Old 11-07-2011, 07:32 PM   #1
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 43
K75S to K75GS
Truth is I'm much better at window shopping Toxic Britney in Jo Momma than I'll ever be at writing a Build Thread. So just one ground rule - Keep your expectations low and I'll try to over-deliver.
Here is where the problem started...I saw this picture.
Then this one.
I knew a little about these, having owned a K75C back in the early 90's. I remembered it as smooth and pain free to own. For this project I found a one owner, well maintained 1992 K75S with 26,000 miles, less than an hour from my house. Just $3300 later, I had myself a project.
Don't expect a lot of "before pictures". BMW made 10's of thousands of these things...we all know what they looked like. Besides, I hate having evidence of failed ideas around for my wife to use as evidence.
The Build:
The rear wheel was the crux of the project. From what I could gather, most of these conversions used either a R100GS drive shaft w/drum brake or started with the C model w/drum brake. I wanted to keep the disk brake and go with a spoked wheel. Clearance between the caliper and spokes was the issue. Lucky for me Zach at Woody's Wheel Works solved the issue with a different model caliper and rotor. I'm currently using the rear Progressive shock that came on the bike with the upper mount repositioned down to raise the rear of the bike.
Front end is a 45mm Marzocchi Shiver and triples off a GasGas FSE450...FleaBay find. A 1" spacer below the top triple and this thing bolt right on...sort of. Baja Designs dual 8" lights that were sitting around the garage and a new Pro Taper bar finished off the front end.
Exhaust- Kept the 3 into 1 and had Collins Muffler in Loveland bend up a pipe to connect the silencer. The silencer is a Delkevic oval shortened 4".
Center stand - lengthened 2 inches to deal with the longer suspension.
The Ride - My experience is limited to 100 miles so far with about 20 of that gravel and/or easy fire roads. Got to say I'm pretty amazed to this point. It's no 950SE but it has no trouble getting out of it's own way. Still some sorting to do with the suspension but we're not too far off. Needs a skid plate and maybe some engine crash guards.
As projects go this was a 4 on the 1-10 difficulty scale...so far.
A few photos.
Muddy3 is offline   Reply With Quote
Old 11-07-2011, 07:43 PM   #2
Mr. Magoo
n/a
Oddometer: 4,978
I love it!
Mr. Magoo is offline   Reply With Quote
Old 11-07-2011, 07:48 PM   #3
dpforth
no inline fours
dpforth's Avatar
Oddometer: 316
That bike is just effin awesome, great job. What rear hub did you end up using? Just bolted on?
I had a K75 for a little while but someone else wanted it more before I finished it.
Cheers
dpforth is online now   Reply With Quote
Old 11-08-2011, 07:46 AM   #4
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 43
dpforth-
The rear hub is from an 1150GS. The rim is a 17" running a 130/80 - 17 TKC80. It is a direct bolt on, as long as you use the 1150GS rotor and caliper then offset the rim from the centerline of the hub a bit.
Cheers
Old 11-11-2011, 04:34 AM   #5
maalstroom
Ferret Legger
maalstroom's Avatar
Oddometer: 458
Nice job! Can you show how the lights are mounted.
My gears grind more and more each day.
maalstroom is offline   Reply With Quote
Old 11-11-2011, 08:15 AM   #6
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 43
How's this? Hose clamps, brackets and a couple hitch pins.
Old 11-11-2011, 08:22 AM   #7
SUVslayer
SUVslayer's Avatar
Oddometer: 833
Very cool. And pretty unique. Can't say I've ever seen a GS'd K bike. Me likes!
IMHO, hose clamps to hold all those lights seems a little (lot) weak, esp if you're planning on any off roading fun beyond fire roads. I'd think about beefing that up with a solid bracket.
What's the rear shock?
SUVslayer is offline   Reply With Quote
Old 11-11-2011, 12:18 PM   #8
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,298
Looks like the same clamps on the original photo. Rick Stator sent me the same ones for my dual 8" headlight set-up. I sold them to some guy named Doug who rode the across some place called Russia. I think they'll hold up.
2007 BMW GSA for sale.
joenuclear is offline   Reply With Quote
Old 11-14-2011, 04:50 AM   #9
MikeJansen
Lost
MikeJansen's Avatar
Oddometer: 119
Awesome!
I am looking for a K75 atm partially because of you and your build. I would love to know more about your front fork set up. You mention that they are 45mm Marzocchi's off a GasGas.
Did you use the yokes from the GasGas too or did you modify the BMW parts? Also is that the GasGas wheel mounted up front?
One last thing for now, could you show the lowered shock mount?
Mike
"A good traveler has no fixed plans and is not intent on arriving." - Lao Tzu
MikeJansen is offline   Reply With Quote
Old 11-14-2011, 06:55 PM   #10
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 43
I used the triples from the GasGas. The backup plan was to have a custom set of triples made for these forks. A quick Google search brought up a guy out east that would make up a set of triples if needed.
Below is a photo of the lowered shock mount. It consists of two pieces of steel plate bolted to the original shock mount hole and the unused hole in front of the shock. The shock is the Progressive one on the bike when I purchased it. Not as much travel as I originally wanted in the rear end...but works surprisingly well so far on the gravel and fire roads.
Also note that the original red side panels are back on the bike. I made brackets with rubber grommets to hold the rear of the panel. This rear side panel mount, normally slides into the tail piece bodywork, which is now gone.
Added tank knee pads, and a skid plate to the sump over the weekend. Also replaced the crankcase breather, which was cracked, go course.
Next up are dirt bike foot pegs. I'm open to great suggestions and ideas.
Old 11-14-2011, 11:29 PM   #11
MikeJansen
Lost
MikeJansen's Avatar
Oddometer: 119
Rockin'!
Thanks for the pics and the information!
Now I just gotta find a good K75S to start with
Some days I wish I was back in the states. . . . parts here can get frighteningly expensive.
M
Old 12-01-2011, 07:10 PM   #12
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 43
Finished a couple of upgrades;
First - heated grips. Bike came with a socket for the electric vest, now the hands will be toasty too.
Second - IMS pegs.
Third - A little protection for the cooling system.
Last - Tail rack and new brackets. 3/16" ABS plastic bent up at both ends with a few holes drilled for straps. The new brackets are fabricated from steel sheet and attached directly to the frame tabs. Pretty solid...I stood on the rack the other night...all 215 lbs and it barely flexed. Rack should fit a Rotopax fuel tank about perfect for some extended range.
Old 12-03-2011, 05:32 PM   #13
Tork
Pinsetter
Tork's Avatar
Oddometer: 3,510
http://lasvegas.craigslist.org/mcy/2734701793.html
For those who are looking for a starter bike for GS treatment,
No affiliation
Tork is offline   Reply With Quote
Old 12-05-2011, 02:35 AM   #14
Tanami
Under The Weather
Tanami's Avatar
Oddometer: 301
just stumbled across this muddy....
thought you might appreciate it..
http://www.motorradonline24.de/mo24f.../umbau-zur-gs/
Tanami is offline   Reply With Quote
Old 12-23-2011, 10:10 PM   #15
RAGBrian
jonesing for a ride
RAGBrian's Avatar
Oddometer: 1,020
Nice project! Subscribed to watch this evolve. I need to keep an eye out for a future K bike - I always have wanted one, now it looks like I should get one and think about doing the same mods.
RAGBrian :: NC700X ::1978 CX500 Standard :: 1976 CB360T ::
"Going where you don't belong, I decided a long time ago, is the root of all misery and the soul of all adventure." - Peter Egan
RAGBrian is online now   Reply With Quote
Times are GMT -7.   It's 08:43 PM.
