Old 11-15-2011, 10:06 AM   #31
windquest OP
windquest's Avatar
Oddometer: 574
Originally Posted by MrPulldown View Post
Due to the remoteness of the trip is seems like it would be a good idea to carry a tube and flat repair, just in case. Seems like a mousse failure would leave you stranded. Esspecailly if you have no experiance with it.
Use mouse for the convenious of a flat free trip. Carry a tube and pump and levers as back up.
I was reading Coletech (sp?) report on the BAM road. He uses mousse.
The reason I was looking at using tire mousse was to eliminate the spare tubes/pumps/levers/time required to fix flats.
We will have a "support guy" with backup spares etc, who will be able to helicopter us spares in an emergency, he will be camped at one end of the trail. This scenario is obviously very expensive since it's in a remote part of northern Canada, but we simply do not have the capability to take every spare we would like as our bikes would become unrideable.
Our other problem is that we have to cover an unsupported section (Canol Heritage Trail) which is about 750km with no people, no gas, no supplies, nothing. Keeping the bikes as light as possible is nessecary to maintain fuel economy that will allow us to make it 750km without re-supply.
So far based on the above posts, a properly installed mousse, in a 250 sized machine keeping max speed below 100km/hr should have no problems making it on our trip, and as a back up our "support guy" would have the tires/tubes/spares/tools available to helicopter in should we have a failure .
If this turns out to not be the case then we will just stick with tubes and carry the appropriate spares & tools...
Thanks for the tip about his report on the BAM I will look into that.
Trans-Canol 2014ish
windquest is offline   Reply With Quote
Old 11-15-2011, 10:18 AM   #32
windquest OP
windquest's Avatar
Oddometer: 574
Looked into the use of Mousse on the BAM road, it doesnt' say what type was used other then that the mousse was not solid and had a tube inside that had got punctured due to tearing in the mousse.
I was under the impression that the Michelin and Mefo mousse were solid?
I did also read about the crazy polish dudes on KTM400's that had complete failure in rear mousse after 300km, I am taking a big assumption by saying that they probably were not the right size, lubed properly, used with speeds exceeding max reccomended or damaged upon instilation...
It is hard to ever know as there was never any information on how they were installed, what size, what speed they were used at, lubrication etc...
Trans-Canol 2014ish
Old 11-15-2011, 10:35 AM   #33
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,643
Thumb Great Thread!
Following your thread with great interest Windquest.
Can't wait for the RR. Good luck with the prep.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler screwed with this post 11-15-2011 at 01:26 PM
Tarheel Wheeler is offline   Reply With Quote
Old 11-15-2011, 11:59 AM   #34
windquest OP
windquest's Avatar
Oddometer: 574
Can'r wait for the RR. Good luck with the prep.
Trans-Canol 2014ish
Old 11-15-2011, 03:38 PM   #35
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
What about tire balls?
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 11-15-2011, 03:55 PM   #36
fasteddy
fasteddy's Avatar
Location: Southern Ontario, Canada ( Niagara Peninsula )
Oddometer: 331
Tech Tubes
Tire Balls are an option, here's another, WER Products ‘Tech Tubes’ http://www.werproducts.net/Tech-Tubes.html and http://www.offroadmotorcycles.ca/jou...e-inserts.html
I've been following this thread since it was put up, I've done a lot of remote riding, not as remote as the Canol Rd however. Having a helicopter deliver a tube in the case of failure seems a bit over the top, one front tube ( can be used in both front and rear tire) and a patch kit really won't add to your kit and will give you the backup you'll need.
My two cents
Ed...
2003 KTM 640 Adv-gone
2005 KTM 640 Adv-gone
1993 KTM 400 LC4 EXC (winter project)
2003 KTM 250/350 RFS EXC
2006 KTM 640 Adventure
2008 HUSABERG 550 FE
2008 Paris to Dacre, TEAM ORANGE KRUSH
5 KTM's and 1 Honda Circumnavigate Ontario's Algonquin Park
4 KTM's and 1 Honda Go North, to Abitibi Canyon & Beyond
3 KTM's, A Honda, A Husaberg, and a Jam Tart
4 Ktm's and a Honda go "NORD"
fasteddy screwed with this post 11-15-2011 at 05:30 PM
fasteddy is offline   Reply With Quote
Old 11-15-2011, 07:18 PM   #37
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Mitas Mousse'lets?
NordieBoy is offline   Reply With Quote
Old 11-18-2011, 10:15 PM   #38
lastplace
lastplace's Avatar
Oddometer: 892
I've used Michelin Mousse in Michelin Desert (or sometimes Maxxis Desert) tires for aggressive dualsporting on an XR650R for years.
The front mousse lasts longer than the tire. Probably longer than 2. When it wears out, it just gets soft. Plenty of warning.
The rear mousse can get hot or can deteriorate more abruptly, especially in hot conditions, fast gravel, or on pavement. It can turn to goo, or sometimes it expands and pops the tire off the rim. (This happened to me several times, and once on the I5 at 85mph where it locked the rear wheel in the fast lane in traffic, but that's another story.) To avoid abrupt failure of the rear mousse: use 2 rim locks and use the M02 "Rally" mousse. (M14 is the Michelin designation for the smaller, softer "Enduro" mousse) Double rim locks will make the mousse last about twice as long as without rim locks, and will keep the tire on the rim in most cases of sudden failure.
In addition to the mousse, I've tried tubes, tire balls, and tubliss. All have their advantages and all have failed me too, but I use mousse exclusively now unless I am planning to spend hundreds of miles on pavement. Then I'll use a tube.
I'm so confident in my mousse that I don't carry a spare tube or tire changing gear any more. I carry some heavy duty zip ties and plan to zip tie the tire to the rim if things get ugly.
fun fun
Charlie
lastplace is offline   Reply With Quote
Old 11-18-2011, 10:47 PM   #39
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,203
My two cents
Ed...
Man, in those WER videos all those vise grips and hammering huge tire irons into the bead look like it would scratch and rip up the rim. Color anodized rims would really get trashed. Those foamies look like a LOT of work to install and remove. Never tried doing them myself, yet.
cyborg is offline   Reply With Quote
Old 11-18-2011, 11:03 PM   #40
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Combo
In a local enduro magazine I just read that they fit the Tubliss inner bladders underneath the mousses. That allows you to adjust the pressure for highway use while it helps to manage heat build-up. When the mouse becomes soft, you apperently up the pressure to keep the feel consistent. The bladder is completely protected by the mousse.
I have not done that, I have not seen the results in person. However, if this works it might just be the ultimate solution.
I would just pay some-one else to fit it
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-19-2011, 01:39 AM   #41
olec
Rookie
Oddometer: 273
BINGO!
This is the ultimate solution! Do something to seal the nipples either by some tublis inner bladder or search in the LC8 threads (lots of guys are creating tubeless setup from sealing the nipples with 'something' in there). Then use a valve and regulate the pressure when hitting longer paved highspeed sections. I use my valve for putting pressure into the tire so the bead pops in place (when running mousse), and sometimes the high pressure stays for quite long time becaue the mousse blocks the valve and the air doesn't go out again. So, seal the nipples completely in some way, and you have the perfect setup. This was the most creative idea for some time in here.......
olec is offline   Reply With Quote
Old 11-19-2011, 07:35 AM   #42
windquest OP
windquest's Avatar
Oddometer: 574
Charlie, thanks for your take on mousse, I'm feeling more and more confident that going with mousse is our best bet. Max speeds will be followed probably 100km/h, temps will be rather cold compared to desert. We will see between 20 celcius and -10 celcius with most temp around 5-15 celcius, this should help against heat buildup... I'll also take ur advice on rim locks.
Jason
fun fun
Charlie
Trans-Canol 2014ish
Old 11-19-2011, 02:53 PM   #43
cyborg
cyborg's Avatar
Oddometer: 5,203
In this magazine article, did they just use the Tubliss inner tube, which is like a skinny bicycle tube, under the mousse? I assume they did not use the Tubliss "red bicycle tire" bead locker part of the Tubliss system?
I have used the Tubliss system with good results so trying to picture the Tubliss tube with the mousse. That would make for quite heavy wheels too.
Old 11-19-2011, 04:29 PM   #44
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
I've never used anything but tubes so i have no idea how much any of the other stuff actually weighs, but it seems like if you had a mousse and a tubliss system in there it could be comparable, if not heavier than just bringing tire changing tools and an extra tube and a patch kit.
Put another way, is weight savings actually a legit reason to dual sport on mousses?
bxr140 is offline   Reply With Quote
Old 11-19-2011, 11:30 PM   #45
Bill the Bong
Supern00ba
Oddometer: 961
They actually used the Tubeliss inner tube in the rear and a bicycle tube in the front. The idea was just to be able to adjust the feel and extend the use of the mousse when it becomes soft. The tubes should be as thin as possible otherwise you'll not be able to fit it with a new mousse. I have a feeling that it would be quite a mission in any case.
Times are GMT -7.   It's 04:13 AM.
