Old 11-02-2011, 06:37 PM   #1
Ohio_Danimal OP
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 596
Touring on the SV650-Pictures of travels
Thought I'd start a thread to see if there were any other Inmates here that had a Suzuki SV650 as their bike of choice.
Mine's a 2003 that started it's life as a naked model, purchased 5 years ago with a little over 7000 miles
As the miles started adding up I wanted something with a bit more wind protection. About the same time I realized the shortcoming of the bike's stock suspension and upgraded that as well, as many SV owners do. Throw on a GSXR front end and a better rear shock and the bike was transformed.
Add clip ons with 3" extra rise and a Corbin built taller than stock and the bike eats the miles up and laughs at the twisties it encounters along the way.
Farkles include full audio with AmpliRider amp (remote volume for all output by left hand) Garmin Zumo linked to my helmet, Sirius radio, and heated gear hookup.
Now, with just over 101,000 miles on her, she does seem to be tiring out a bit and burning a bit of oil. While still running well and getting great mileage, I may start looking for a used engine soon, and plug that sucker in like a 9V battery, and just keep going. Aside from normal maint, it had it's valves 1st checked at (get this) 72,000 miles and they were still in spec.!
There are quite a few other bikes I have lusted over, but none I think that would have been this fun.
So post up here if you own and travel on your SV650. No Weestroms here lol. My bike can pretty much do what your wee can outside of bashing over logs. Who knows though...my next engine could come from a wee.
Wisdom is age well spent.
Anger is age, hell bent.
Ohio_Danimal screwed with this post 12-05-2012 at 10:39 AM Reason: Wanted to bring in more sv owners to post their pictures
Ohio_Danimal is offline   Reply With Quote
Old 11-02-2011, 06:53 PM   #2
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 908
http://www.advrider.com/forums/showthread.php?t=597711
I absolutely love my SV to death. I'm going to have some money to buy a new bike, and my only worry is, will it be as good as the SV? I'll likely transform the bike into a track bike when the new bike comes in, but gee golly I love this thing. I've put 20,000 miles on it since I bought it 2 years ago.
Clem Kevin is online now   Reply With Quote
Old 11-02-2011, 07:20 PM   #3
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Originally Posted by BOETJE View Post
Did you buy a whole new bike with fairing, or did you put an S-fairing on?
Do the clip on risers interfere with the fairing ?. ( close up picture maybe ?)
How is the fairing/screen combination for buffeting/wind noise ?.
Can you fit the lower footpeg assy of the naked version onto the S ?
Sorry for all the questions, but after 10 years of BMW's I am looking for something a bit lighter, but still comfortable.
.......100K miles , and no problems ??
The bike was a naked model (like ClemKevins above) when I purchased it used.
I added the full fairing from a "S" model SV650. It bolts right on. Here is a picture before the GSXR front end went on
No, no interference issue. In fact, when I first mounted the GSXR front forks, I modified a GSXR upper triple clamp to add the stock SV650 naked bike's risers and used the stock SV naked bars...even then no clearance issues
Later, I wanted a bit lower bar position, and got a machined upper clamp and 3-1/2" rise 50mm clipons from a (now defunct) company called SWATT Machine.
I have tried three different screens. Stock SV650 S screen (low), A double bubble design screen, and the GIVI sport-touring screen I have now used for over 40,000 miles.
I am 6" and the windblast hits me just at the top of the shoulders. The wind over the helmet is pretty clean and quiet. Never really thought much of buffeting, so I guess it's not an issue.
Yes. The rearset assembly on my 2003 naked ARE lower and more forward than the same year's "S" model. They are interchangable.
Let's see...
The front cylinder would cut out off and on when riding in rain. Common SV issue. The drain hole in the front cylinder's spark plug cavity gets clogged and the plug fouls. I fabricated a plastic guard that is attached to the radiator and that hasn't been an issue for several years.
I ride agressively and rarely get over 7000 miles on rear tires, but riding so much I go through lots of tires and have tried most. (I guess that's really not a "problem")
The 4.7 gal tank and the mid-50s mpg give me around a 200 mile range. I wish it had more (and am considering having a remote tank fabricated that would add a gal or so) but again, that's reallly not a problem of the bike, just a limitation.
The front GSXR rotors warped badly after 15,000 miles and were replaced by Alth's....MUCH better...but again, not really a fault of the bike.
no...really...no mechanical issues.
Ohio_Danimal screwed with this post 01-24-2012 at 05:24 PM
Old 11-02-2011, 07:24 PM   #4
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Great RR Kevin and what a wonderful trip!
With my son entering college soon, I will start having much more free time in the Summer (no more travel baseball!) and multi-week trips are in the works for me too!
Old 11-02-2011, 07:36 PM   #5
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,476
Just wanted to say how awesome your bike is! If I ever replace my GS500F it'll almost definitely be replaced with an SV650. For some reason the only full-fairing bikes I really like are SV's. Great mods by the way.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 11-02-2011, 07:46 PM   #6
madisonreid
Oddometer: 1,701
Just picked up a 06 naked SV. This is my third . I want a street fighter and the SV fits the format perfectly and inexpensively. Nice bike. The SV was my very first bike and may be my one of my last.
madisonreid is offline   Reply With Quote
Old 11-02-2011, 08:09 PM   #7
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 908
Go for it man. If you do one next summer let me know, maybe I'll come along for part of the ride.
Old 11-02-2011, 08:43 PM   #8
doxiedog
doxiedog's Avatar
Oddometer: 932
Road this 77 gs550 for 20 yrs.
Gave it to my son,when i bought a 99 sv.
Rode sv.,for 77k miles,trouble free.
Just bought a 2011 bonneville t100 last oct.
Made son buy the sv. :) still runs great.
Snot nosed 68 yr.old kid.
I ride because, it lets my soul out to play. .
doxiedog is offline   Reply With Quote
Old 11-02-2011, 09:24 PM   #9
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
glad to see it stay in the family.
Old 11-03-2011, 05:14 AM   #10
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Mine began it's life naked but ended up clothed. I've never been a big fan of the whole streetfighter genre, but can appreciate I guess trying to emulate the whole stripped-supersport look that seems to have come about due to crashing and destroying the fairings.
Old 11-03-2011, 07:04 AM   #11
madisonreid
Oddometer: 1,701
I have a custom K75 being built which will be quite nice for touring. My ride to work when I ride is only 30 miles round trip. I just thought for that kind of ride less is more. I also enjoy viewing the geometry/artistry of a naked bike. Some are very beautiful. I'm also a practical person (2 pc800s) and will add comfort features to make the commute enjoyable. Don't want beauty to be skin deep only. The Rox risers and heated grips will make my day. The Alaska leather seat cover and lowering peg solution will make her range enhanced. We'll see
madisonreid screwed with this post 11-03-2011 at 07:10 AM
Old 11-03-2011, 09:14 AM   #12
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
It's just that the term "streetfighter" is bandied about a bit much I think. Have you ever looked at streetfighters from Europe? Bobbed tails pointing straight up and odd ball headlights, etc.
The naked SV I consider more of a modern "standard"
Old 11-03-2011, 09:23 AM   #13
madisonreid
Oddometer: 1,701
I hear what your saying. Many of the Triumphs are considered "streetfighters" with two or one headlight. Not very different from a naked SV. So for our discussion, let's just say I'm making the SV standard a bit more comfy.
Old 11-03-2011, 10:00 AM   #14
Ron Bullard
Ron Bullard's Avatar
Oddometer: 153
My 2001 is primarily my commuter, but I was finally able to do some traveling with it recently (ride report from August pending). I like how it looks better without any windscreen, but the Givi I used for the trip sure was nice
Northern California
Western Washington
The Redwoods
_______________________
Day Trippin':
The Ridge Route, 2011
The Oregon Coast, 2009
"...the fuel goes in there, through there and out there. . . the black turny thing on the back then goes round and round."
Ron Bullard is offline   Reply With Quote
Old 11-03-2011, 10:26 AM   #15
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Northern California
Western Washington
The Redwoods
NICE!!!
When I first got my 2003 SV it was nekkid, and I put a GiviA750 on it. Not quite as large as the one you ran, but very similar
Times are GMT -7.   It's 04:04 PM.
