Old 09-10-2013, 05:37 PM   #511
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
Originally Posted by etingelefunts View Post
Using the 1-3/4 gallon rotopax cans puts them down so low they almost touch the ground under full shock compression. Flipped the hoops and swung them bottoms towards the bike by relocating the lower mounting hole so the tanks are essentially level, while sharing the same underbelly plane as the tub's main tube.
Would hate to have a stump miss my foot pegs and trailer load only to rip off the lower hanging up-sized Rotopax.
CG is higher, but then again so is the entire bike on a dual sport like the WR, so UP went the tanks to match. Will post photos as able.
Photo as promised;
Also ditched the "hugger" fender. It packs with mud and acts like a reverse thruster when/if it locks up the tire.
Now if only I can get a motomule.com decal set for the new rear fender
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts screwed with this post 09-10-2013 at 06:10 PM
etingelefunts is offline   Reply With Quote
Old 09-10-2013, 09:00 PM   #512
greatnortoni
Oddometer: 432
Photo as promised;
More pics of that red Jeep in the background please!
greatnortoni is offline   Reply With Quote
Old 09-11-2013, 07:35 PM   #513
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,435
Originally Posted by MrBracket View Post
.....Or better yet, take it apart and ship it to me and I'll fix it for you. I'd like to learn from it so that future trailers will be better.
NICE !!
MrBracket gave me new bearings for mine, due my abuse and neglect,
I insisted I pay for them, then he just sent them n/c.
YMMV, but.....What a guy !!
VERY deserving of more business
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 09-12-2013, 12:18 AM   #514
etingelefunts
retem-odo
Oddometer: 815
Next upgrade is replacing the modular undercarriage sectioned tube with a single 2" x 2" square tube, .062" wall (same thickness as the round tube which I believe is between 15 to 16 ga)
Even empty, no gas in cans, she has always had a tendency to weeble wobble after sudden steering input, which feeds back to the bars. The swingarm flexes too. I bushed the axle tube to about .010" over the skewer diameter which helps. After the more rigid square under tube, the swingarm will be replaced with a flipped-around and cut down aluminum swing arm from a donor dirt bike, de-horned with a spliced in head tube using the Moto Mules original head tube bearings.
Old 09-12-2013, 01:55 AM   #515
etingelefunts
retem-odo
Oddometer: 815
Tire rubbing
Hi Mr Bracket,
Some user tips for other owners, and an FYI regarding my experience with my beloved trailer;
During initial assembly I observed the MM web site and assembly instructions and opted to place the rear wheel hub's accessory side (with 4 hole flange) on the right side as seen on the MM web site. Still had to tighten the axle bolt with a little "English" to keep the knobbies off the inner left swingarm. Murphy intervened, and the axle settled towards center where the tire wound up rubbing a deep groove into the steel arm. I had noted during assembly the bearing spacer sleeve protruded out both sides as opposed to being captured between the inner races, protruding more to the accessory flange side on the right, which allowed the tire to favor left where it tended to rub. The distance between the un-sprung axle flanges measures 4.06", yet the cumulative span of the bearing sleeve and 2 aluminum spacers is a mere 3.89. The thinner of the two spacers provided was .210". Fashioning a .375" replacement eliminates the compression of the swingarms during assembly which prevents the swingarms from encroaching on the knobbies as much. Also it appears the left swingarm flange tries to spring inwards when tire is dis-mounted (bent inwards ???), which in theory would help keep the tire off that side, but once the axle nut is snug, it (left swingarm's axle flange) returns to parallel with the opposite side, and the rubbing commences. Flipping the accessory flange towards the left side, centering the internal bearing/axle sleeve, and introducing a thicker spacer to fill the surplus span between the uncompressed axle flanges has pretty much put the tire's knobbies equal distance from either inner swingarm leg. Truing and tightening the fairly new rim's spokes (good SOP in any book) may help further.
If you ever revise the swingarm for a wider one with more knobby clearance, I'll buy the first one you can spare.
Old 09-12-2013, 04:01 PM   #516
MrBracket OP
MrBracket's Avatar
Oddometer: 258
Hi Mr Bracket,
It sounds like your wheel has become "un-true" or it has at least shifted to one side. If you tighten the spokes on the side with too much gap, you can pull the tire away from the swingarm on the opposite side. Be sure to only adjust them a little at a time, and work your away around the whole rim. If the spokes get too tight, you can loosen the ones on the side that is too close to the swingarm. After you get it moved over, true the wheel.
http://www.facebook.com/MotoMule http://www.moto-mule.com
2010 Husaberg FX450, 2011 Husaberg FS570, 1994 Yamaha TW200, Next bike?? - A twin cylinder adventure bike. Why? Because most thumpers sound like two skeletons making whoopie in a trash can!
MrBracket is offline   Reply With Quote
Old 09-12-2013, 05:27 PM   #517
etingelefunts
retem-odo
Oddometer: 815
It runs true within 1/16 minimum to 3/16 (1/8" average) at the rubber, almost perfect at the rim as delivered. Flipping it around proved your point. Just wish there was more that 1/8" clearance per side when centered. Might try a modified YZ80 swingarm for the tire to compliment the larger swingarm that is replacing the front attaching arm.
Old 09-13-2013, 07:24 PM   #518
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 571
nice fender!
Photo as promised;
Nice fender & Rotopax mount! Wish you could put some eyeballs on the Rotopax caps; nobody could follow you with a straight face
"Four wheels move the body,
Two wheels move the soul." http://ridingacross.com/
Three move you & the dog!
Cromoth is offline   Reply With Quote
Old 09-14-2013, 06:17 PM   #519
Falconx84
Lurker
Oddometer: 371
Yeah.... Its like a "two-can" bird
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 09-15-2013, 06:05 PM   #520
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,544
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 09-16-2013, 02:33 PM   #521
etingelefunts
retem-odo
Oddometer: 815
Tweaked it a little and all is well. Your advice rounded out the equation.
Perfect trailer !!
Thanks.
Mr Bracket... do you know the rear shock spring rate (lbs per inch) ???
There's a cycle shop near me with a few used FOX shocks I'm considering. One of them has the correct eye spacing, damping and rebound adjustment, all I need to do is see if FOX carries a compatible spring (not too stiff or soft) for direct swapping their shock onto your trailer.
Old 09-17-2013, 11:02 PM   #522
etingelefunts
retem-odo
Oddometer: 815
Thanks in advance for any reply.
Old 09-20-2013, 09:31 AM   #523
etingelefunts
retem-odo
Oddometer: 815
Bump the inquiry above
Old 09-22-2013, 11:40 PM   #524
etingelefunts
retem-odo
Oddometer: 815
<<<<(link to signs of life)
Old 09-23-2013, 12:32 PM   #525
MrBracket OP
MrBracket's Avatar
Oddometer: 258
Ha Ha, yep still alive and kickin!
I do not know the exact springrate of the shock spring. It's an aftermarket shock for the little 50cc pitbikes. I designed the swingarm around the shock, rather than sourcing a shock for a design I already completed.
Times are GMT -7.   It's 05:13 PM.
