Old 01-21-2013, 10:22 PM   #421
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
Originally Posted by bee-rad View Post
Its a 1620 Pelican Case. It just fits. I removed the plastic luggage handle and wheel contraption and then welded up a mounting plate with integrated bash bar. The only gripe is the rear most latch hits the shock tower & its tricky to get your fingers in between the steel plates to snap it open, however I wanted the case as low as possible so the rifle would clear.
I'm expecting tracking details soon on my trailer. I have the iM2750 Hardig Storm Case, which is essentially the same as the Pelican 1620. Please post pic's of your bash plate if able. I have an ample supply of raw materials and a few welders at the ready to fab a bash plate, and appreciate EVERY thing you have shown us. The Kolpin is motivating too. Is that a ready made Kolpin adapter?
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 01-22-2013, 05:11 AM   #422
bee-rad
Oddometer: 7
I modified/hacked up the bracket portion which mounts/bolts to the shock tower uprights. As this aspect interferes with the rotopack mounts, I have the right rotopack mount spaced off at the lower bolt the thickness of the Kolpin bracket. If I was to do it again, I would have mounted the rifle another .25-.5" higher. With the rotopax full, and rifle mounted, any speeds above 85KPH on asphalt set up a wicked speed wobble. It wasn't an issue for myself as I spent 99% of time on gravel roads.
http://www.basspro.com/Kolpin-Bootte...SSSELL_PRODUCT
http://www.basspro.com/Kolpin-ATV-Sa...SSSELL_PRODUCT
http://www.basspro.com/Kolpin-Gun-Bo...SSSELL_PRODUCT
bee-rad is offline   Reply With Quote
Old 01-25-2013, 06:49 PM   #423
bee-rad
Oddometer: 7
Its made from a thin steel plate that was formed into a J-shape with one leg being much longer then the other. I then closed the ends off for cosmetics.
Custom adapter mounting plate for the case picks up off the rear factory mounts as shown. I used all of the factory pelican case screw locations and did not drill through the box, so it remains water tight. The bash plate is welded to the adapter plate.
bee-rad screwed with this post 01-25-2013 at 06:54 PM
Old 01-28-2013, 06:28 AM   #424
etingelefunts
retem-odo
Oddometer: 815
Thanks bee rad
Still waiting on my tracking details. Your idea will be plagiarized!!!!!
Old 01-28-2013, 12:11 PM   #425
MrBracket OP
MrBracket's Avatar
Oddometer: 256
Got three new trailers shipping later this week!!!
Here’s what’s new at Moto-Mule for 2013:
Cargo area has been lengthened by 2-1/2” to aid in fitting larger boxes like the Pelican Cases.
The frame is now modular, the cargo area bolts in with flanges. Now, one trailer can be customized to haul different things by changing out the cargo section of the frame. Watch for new cargo platforms later this year. This also makes assembly for the end user much easier. It is now feasible to supply parts to those wishing to build their own custom trailer as well.
Looks the same at a glance....
Comes apart at the flanges.
Soon to be more options for cargo area.....
No cargo area... Not sure if this has any value yet?? Could use just the rear side racks to carry gas or water???
http://www.facebook.com/MotoMule http://www.moto-mule.com
2010 Husaberg FX450, 2011 Husaberg FS570, 1994 Yamaha TW200, Next bike?? - A twin cylinder adventure bike. Why? Because most thumpers sound like two skeletons making whoopie in a trash can!
MrBracket is offline   Reply With Quote
Old 01-28-2013, 12:21 PM   #426
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,676
Uhm, I think that needs "FisherMAN tested"
I got an idea for a cargo area... any deals on a retrofit?
Mr. Fisherman is offline   Reply With Quote
Old 01-29-2013, 05:37 AM   #427
griffo1962
griffo1962's Avatar
Oddometer: 1,485
Cross post from the other thread....
Have you got a model to fit a KLX 250?
Any idea on the cost to ship this to Qld, 4217 in Australia? Looks like this new model packs down smaller. Would it be possible to ship without the tyre & tube to make it lighter/cheaper?
cheers
g
griffo1962 is offline   Reply With Quote
Old 01-29-2013, 07:06 AM   #428
kitesurfer
kitesurfer's Avatar
Oddometer: 1,613
glad to see the 2013 model. i'm still waiting for a little more development. you've got brackets that mount above the shock for mounting gas cans. someone in the past 29 pages i just read mentioned something similar to a sportbike subframe extending over the back wheel. that's what i want...could be just a steel bar to loop soft bags over each side.
2012 VSTROM ADV 650
US NAVY RETIRED
kitesurfer is offline   Reply With Quote
Old 01-30-2013, 01:21 PM   #429
etingelefunts
retem-odo
Oddometer: 815
Good fortune!!
Since my order was placed Jan 11th (me thinks)... will it be the 2013 modular variant?
The "half-pint" configuration will be great for a number of options;
  • Mini tanker with the RotopaX mount
  • Smaller pannier set up with Pelicans on the RotopaX mount as others suggested
AWESOME!!
The extra few inches is especially welcome since I already own the Hardig Storm Case im2750 which is a hair long like the Pelican 1620.
Also had an idea to make a dog trailer which is easier to adapt in modular mode.(yes there will be haters, but dog ignores death threats)
Old 01-30-2013, 01:38 PM   #430
etingelefunts
retem-odo
Oddometer: 815
Brilliant
Looks like the extra length is mostly aft of the rear cargo mount, which should help opening the rear latch on the Pelicans/Hardigs, and better still, eliminate the urge to ease the box forward which hampers turning radius.
Brilliant, brave, and commendable
to re-tool and innovate. You can NEVER address every idea or request, but that mod by itself kills many, many birds with the same stone, and probably expands potential BEYOND what many requests had petitioned for or imagined.
Old 01-31-2013, 02:53 PM   #431
hairsmith
hairsmith's Avatar
Oddometer: 223
2013 looks to be an fun and interesting year at moto-mule !
MrBracket sent you a email earlier this week checking to see if you got it ?
2000 R1150GS
1983 R100 RS
2005 KLR 650
Hairsmith
hairsmith is offline   Reply With Quote
Old 01-31-2013, 06:00 PM   #432
MrBracket OP
MrBracket's Avatar
Oddometer: 256
cheers
g
Hi, here is a pic of a moto-mule behind a 2009 KLX250
She made her own custom flat bed deck for the trailer.
Shipping to Australia is about $219 US.
Old 02-01-2013, 02:50 AM   #433
griffo1962
griffo1962's Avatar
Oddometer: 1,485
Thanks,
great shot, unfortunately that much freight makes it just way too expensive (damn!!)
Old 02-01-2013, 10:07 PM   #434
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,136
.. finally ..
.. the taxes are filed and the return should be here shortly .. ahem .. I'll be placing my order accordingly .. been waiting WAY to long to order this baby ..
.. '06 KLR 650 ..
.. just sayin' .. in case you happen to be thinking of prepping up some in the next few weeks ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill is offline   Reply With Quote
Old 02-04-2013, 12:43 PM   #435
rjmorel
Dual Sporticus
Oddometer: 296
MrBracket, great modular mods for 2013. I like the mini version. Just add a bar stool and someone will find a use for it. Place to sit if your not the "designated" driver rj
Dream Ride :I dream everytime I ride , even around town. There top that one.
Ride the world, we'll do Mars next year
2012 Honda NC700x (Dual Sporticus) shaken ,not stirred
rjmorel is offline   Reply With Quote
Times are GMT -7.   It's 03:54 AM.
