Old 04-23-2012, 03:50 AM   #61
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 25,646
Originally Posted by BikeMan View Post
no kidding. i would hate doing 500mi. days on any 650. i recently did a 1000mi. 87 vs 93 octane mpg compar-o. and averaged 2.9 more mpg using 93 octane. it works for me. g-luck with your bike and ride safe.
Dranrab Luap is offline   Reply With Quote
Old 04-24-2012, 10:05 AM   #62
mark444
Oddometer: 389
Off Topic, sort of.............performed a test using Lucas Gas Treatment in my Nissan Frontier.........same gas station, same route (work) for 2-3 weeks.........outside weather not much different in those 2-3 weeks..........speeds not over 60 mph. (I know, lots of variables come into play here) Lucas gave me 1 more mpg over non-treated gas. Crunched the numbers and it would not pay for itself in the long run. Wasted $$$ = lesson learned.
mark444 is offline   Reply With Quote
Old 04-24-2012, 04:57 PM   #63
BikeMan OP
smoke, drink, screw, ride
BikeMan's Avatar
Oddometer: 204
i use sta-bil ethanol treatment marine formula for 1.4 mpg increase. one bottle $6.50 treats 100 us gals. so, its cost effective.
check out the fuelly link: http://www.fuelly.com/driver/jbw/dl1000
BikeMan screwed with this post 04-25-2012 at 08:42 AM
BikeMan is offline   Reply With Quote
Old 04-24-2012, 05:08 PM   #64
Mulewright
Old Fart/Journeyman
Mulewright's Avatar
Oddometer: 113
Send a message via Yahoo to Mulewright
i use sta-bil ethanol treatment for 1.4 mpg increase. one bottle $6.50 treats 100 us gals. so, its cost effective.
I use their product marked as "Ethanol" friendly treatement and noticed no improvement in miliage but, the bike performed substantialy better with the product than without when running the 10% blend around here...
Still not nearly as well as with straight gas tho...
I do however take some with me on trips just because you can't easily find straight gas on the road....
Mulewright.......
"Streaching the Limits of Performance & Good Taste" since 1967 .
Mulewright is offline   Reply With Quote
Old 05-09-2012, 07:40 AM   #65
BikeMan OP
BikeMan's Avatar
Oddometer: 204
Thumb
check this out. http://www.fuelly.com/driver/jbw/dl1000
Old 05-11-2012, 06:42 AM   #66
garandman
garandman's Avatar
Oddometer: 4,738
Originally Posted by BikePilot View Post
I have quite extensively on the TL, monster and XB. Zero difference in mpg. Have also dyno tested the TL and found no difference there either. Your mileage difference isn't due to an octane difference. If your results are accurate, they are down to some other aspect of the fuel, likely ethanol content as I mentioned earlier.//
I did the same thing with a Subaru H6 (3.0 liter flat six). It's "recommended" to run with higher octane. There was no difference in the dyno runs.
I've found the key to mpg is in the right foot and wrist, respectively.
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R
garandman is offline   Reply With Quote
Old 05-12-2012, 07:27 AM   #67
BikeMan OP
BikeMan's Avatar
Oddometer: 204
DL1000 increase MPG
it seems a little off topic to talk about dyno runs on a mpg thread. try doing a mpg compar-o. as per at lease as good as the O.P.. which was done over a 1100 mile period. your results may surprise you. as far as ethanol blend fuel is concerned, i got better mpg with the higher octane fuel long before they started ethanol blend fuel in my area of the country, which was in 2010. g-luck and ride safe.
Old 05-12-2012, 03:54 PM   #68
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,159
Just got back from a another fantastic 227 miles, of commuting. Average speed 75mph, GPS confirmed.
4.51 gallons of gas. 87 octane.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 05-12-2012, 05:36 PM   #69
robert110411
Oddometer: 54
I've taken a slightly different
I've taken a slightly different approach to this whole DL 1000 fuel mileage problem.
I pump 93 into my tank every time the little fuel light flashes at me, just like I did on my last bike. Then I ride until the light goes off again, then I fill up again.
Now, I know for a fact that my CAR returns about 2 MPG's more with 93......but that's my car.
If I ever start worrying or even arguing about 1 MPG? I'll trade my bike in on a Bergman scooter.
robert110411 is offline   Reply With Quote
Old 05-12-2012, 07:50 PM   #70
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,159
Yeah, but which fuel light?
You got your 1 solid bar and flashing fuel pump. Then your flashing bar and flashing fuel pump.
FWIW, when the bar starts flashing, I ususally pay my tab because it is time to go home.
Old 05-13-2012, 06:45 AM   #71
robert110411
Oddometer: 54
when the fuel pump flashes I've usually reached the limit of my ass's ability to sit down........so I start looking.
Old 05-19-2012, 05:39 AM   #72
BikeMan OP
BikeMan's Avatar
Oddometer: 204
possible damage due to low octane fuel.
Old 05-19-2012, 06:23 AM   #73
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,159
That's the weirdest looking Vstrom Piston I've seen yet.
Old 05-19-2012, 06:53 AM   #74
Mulewright
Old Fart/Journeyman
Mulewright's Avatar
Oddometer: 113
Looks like a classic case of detonation to me.....
Pre-ignition burnes holes in the middle as a rule.
Mulewright.......
Old 05-19-2012, 06:55 AM   #75
tkent02
Oddometer: 818
Did the OP even test the alcohol content of the fuel used in his original test?
Somehow I doubt it, and it is certainly useless information without.
tkent02 is offline   Reply With Quote
Times are GMT -7.   It's 03:25 AM.
