Old 01-01-2013, 06:04 PM   #241
Ohio_Danimal OP
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 596
Originally Posted by blue72beetle View Post
I will be going to the Rally for sure! I made sure to get plenty of time off around June. Just gotta figure out lodging or camping or whatever.
I bought an arctic suit so I was riding up until Christmas day, but I think it's not leaving the garage until spring comes now that the snow has stuck around.
I have access to a two bed private cabin in Robbinsville,with crazy low rates (know the owner, who is trying to convince me to move down there and build on her property) so if you do need a place let me know. It's got a shower and TV, etc with a small kitchen but the only stove is a grill that's right outside.
Outside the cabin
Inside
Wisdom is age well spent.
Anger is age, hell bent.
Ohio_Danimal is offline   Reply With Quote
Old 01-01-2013, 06:32 PM   #242
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,594
Welcome blue.
Come on down, the weather was good Sunday and Monday.
X the DY.
TrashCan is online now   Reply With Quote
Old 01-02-2013, 12:27 PM   #243
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Originally Posted by TrashCan View Post
Welcome blue.
FYYFF
Old 01-03-2013, 05:41 AM   #244
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 4,594
Originally Posted by Ohio_Danimal View Post
FYYFF
X the DY.
Old 01-03-2013, 08:01 AM   #245
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
FYYWFFF!!
(fuck you you warm fuckity fucking fuck)
This is what it is like outside in NE Ohio today, with a balmy high of 19 degrees
Old 01-03-2013, 05:41 PM   #246
blue72beetle
Look at my Wee
blue72beetle's Avatar
Oddometer: 193
Absolutely I'd be interested in riding down there with you. If you head down in a group or with some friends, I don't even mind sleeping on the floor, or heck, even in tent.
We'll figure something out close to June. Gotta make it out of winter alive first.
blue72beetle is offline   Reply With Quote
Old 01-04-2013, 07:20 AM   #247
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 729
I bought this trunk for my SV for some dry storage this year. Went on a 2100mile trip last year with most of my stuff packed in a duffle bag, and it all got soaked.
The bike came with a luggage rack that bolts under the seat.... but I'm wondering if it is too weak to handle the top case and whatever I put into it. Would I need to buy a rack from SW-Motech or something?
http://www.jcwhitney.com/motorcycle-.../p2010969.jcwx
Here is my bike
A V-Strom and a DRZ. 2 bikes to cover all of my bases.
EastBoundAndDown is offline   Reply With Quote
Old 01-04-2013, 07:37 AM   #248
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Let's see a few pics of the rack mounts with the seat off
Old 01-04-2013, 07:42 AM   #249
ducnut
Oddometer: 3,320
I wouldn't hesitate to use what you've got, as the SW Motech rack is nothing more than bent aluminum.
What's unfortunate is that your rack has that raised loop on it. Otherwise, you could mount your topbox further forward. Of course, that would hinder getting the seat off. Everything's a tradeoff, I guess.
Also, I'm not sure what kind of duffel you used, but, I've used a drybag and never had a problem with things getting wet.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-04-2013, 07:55 AM   #250
EastBoundAndDown
Oddometer: 729
Cell Phone pics....
It held up carrying all of this through gravel and dirt roads, but some of the weight was sitting on the seat.
Old 01-04-2013, 08:18 AM   #251
ducnut
Oddometer: 3,320
I looked at the SW Motech directions and see that their plate ties into those welded bosses that are under the helmet hooks. If you could weld some type of reinforcement to those, I think you'd be OK. The way it is now, I think, would put way too much stress on those two bolts and would guess the box to be "floppy". Though, looking at the SW Motech mount, I'm surprised it's not more robust than it is.
'96 Ducati 900SS
Old 01-04-2013, 10:34 AM   #252
Ohio_Danimal OP
Midlife Crisis Man
Oddometer: 596
Eastbound...that rack you have is made in the UK by Rentec. I used to run the same rack. As is, it's rated for a 12 lb load (not much) and unlike the SW Motech and others, does not have secondary anchors to make it more rigid.
Good news is that you also have the OEM Suzuki Aluminum fender eliminator installed.
I used to run a Rentec rack, and here's what I did to help. Go to Lowes,etc and buy a strip of Alum. about 1" wide, 1/8 thick.
Cut 2 arms that act as supports to run from the rack sides down to the fender eliminator. Drill holes and bolt the arms directly to the fender eliminator (it has holes on the side for bungees)
On the end attached to the rack sides, go to a local bicycle shop and get a couple plastic or rubber coated band clamps (most shops have drawers filled with them, used to mount rear racks, etc) and use them as clamps on the rack's tubes.
I did this and it easily supported a top box.
I don't have a picture (no longer use a top box and sold the rack) but here's a shitty drawing clearly showing what I mean.
Old 01-04-2013, 11:04 AM   #253
EastBoundAndDown
Oddometer: 729
Nice! I will do that, thanks. Great eye to see I had a fender eliminator, you know these bikes quite well. That should hold the box I bought.
Believe it or not, I will be using the bike for some 2-up day trip touring. I need a set of soft side bags that will fit with a passenger. Any experience on what will be small enough to work?
Old 01-04-2013, 11:53 AM   #254
Cosmic Charlie
Cosmic Charlie's Avatar
Oddometer: 2
Hi inmates,
This is my first post. I'm building my SV into a tourer to take some long-distance trips (south) this winter. So far it's got:
Plexifairing GT windscreen
Givi top/side racks
Happy-Trail panniers
Powerlet 12V charging outlet
MSR 1L spare fuel bottles
The stock seat has been fine for me but I'm probably going to throw on some higher bars. Maybe heated grips too. Open to suggestions from those in the know.
Cosmic Charlie is offline   Reply With Quote
Old 01-04-2013, 12:56 PM   #255
ducnut
Oddometer: 3,320
Those are commonly called "P-clamps" and they, also, have those at home improvement stores. May have to ask an employee where they're at, though.
No kidding. I saw you didn't have the original fender, but, couldn't have begun to tell you what was there. Sheesh!
'96 Ducati 900SS
Times are GMT -7.   It's 03:22 AM.
