Old 05-26-2013, 05:19 PM   #91
F16Viper68 OP
Trapped in the Sandbox!
F16Viper68's Avatar
Oddometer: 843
I decided to take the cylinder head off to swap out the head gasket and oil seals to address a minor oil leak. While everything was apart I replaced the valve seals and lapped the valves. The hardest part of the operation was finding a suitable spring compressor that didn't cost a fortune. After checking the auto parts stores (everything was too big) I figured I'd just make one out a c-clamp and cut up socket.
It worked pretty well but when I was putting the keepers back in I realized I wished I played more of the game Operation when I was a child.
When I re-assembling everything I realized the gasket kit from Athena didn't include the small O-ring gaskets I needed on the left and right side of the cylinder head.
I figured since I was going to need to order the O-rings why not just order a OEM head gasket too.
pirahna - If any of us put a dollar value on the time we spend on our hobbies we would all look like idiots.
F16Viper68 is offline   Reply With Quote
Old 05-26-2013, 05:40 PM   #92
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
I partially assembled the engine so I could paint it with Dulicolor 1615 Aluminum. I cleaned up what I could with wire wheels, brass brushes, gray scouring pads, taped it off, and painted. It's not perfect by any means but it looks better than it did before.
Old 05-26-2013, 06:37 PM   #93
brucifer
brucifer's Avatar
Oddometer: 2,519
Well, that "not perfect" painted engine is going to look sooooo good when you get it back in the frame. You're really doing a nice job on this bike.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 05-26-2013, 07:20 PM   #94
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Thanks! I'm getting closer to getting it back on the road. When I get back from my next business trip I should (knock on wood) have everything I need to get it back together.
Mulling over having a machine shop look at the cylinder head to ensure it's still flat.
Dave...
Old 05-27-2013, 06:04 AM   #95
brucifer
brucifer's Avatar
Oddometer: 2,519
Certainly wouldn't hurt to have a shop check it for flatness. Can't imagine them charging you much to do so. My local shop usually checks cylinder heads for me while I'm standing there--no charge. Of course if it needs milling, they get the job. :)
Old 05-29-2013, 06:32 PM   #96
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
I know this probably varies greatly but what's the typical cost?
Old 05-31-2013, 03:23 AM   #97
KeithTurk
KeithTurk's Avatar
Oddometer: 767
Nice work here.... I collect 550's... which have most of the problems yours had with oil seals between the Head and cylinders... ( I'm getting better at ignoring them )....
Fun
200 mph club ace
Race director ECTA
Honda 550x4 to Mexico - ADVrider
KeithTurk is offline   Reply With Quote
Old 05-31-2013, 12:17 PM   #98
brucifer
brucifer's Avatar
Oddometer: 2,519
I asked my machinest what he charges--nothing.
Old 06-01-2013, 06:22 PM   #99
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Fun
I was reading over at SOHC.net folks jam rope in between the cylinder head fins to absorb the leaking oil and swap it out every so often. I wish I had learned that before I torn it down.
Still waiting for the new head gasket to come in.
Dave...
Old 06-01-2013, 06:23 PM   #100
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Cool and thanks for asking. I'm going to start asking around to find out where I should bring it.
Dave...
Old 07-06-2013, 04:52 PM   #101
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Well finally got around to putting this thing back together. The cylinder head and deck were well within spec with regards to the amount of warpage so I replaced the valve seals, lapped the valves, and replaced all the gaskets. I tried for over a month to find a OEM head gasket but everyone kept canceling the order despite showing them in stock. I ended up ordering a gasket kit from David Silvers.
Once I was able to find a friend with the time to help me muscle the engine back into the frame everything went pretty smooth.
Here she is in all her new found glory.
Old 07-06-2013, 04:53 PM   #102
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Here's a few before (Oct 2011) and after (July 2013) photos.
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Dave...
Old 07-06-2013, 05:22 PM   #103
civhatch90
civhatch90's Avatar
Oddometer: 128
Looks amazing! must feel good to ride it after so much work.
civhatch90 is offline   Reply With Quote
Old 07-06-2013, 05:45 PM   #104
brucifer
brucifer's Avatar
Oddometer: 2,519
Excellent!
Looks like the bike in the background changed as well.
Old 07-06-2013, 06:26 PM   #105
F16Viper68 OP
F16Viper68's Avatar
Oddometer: 843
Thank you very much. I just got back from a 45 minute ride it's running better than ever. It had a weird hesitation in 4th and 5th gear at 3500rpm which is now gone.
Now I need to work on the suspension.
Dave...
Times are GMT -7.   It's 01:10 AM.
