. I was preparing to argue my point for the value of my bike, but I did not have to. Progressive could not have been more fair. I also had additional insurance for accessories which helped bridge the expense. All and all, while I miss my old bike a lot. (Had many adventures together), I was able to get a another bike within a couple of weeks and I am back on the rode with little interruption! Thanks Progressive!
Roger Baker is offline   Reply With Quote
Old 06-07-2014, 08:39 AM   #2
Teckel
Wait, what?
Teckel's Avatar
Oddometer: 3,183
What started the fire?
Teckel is offline   Reply With Quote
Old 06-07-2014, 09:03 AM   #3
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,464
Oilhead=oilcooled=overheat=oil fire? Or coincidence?
--Bill
'73 R60/5 Toaster
Old 06-07-2014, 09:29 AM   #4
Spaggy
Spaggy's Avatar
Oddometer: 834
Letting it run for 12 minutes just sitting. Start it, ride it.
Even a few minutes balancing throttle bodies, I use a big fan or the sucker gets hot hot.
Spaggy is offline   Reply With Quote
Old 06-07-2014, 11:03 AM   #5
catweasel67
Still a B.A.N
catweasel67's Avatar
Oddometer: 8,192
Are you serious?
You're suggesting that a GS will catch fire if left to idle for longer than XX minutes?
Planning NA 2010 NA 2010
Adriatic Loop August 09 Mandello Guzzi Protest Sept 09
"I've got the key to the gates of paradise...but I've got too many legs!!" Jeff
Guns don't kill people, people kill people but people with guns manage to kill more people than people without.
catweasel67 is offline   Reply With Quote
Old 06-07-2014, 11:16 AM   #6
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,320
Originally Posted by catweasel67 View Post
Are you serious?
Yep, older bike with a loose/weak oil sight glass. Glass pops out, oil drains onto hot exhaust, combustion ensues. Not the first time it happened, and probably won't be the last.
Gear up, get on the bike, start it, and ride away.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 06-07-2014, 11:42 AM   #7
catweasel67
Still a B.A.N
Oddometer: 8,192
Mike
Good god! and thanks :) Time to move my AT away from that old Dakar GS :p
Old 06-07-2014, 11:47 AM   #8
Bill Harris
Oddometer: 7,464
Yep. Since the engine is largely oil-cooled it dumps a LOT of heat into the oil, which relies on airflow through the oil cooler to remove the heat. Heat keeps building up and up and up. Also there are ignition sensors ("Hall Effect Sensors") that have a history of HES wire insulation problems when they get cooked if the bike overheats, even idling it for 3-4 minutes.
--Bill
'73 R60/5 Toaster
Old 06-07-2014, 02:46 PM   #9
Pecha72
Oddometer: 3,887
The bike idles for less than 15 minutes, and it catches fire? Really?? In that case, there should be a system, that if the bike's not moving in, say, 5 minutes, the engine is turned off.
Countries ridden FIN SWE NOR DK EE LV LT POL SK HU RO BG GR IT AT DE CZ CH SMR LIE NL BE FR AND ES GBR LUX SI HR BIH SRB MK TR IR PAK IND TH KH LA MY ID AUS CR USA ZA LS SWZ MZ NA BW ZM ZW
Pecha72 is offline   Reply With Quote
Old 06-07-2014, 04:21 PM   #10
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,441
There is, it's rider controlled and called common sense.
X the DY.
TrashCan is offline   Reply With Quote
Old 06-07-2014, 04:26 PM   #11
RodT
Oddometer: 338
enough already
We don't need anymore sensors, just use common sense. These bikes already have more than we need in that department.
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT is offline   Reply With Quote
Old 06-07-2014, 04:28 PM   #12
tntmo
Oddometer: 460
How the hell would you ride through heavy traffic if the bike catches fire in 15 minutes?
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 06-07-2014, 04:31 PM   #13
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,441
Lane split?
X the DY.
Old 06-07-2014, 04:36 PM   #14
joef
joef's Avatar
Oddometer: 483
There is, it's called design flaw.
joef is offline   Reply With Quote
Old 06-07-2014, 04:42 PM   #15
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,251
Are you all really so spoiled as to have never owned an air cooled bike?
*WTB: '90 DR350S Stock CV carb (bst33) PM if you have one*
'90 DR350S
How to misuse a '90 DR350S
Photos
Anonawesome is online now   Reply With Quote
Times are GMT -7.   It's 03:56 AM.
