Old 11-15-2011, 11:49 AM   #1
F16Viper68 OP
Trapped in the Sandbox!
F16Viper68's Avatar
Oddometer: 843
1981 Honda CB650C aka "The Titanic's Anchor"
I have a 1981 Honda CB650C I recently purchased off of craigslist which hasn't run in about ten years. It's in rough shape cosmetically but only has 8k miles on it. Over the course of past few weeks, I've rigged up a temp gas tank, adjusted the valves, performed a compression check (150 psi across all four) replaced the spark plugs, changed the oil/filter, changed the air cleaner, replaced the battery, and rebuilt the carbs.
It's running now on all four cylinders. It was only running on three cylinders due to the slow speed jet on #3 being plugged. To fix that issue I disassembled the carbs (not the rack), soaked in pine sol overnight, flushed with water, air, carb cleaner, and air again. Did your standard carb rebuild and re-installed.
It's running pretty smooth but I noticed a pretty wide temperature difference when I check the exhaust tubes (as they exit the motor) with an infrared gun.
#1 = 100 degrees F
#2 = 175 degrees F
#3 = 268 degrees F
#4 = 150 degrees F
Is this normal? If not, can it be caused by the idle mixture which has not been fine tuned or the carbs being out of sync? Waiting on manometer.
Dave...
pirahna - If any of us put a dollar value on the time we spend on our hobbies we would all look like idiots.
F16Viper68 is offline   Reply With Quote
Old 11-15-2011, 12:09 PM   #2
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,000
Short answer: yes.
Brad Felmey is offline   Reply With Quote
Old 11-15-2011, 12:10 PM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Have you synced them yet?
Old 11-15-2011, 12:11 PM   #4
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,351
More work to be done, Dave
ASSuming the carbs are clean now, float level must be correct. Too low will make a lean condition.
Be sure there is no air leak. Typically the carb boots/holders that attach to the head will get old & leak. Offering a LITTLE propane to each cylinder will tell you if any are lean. If the idle falls off it's too rich, if it raises it's too lean.
Consider what the infrared tool is looking at. I've found it can be sensitive to textures. Like if one pipe is dirty, you'll get a different reading.
Finish the job by syncing them & getting the mix screws adjusted. (Did I mention float levels must be correct.)
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 11-15-2011, 12:26 PM   #5
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
And again, yes. The carbs not being sync'd and in proper mixture/float level will cause variances in your readings. Cooler tends to indicate a richer mixture and hotter tends to indicate a lean condition.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 11-15-2011, 12:53 PM   #6
Tosh Togo
Oddometer: 1,594
-Joe
And going leaner than peak also results in lower temps.
Synch the carbs, and see what you get.
fwiw, the inner exhaust cylinders' temps should be noticeably higher, especially when the bike's parked to check temps and the breeze has gone away.
Tosh Togo is offline   Reply With Quote
Old 11-15-2011, 01:17 PM   #7
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,094
Good tips here.
As Motomantra said, cracks in the rubber between the carbs and cylinders can cause those lean conditions. A good way to check that is with a small squirt of WD-40 around the "intake manifold". If the idle changes, you've got a leak.
High Country Herb is offline   Reply With Quote
Old 11-15-2011, 03:18 PM   #8
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
#1 = 100 degrees F
#2 = 175 degrees F
#3 = 268 degrees F
#4 = 150 degrees F
Dave...
Those temps are very low; either the pipes are double wall where you are getting readings, or the bike was
only running for a few moments. And considering the low temps, the difference is small. Usually temps at
idle where the pipes exit the heads run 3-400 or more, and if one shows 100 or so, that cylinder is not running,
with that temp being just the result of pumping friction....
Recheck where you took the readings, and let the bike run for 15 minutes before you take temp readings. Since
you did not remove the carbs from each other, they are likely still in sync. Since the bike runs smoothly at
idle, it's probably fine. You can pull off each spark plug cap in turn with the bike at idle. Each time one is pulled
off, the rpm should drop about the same amount....
CycleDoc59 is offline   Reply With Quote
Old 11-15-2011, 03:23 PM   #9
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Yes, teh Jap bikes (with chrome pipes) have double wall pipes. The float level at idle will only be an issue if it's grossly misadjusted, not likely. The "high temps from a lean condition" are ONLY AT WOT AND ENGINE LOAD, or at least a nearly so throttle opening and load. At idle, a lean condition will show a cooler exhaust temp.
Old 11-15-2011, 04:40 PM   #10
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Thanks for all the advice. To answer some of the questions:
Float Levels - The float levels on these carbs can't be adjusted, it's either in spec or the float needs to be replaced. I discovered after the fact you can check them but can't adjust them.
Sync - No, I haven't sync'ed them yet since I don't have a manometer. I ordered Motion Pro manometer and adjustment tool last night.
Idle Mixture - I have the screws set 2.5 out. I'm getting conflicting info on the initial setting (2.25 and 2.5). According to the manuals I have, I need a more accurate tach since the bikes tach is not accurate enough. Any suggestions?
Temp Readings - The bike had been running about 15 minutes when I took the readings. I do admit the variances seem wide and low. Had me baffled. I'll recheck when I get a chance.
Cylinders - I did notice a drop in RPM's when I removed the wires from each cylinder but the drop was more noticable when I removed #3 and #4. #1 minor drop, #2 more, #3 a lot, and #4 near stalls.
Intake Boot Cracks - I tried the WD-40 trick when I was troubleshooting the #3 cylinder not firing and didn't notice any change in RPM. I'll check again when I recheck the temperatures.
Thanks again for all the advice.
Dave...
Old 11-15-2011, 06:48 PM   #11
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,651
If you are shooting an IR gun at the exhaust.... IR does not like reflective materials and the chrome will give false readings.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 11-15-2011, 07:32 PM   #12
DirtViking
SKOL!
DirtViking's Avatar
Oddometer: 372
I'd probably go back to the jets on #3 carb to ensure they are in fact clean... It may have looked clean, but since that was your troubled cylinder, it would be worth another look. Are you sure that the #3 idle jet is the same as the others? Stock? Jets are easily changed by owners fiddling with different intake systems and exhaust.
Reading the plugs would give you a pretty good idea of what's going on. At a minimum, they can be compared to one another.
You could also compare the plugs after riding at 3000 rpm or so and then chopping the power. Coast to a stop and read the plugs again. Try a higher rpm last, maybe 6-7000. The goal is to get the plugs to look the same at all levels. Those readings should indicate the effectiveness of your other jets.
I'd probably sync the carbs last, after you are sure everything else is within spec. Not sure about that bike, but you never mentioned timing. If it's mechanical, a timing light and a dwell meter for the points are required.
Jon
2011 1200 GSA
2012 WR450F
1970 Triumph Bonneville
DirtViking is offline   Reply With Quote
Old 11-15-2011, 07:51 PM   #13
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
That may be the case but it gives consistent false readings.
Dave...
Old 11-15-2011, 08:03 PM   #14
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Jon
I know for a fact all of the jets are clear. I spent a lot of time ensuring this fact since I'd already been in there once. While surfing another forum (yes they exist ) I found a very good article on rebuilding Honda carbs. http://www.cb750c.com/publicdocs/Sea...anual_revD.pdf
I replaced the idle jets and main jets. The slow speed are pressed in and can't be swaped out without major modifications.
I'll do a plug check but the road check is going to have to wait. This thing needs a lot of work before it's ready for the street.
I haven't check the timing on the bike. Good point and something I need to do.
I just spent the past few hours trying to figure out why the sucker wasn't charging. Think I got it figured out. It confused the hell out of me because during my initial t-shooting the stator was reading shorted to ground. After removing the covers the short disappeared. Started chasing wiring and discovered the mess below. It was pinched by the primary cover.
Old 11-20-2011, 05:04 PM   #15
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Ok, today was about getting the fork seals replaced. As you can see below they've been leaking. ;D
Everything came apart pretty easily.
When I pulled off the dust seals I discovered I was in for a battle. The c-clips were rusted in there pretty good. I scooped out as much of the gunk I could, blasted it with air, and soaked them in PB Blaster for about six hours. After wrapping the fork tubes in blue painters tape I started tapping the clips with a drift pin to see if I could break it loose. After much fighting was able to remove the clips and washers.
Removing the seals was accomplished by blocking the air hole, filling it with ATF fluid, and using a wood clamp to compress the fork which brings the seal up to the top.
Despite my efforts the seals still came out crooked (not as crooked as the pic. That's after prying for awhile) so I spent about 30 minutes prying them out.
The longest part of this job was the polishing and buffing. Holy crap getting those DoD sticker off was a MoFo. I have a lot to learn about polishing but I think they look better than they did when I took them off the bike. ;D
Dave...
Times are GMT -7.   It's 07:20 PM.
