Old 02-02-2012, 12:27 PM   #76
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Originally Posted by camgregus View Post
There is an internet vendor that modifies them to fit with iphone cords to allow use of the remote/mic like the newer ones. Reviews said that it had more bass/mid and muddier highs. Anyone have experience? I have an extra set of e6s that I am tempted to attempt to solder and shrinktube myself...
Link?
Originally Posted by John Smallberries View Post
I noticed that they are more likely to stick in your ears after a few months of use. If you swap out the rubber bellows thingie with a new one, they come out easier.
I tried the dental floss, but did not add the beads on the end. That is the better way to go.
A friend would always use ear lube. No shit, there is such a thing. Amazon link.
tedder is offline   Reply With Quote
Old 02-02-2012, 01:23 PM   #77
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
Originally Posted by tedder View Post
Link?
Lick 'em before putting them in. Yup, it sounds gross but it works just fine.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 02-02-2012, 01:33 PM   #78
Strominid
Oddometer: 26
If I could lick my ears, my wife would never let me leave for a ride.
Strominid is offline   Reply With Quote
Old 02-02-2012, 01:38 PM   #79
Mercury264
Mercury264's Avatar
Oddometer: 22,168
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 02-02-2012, 02:47 PM   #80
tedder
irregular
tedder's Avatar
Oddometer: 8,797
I do that too.
Usually I lick my finger instead of licking the etymotic, I don't like the taste of my earwax.
(tmi?)
Old 02-02-2012, 04:12 PM   #81
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,546
I've tried the etymotic MC3's and was not only disappointed in the sound quality but just couldnt get them to work with a helmet on as they protrude out of my ears too far. The HF5 looks to have the same drivers as the ER6i but I can't find anything that indicates whether they are physically longer or shorter.
soyanarchisto is offline   Reply With Quote
Old 02-02-2012, 04:21 PM   #82
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,060
I have the hf5's.
They are a little bit longer but they seem to go in your ear deeper.
I found them to be almost as comfortable(but not quite)as the er6's
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 02-02-2012, 04:26 PM   #83
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,632
"The ER6i was discontinued to make room for our new generation hf series. We suggest the hf5 as a replacement for the ER6i, the speaker housing is only a few millimeters longer than the ER6i and seems to be fitting under helmets without any problems.
Best Regards,
Maureen (Moe) Defoort
Customer Service
Etymotic Research, Inc."
My hf5's are showing up tomorrow. I'll post my impression after a couple of rides and other usage.
swimmer is offline   Reply With Quote
Old 02-02-2012, 08:34 PM   #84
soyanarchisto
Oddometer: 3,546
Awesome! Can't wait to hear your review
Old 02-03-2012, 01:02 PM   #85
maveriks
Oddometer: 15
Shure SE215
For the few rides around town I wanted to get some IEMs or ear-buds; after much research I went with Shure's SE215 and am happy with both noise cancellation and music quality.
maveriks is offline   Reply With Quote
Old 02-04-2012, 05:51 AM   #86
Brunssd
Potemkin villager
Brunssd's Avatar
Oddometer: 362
Originally Posted by Brunssd View Post
So I've ordered a pair from this outfit
http://www.earfuze.com/
the motorsports version. Included is some sort of goop to make your own molded earpieces. And for only $50.
Earfuze Update
The earbud quality is fine and the sound good as well. My problem with them may be operator error but I'm not sure how I could have done it differently. You insert the buds in your ears and then mix the two tubs (per ear) of mix to form in your ear. I did this and dutifully left them in until they hardened. When I reinserted them, I couldn't get the seal in my ear canal since the moldings made it impossible to insert them deep enough to get a seal. I had a proper seal when I molded them. I looked at my work and noticed that since the earbuds are small, the molding barely had a grip on the earbud itself and I can't see how I could have done it any differently and still maintained both a seal in the ear canal and a proper ear mold. I ended up removing the moldings and using them as conventional earbuds. You may have better luck. I may reorder the molding material from them and try again myself. I think it's a valid concept, just hard (for me at least) to execute properly. I will tell you that they give you enough molding goop to do two sets of earbuds as I found after I'd molded mine and had to trim off the excess.
“Those who do not move, do not notice their chains” - Rosa Luxemburg
Brunssd is offline   Reply With Quote
Old 02-04-2012, 06:02 AM   #87
sonic578
Oddometer: 741
I am considering those as well. I have had trouble in the past getting a reliable seal with single flange tips for helmet applications, but apparently the triple flange tips are available for these here for an extra $10.
Dave
'11 GS
sonic578 is offline   Reply With Quote
Old 02-05-2012, 07:11 AM   #88
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,632
The person I bought these off of ebay from sent me the ER-4PT unit instead. So I can't provide a review of the HF5 at this time. I actually didn't realize until after using them, both on my motorcycle and at the gym. I picked them up from the post office on the way to gym and just tore into the package and started using. They may be a bit too long to use with a helmet. One of my ears felt a pushing pressure, the other seemed fine. I had to reach into my helmet to pull out the ear plugs before taking my helmet off which I didn't have to do with the ER6 but the angle of the ear plug end makes it not really an issue. I am using an Arai RX-Q. Although I think these use the same flanged tip as the ER-6 the noise isolation seems better.
After I pulled these out of the package I wondered why no one had mentioned the braided wires going to each ear plug and the much stouter, sheathed cable running from the plug to the "Y" which would have seemed like an obvious benefit for motorcycle use. The ER-4PT retail for $300 vs. $150 for the HF-5.
Oh, the sound is really good. Using with Cowon iAudio7 mp3 player.
swimmer screwed with this post 02-05-2012 at 07:34 AM
Old 02-05-2012, 07:31 AM   #89
Paulie
Paulie's Avatar
Oddometer: 315
Those will be comfortable, but they won't be noise reducing like the Etymotics. I like the lighter-weight plugs for commuting because they are easier to put in. They certainly aren't comparable, though.
gave the new Sennheiser CX200s a ride yesterday. Nice sound, more comfy than the ERs, a bit less noise reduction. Since they're 1/6 the cost we be
Paulie is offline   Reply With Quote
Old 02-05-2012, 09:08 AM   #90
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Have you ever priced a hearing aid?
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Times are GMT -7.   It's 05:46 PM.
