Old 01-27-2012, 01:12 PM   #61
pineknot
pineknot's Avatar
Oddometer: 16
seat height
Nice project .any idea what your seat height will be?
pineknot is offline   Reply With Quote
Old 02-04-2012, 01:07 PM   #62
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,076
Having a look at a GS500 myself tomorrow and this looks awesome!
I'd like to do something similar.
Old 02-04-2012, 08:47 PM   #63
SteveROntario
Oddometer: 52
This is a really cool project. I had a 1982 4-valve per cylinder GS400E years ago and had mounted knobbies on and it worked really well. I was able to ride it through 3 winters in Ottawa with sheet metal screws in between the knobs. Offroad wasn't so hot as the bike was stock height, I would get stuck with the frame on the ground too much and I didn't have anythng to grab onto to pick up the rear end up out of the holes. Another problem I had was my aftermarket screen as it only had 2 clamps on the handlebars. I could go pretty good in the wash boards but I couldn't stand hearing it hammering on my headlight. It's a shame the US didn't get the 400E engine, it is way way better than the 2 valve GS400, 450, and 500.
I think your project will solve the issue of the 400/500 CC range dual sports not being able to keep up on the highway.
Steve
SteveROntario is offline   Reply With Quote
Old 02-05-2012, 02:42 PM   #64
Donde
Oddometer: 1
2006 GS500F now the F stands for Frankenbike.
Run around dirt roads and have run at Big Bend.
Bought new with fairing, ran solo 3200 mile Texas border hiway trip in 7 days.
Pulled front fairing for track days.
Barrelled it on turn 9 Texas world spdwy.
So decided to turn it into a beater. It's mine now.
Acewell gage , acerbis lights
Katana 600 rear, racetech emulator and progressive springs up front
Avon AM43/44 for offroad. I don't think they have any better traction, but they have a thicker carcass and the front is taller so tends to track better in the soft.
It doesn't have good tire clearances so it probably would be no good in the mud.
Have run some supermoto track tires very well, have considered supermoto wets for sand running.
One must have for anyone dualsporting a GS is case guards, Don't get the factory guards, SW-Motech is far better.
On the track it made the difference between scrapping the bike or rebuilding.
Donde is offline   Reply With Quote
Old 02-05-2012, 06:09 PM   #65
Unclerock
UncleRock
Unclerock's Avatar
Oddometer: 23
Kreame tank sealent.
The only time I used it (and this was my fault) it leaked on me not long after.
but I had solid mounted the tank on a Sportster that I put a 79" stroker in.
"1 measure of a man is what he does when he has nothing to do"
Robert E Fulton 1Man Caravan
http://www.doubleramericanbulldogs.com/21835.html
It's all about the ride, nothing else matters
UR
Unclerock is offline   Reply With Quote
Old 03-01-2012, 01:01 PM   #66
nzjaprider
Oddometer: 3
GS500 dual sport
With the right suspension and engine protection, do you think it would be possible to do some stages of the T,A,T in the summer?
nzjaprider is offline   Reply With Quote
Old 03-01-2012, 04:21 PM   #67
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
Yes.From all I have seen of the TAT,it could be done with a little suspension lift,skid plate,bark busters,and proper tires.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 03-02-2012, 11:28 AM   #68
pjm204
Oddometer: 2,019
You could do the tat on a stock GS500 with decent dual sport tires from Tennessee to Colorado depending on the weather. There would be a few sections that may challenge you, and you might not be able to keep the same pace as a dual sport...but there were very few instances I really needed a dual sport. After New Mexico though, I bet it gets a bit tougher.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 03-08-2012, 07:23 AM   #69
Bleached OP
Oddometer: 23
Haven't checked in for a while and wanted to leave a quick update. The project is still moving. New position at work and lots of travel slowed me down over the last couple months. That, and I would love a heated garage.
Hopefully with the warmer weather on the way I'll start making some steady progress again. As far as I can tell on the SV650 rear shock, final word is that it must be cut and redrilled. I can't make it fit any other way.
Bleached is offline   Reply With Quote
Old 03-08-2012, 07:26 AM   #70
mikeybikey82
mikeybikey82's Avatar
Oddometer: 1
thanks for the update i anxiously await your progress! i have a GS500 and am planning on the same thing, just as soon as i can convince my wife that its....necessary... uh, any ideas on that?
mikey
95% of what i just said is bullshit
mikeybikey82 is offline   Reply With Quote
Old 03-21-2012, 07:44 PM   #71
WAP
Weekday Warrior
WAP's Avatar
Oddometer: 1,062
Looking forward to seeing progress. I've been considering doing some kind of DS frankenbiking to my GS as well.
2002 GS500
2013 990 SMT
WAP is offline   Reply With Quote
Old 04-19-2012, 10:41 AM   #72
Manaen
Oddometer: 5
This project is awesome. It is exactly what I have been planning for over a year. I finally also found a GS and am in the process of doing a milder version of what you've done. I decided to keep the stock forks with better springs and valving (for now) but I may go to something like an early Honda CR or XL fork later down the road. Great looking project.
Here is a thread I have been posting about my bike if your interested.
My GS500e Adventure Project
Keep up the good work!!!
This is the current status of the bike, But I currently have the front ripped apart working on the forks.
Manaen is offline   Reply With Quote
Old 04-19-2012, 02:32 PM   #73
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
Good to see you made it over from the twins forum.
Old 04-20-2012, 04:00 PM   #74
tdrrally
tdrrally's Avatar
Oddometer: 3,456
any one know if a dr350s rear wheel will work, on the gs500?
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 04-20-2012, 06:38 PM   #75
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
Yes,but they are not a direct swap.See this thread and just reverse engineer what dbarale did.
http://www.advrider.com/forums/showthread.php?t=742198
Pre 97 DR650 used the same swing arm as the GS.May wanna find that entire rear wheel set up with spacers,cush drive,brakes,and all.
Times are GMT -7.   It's 01:44 AM.
