Old 11-17-2011, 11:08 AM   #1
Pigford OP
British
Pigford's Avatar
Oddometer: 951
Harris Magnum 1- Kawasaki
So, been hankering after a "proper" trick framed bike for some time now...... And as a dedicated Kawasaki fan - Big Zeds, when this bike turned up I just had to go for it......
Its been sat around, just cobbled together very roughly, for some years.
Consisting of: a nice green Harris Magnum 1 frame & alloy tank, seat unit, Ducati 916 compleet rear end, GSXR1100 USD front end, KZ1000A1 motor & carbs + box of bits; rear sets, clocks, shox, electrics, etc
Pigford is offline   Reply With Quote
Old 11-17-2011, 11:37 AM   #2
England-Kev
Oddometer: 3,602
It is a thing of wonder Mark, and I look forward to seeing it on the road...
England-Kev is offline   Reply With Quote
Old 11-17-2011, 11:40 AM   #3
anotherguy
anotherguy's Avatar
Oddometer: 6,348
Looks like you have some work for the winter. Subscribed.
you don't see luggage racks on a hearse..........act accordingly
Old 11-17-2011, 12:30 PM   #4
fleshpiston
fleshpiston's Avatar
Oddometer: 599
Too cool, looking forward to following this project!
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 11-17-2011, 03:49 PM   #5
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,086
In the latest issue of Practical Sportbikes they make a mention of the Harris frames and quoted them as "sited in many divorce petitions."
Carter Pewterschmidt is offline   Reply With Quote
Old 11-17-2011, 03:56 PM   #6
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
That IS and can be wicked cool!
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 11-17-2011, 06:08 PM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,511
That looks really light and zippy. I'm not a huge fan of inline 4s in general, but that thing looks like stupid amounts of fun.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 11-17-2011 at 07:06 PM
Old 11-19-2011, 08:19 AM   #8
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,108
Street Fighter it!
Old 11-19-2011, 05:47 PM   #9
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,613
Nice frame and components, now ditch the John Deere paint and the IL4, find a H2 motor and Bobs you uncle.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 11-20-2011, 09:36 AM   #10
Pigford OP
British
Pigford's Avatar
Oddometer: 951
Right then chaps - as you know the Harris is all about HANDLING - so I shall not be tweaking the motor too much, I've a set of slightly "lumpier" cams and some VM29 smoothbore Mikuni's
Here's a period write up for the Magnum 2, from Nov 1982.....
So far I've sold the GSXR USD front end and the Ducati 916 rear end - as they are the usual suspects for modded bikes My plan is to keep it looking a bit more Old Skool.
I have a ZZR1100 RWU front end and have tracked down a loverly JMC, double braced swing arm, and some 17" DYMAGS
Let the DIVORCE PROCEEDING's begin
One of the standard discs has a bent rotor, so I have got a nice new front set, to compliment the rear disc...
The JMC will need about 10mm removed from the frame pivot point - which will also mean the needle rollers have to be recessed accordingly. I have pressed the stem out of the ZZR tripple trees and will get a new one made up to fit on the Harris headstock.
Got a bit of frame brazing to sort out too - the lower rear engine mounts have been removed - but they came with the "box of bits" so just need cleaning up & sticking back on
Old 11-20-2011, 10:03 AM   #11
Oddometer: 1,086
Good call! I hate the single sided swingarm conversions. That JMC arm with those Dymags will look freaking sweet.
Old 11-20-2011, 04:27 PM   #12
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,108
Well done, laddo.
Would a J motor suit that chassis?
Period correct and a better donk, no?
I'll be watching this one with interest.
Old 11-21-2011, 12:11 PM   #13
Pigford OP
British
Pigford's Avatar
Oddometer: 951
Originally Posted by Lornce View Post
Well done, laddo.
The later "J" is a bit "fruitier", but I prefer the older (more original) kickstart motors & round cam covers
The engine mountings are different too - and this frame is made for the older model. Once I fit the lumpier cams & VM29's she'll go fast enuff for me........ If I do need a bit more squirt I'll take the motor out of my Sprint bike....
Its a 1392cc lump I built last year
Old 11-26-2011, 10:00 AM   #14
Pigford OP
British
Pigford's Avatar
Oddometer: 951
I've now had the lugs brazed back on and took the frame and swingarm to TALON for an estimate to trim 7mm off each side of the JMC & make a spindle sleeve - as the Harris spindle is 20mm & the needle bearings are 25mm :shock: They said it would be about a days work (setting up the machines takes a while) and 250 max. I could get it done a bit cheaper, but I want this work done right!!!
In the mean time I've made some card board templates of the lower rear engine mounts, to line up with the lugs..... I had some 10mm ally plate which I'll cut out for the brackets.
I also took Mr JigSaw to the Zed Butt unit & hacked a bit of fiberglass off....
The JMC is sitting ON the pivot in those shots and the rear end is sitting rather low.
I'll make some brackets and make surethe seat is nice and firm to support the rider :??
I dropped a few bits off to Mikey on Thursday afternoon and took the cam cover off - so I could get my first glimpse of the motor internals....
..... as luck would have it, the top end looks good, the cams are mint and the clearances are spot on :twisted: As you can also see, the cam caps have the standard bolts fitted - so hopefully no surprises there!
I think I'll be doing the minimal mechanical work and just give it a thorough service, a bit of a clean up and run it
Old 11-26-2011, 10:06 PM   #15
Bongolia
stop acting
Bongolia's Avatar
Oddometer: 17,196
Lovely frame and swing arm. Looking forward to this thread.
Former Farmer.
G 850 LM Mk II
http://advrider.com/forums/showpost....ostcount=53377
Bongolia is offline   Reply With Quote
Times are GMT -7.   It's 05:53 PM.
