Old 04-01-2005, 02:26 AM   #1
TerryM OP
Oddometer: 39
Garmin software on Apple Mac?????
Does anyone know if and how the software maybe run on Mac please?
TerryM is offline   Reply With Quote
Old 04-01-2005, 03:56 AM   #2
Slimie
Oddometer: 1,078
Virtual PC, AFAIK.
Slimie is offline   Reply With Quote
Old 04-01-2005, 04:54 AM   #3
Gizmo
Hermes
Gizmo's Avatar
Oddometer: 1,668
Don't even go there, I just tried this using Virtual PC and it works up until you try to connect the GPS and transfer maps. It will not recognize the GPS. When I called Garmin they said their units are not designed to work with Mac's even with Virtual PC on board. I did some investigating and it seems the problem is that Mac's use USB for the mouse and keyboard and this creates a conflict. I ended up using an old PC laptop I had to make use of the software and my GPS, just hope it keeps working. This is a sad story with Garmin and really has my feathers ruffled. Sorry I cannot be more optimistic.
Regards & Ride Safe!
Bruce
4-Wheels moves the body, 2-wheels moves the soul
09' BMW K1200 LT
IBA # 8547
Gizmo is offline   Reply With Quote
Old 04-01-2005, 07:05 AM   #4
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
I thought people that used Apples drove VWs and rode bicycles...
RocketJohn is offline   Reply With Quote
Old 04-01-2005, 08:32 AM   #5
Tim
Tim's Avatar
Oddometer: 2,361
Although I have seen reports from someone on AdvRider that he was able to use Virtual PC with his Garmin, I tried and failed Had to go out and get a used PC just for Garmin work.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 04-01-2005, 09:38 AM   #6
TerryM OP
Oddometer: 39
Thank you all, that will save me some heartache failing to make it work.
Perhaps I will install the PC in my VW camper and the GPSMap 276C on my bicycle then dream about getting a motorcycle when my hormone levels improve!
Old 04-01-2005, 10:24 AM   #7
Danamr
Danamr's Avatar
Oddometer: 282
All that has been said is true, trying to run mapping software on VPC is painfully slow, and if the GPS is a serial connection forget it. OTOH if the GPS is one of the newer units that are true USB you can make that work.
Danamr is offline   Reply With Quote
Old 04-01-2005, 10:27 AM   #8
fire_strom
fire_strom's Avatar
Oddometer: 1,256
i married a PC user so i do my mapping on on her laptop.
scott
fire_strom is offline   Reply With Quote
Old 04-01-2005, 02:34 PM   #9
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,466
Boy that was an expensive solution but I admire your dedication. I'm buying a laptop on ebay now just for this reason. No Mac support, 256 proprietary cards that I'll have to get 3-4 of, then the Touratech mount then, finally, I'll have access to 4-5 year old out of date information.
Remind me why again?
I wish the TomTom Rider was out or the Lowrance iway 500c had batteries. There's no good solution is there? Does your wife have a sister with a laptop?
G
sakurama is offline   Reply With Quote
Old 04-01-2005, 02:42 PM   #10
bigmizzle
Grease Pirate
bigmizzle's Avatar
Oddometer: 308
and sometimes they RIDE BMW'S and sometimes they ride bicycles
are you trying to stereotype someone?
2000 R1150GS
1984 Mercedes 300SD Turbo-Diesel (WVO)
Founder of Westside-Greasers car club
$5 off smugmug coupon M1l1PZrRsFWYo
bigmizzle is offline   Reply With Quote
Old 04-01-2005, 05:08 PM   #11
Crossmojonation
Oddometer: 39
Actually you might not be in as big a hole as you think.
Check out this thread and you may find some helpful info. Using GPS and Mac
Crossmojonation is offline   Reply With Quote
Old 04-01-2005, 06:45 PM   #12
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,466
GPSCity has a petition page that you should take some time to sign just to help put the pressure on the manufacturers.
That and you should email Garmin: mobile@garmin.com
It can only help...
Old 04-01-2005, 08:17 PM   #13
Bayou Boy
Bayou Boy's Avatar
Oddometer: 1,685
I just used my G4 Powerbook with VirtualPC everyday on an 8 day trip to reload maps to my GPS V with a serial/USB connector. Took like 40 minutes to upload but worked like a champ. If you don't have 40 minutes every night while eating or drinking beer or something, your trip is way to tight on time.
Bayou Boy is offline   Reply With Quote
Old 04-02-2005, 06:02 AM   #14
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,466
The issue is USB only GPS units which can't upload maps through VPC. Units that are serial can use a serial to USB and suffer VPC but USB only can't - I've tried. Garmins protocol for USB is too messed up.
Old 04-02-2005, 06:26 AM   #15
Gizmo
Hermes
Gizmo's Avatar
Oddometer: 1,668
How did you do this, I do not care about the time I would just like to ba able to do it? The computer (Virtual PC) nor Map Source recognizes my Garmin 276C.
Bruce
09' BMW K1200 LT
IBA # 8547
Times are GMT -7.   It's 12:36 PM.
