Old 11-27-2011, 11:47 AM   #16
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Been surfing dear old eBay........ and now have some nice calipers to fit
Harrison Billet 6-pots ........also currently tracking a lush little race style rear caliper too :twisted:
Pigford is offline   Reply With Quote
Old 11-27-2011, 12:41 PM   #17
England-Kev
Oddometer: 3,548
Harrison 6 pots... nice
England-Kev is online now   Reply With Quote
Old 11-27-2011, 06:16 PM   #18
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,333
Nice looking project, I'll tag along for the ride.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 11-29-2011, 08:15 AM   #19
Montford
Montford's Avatar
Oddometer: 134
Lookin good!
]Here's a couple of pics from the original 80's Harris brochure for the Magnum 2.
Montford is offline   Reply With Quote
Old 11-29-2011, 11:31 AM   #20
Pigford OP
British
Pigford's Avatar
Oddometer: 931
That sure is nice, indeedy-do
I will need to get a lug welded onto each of the ZZR fork legs to fit the Harrison calipers - I don't know what they were made for, but at least the lower lug is in the right place.
In my stash of parts I have a rear caliper off a Kawasaki ER6N - commuter bike which I'll adapt to fit. I have to wait for a call from Mike at TALON Engineering
( http://www.talon-eng.co.uk/ ) and drop the JMC s/arm off for him to machine and make a sleeve to match the spindle & bearings (20mm & 25mm respectively). I could get the work done for about half the price, but I want this bike to be "spot-on" so an estimate of 250 for a days work is what it'll be Most of the time is setting up the machinery. Luckily a mate is making the new stem for the yokes (triple trees)
I managed to strip the Harrison calipers down and give them a thorough seeing to with brake cleaner, at least that didn't cost me anything!!!!
Old 12-04-2011, 06:46 AM   #21
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Got a phone call Sat morning - from Mike at Talon and he's part way thru' doing the JMC modifications - so should be able to pick it up next week sometime
To match the Harrison Billet-6 calipers I now have...
.... I've found a loverly Harrison rear c/w hanger made for a JMC slotted swingarm !!!!
I've also been a busy boy this morning (skipped church ) and got the engine onto me workbench (OK - so its an old kitchen unit) and took the sump off for a quick looky-see......
So far, so good - all looks OK inside, gears look nice & clean and no visual signs of wear, even on the gear selector forks
Old 12-04-2011, 07:34 AM   #22
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,948
What's all the crap in the screen? Is that normal for those motors?
Old 12-04-2011, 07:50 AM   #23
Montford
Montford's Avatar
Oddometer: 134
Some quality parts coming together there!
Should be a nice build, looking forward to the next installment.
Old 12-04-2011, 08:18 AM   #24
England-Kev
Oddometer: 3,548
Pretty much, my Mk 2 was worse I seem to remember, I shall have a look.....
Old 12-04-2011, 09:24 AM   #25
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Yeah, fairly typical for a 33yr old motor Most of its clutch friction plate and gasket goo. Its one of the only things that gets missed and can lead to oil starvation - but its only a mornings work dropping the sump insitu.
Old 12-04-2011, 10:16 AM   #26
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,068
Carter Pewterschmidt is online now   Reply With Quote
Old 12-04-2011, 11:55 AM   #27
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Here's a photo's of the sump from my Mk.II Sprint bike when I first got it...
..and it was running OK before I stripped it down... and did this to it using the same gearbox & crank :
Old 12-10-2011, 12:02 PM   #28
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Got all me REAR END stuff back from TALON - I had a s/arm pivot sleeve made, a wheel spindle & sleeve and the JMC trimmed down to fit snuggly in the frame :!:
I spent this afternoon getting the wheel lined up spaced centrally.
I had to make some bits myself - the wheel adjusters that fit in the s/arm recess & has the chain tensioner - I used s/s 8mm threaded rod for that.
The Harrison rear brake has a lug that fits under the s/arm and an adjustable cam on top to hold it secure.
The chain run will clear the frame by about 5mm but I haven't checked it in relation to the drive sprox yet
Just awaiting the new stem so I can fit the front end and align the calipers on the forks. I'll need to get an extra lug on each leg to hold the Harrison Billet-6's - this may be a problem as the fork leg alloy can shrink after welding - but my chap will take a look when its time If this is going to be a no-no, I'll make a couple of adaptor plates from 10mm alloy plate.
Old 12-10-2011, 12:30 PM   #29
England-Kev
Oddometer: 3,548
Old 12-11-2011, 09:30 AM   #30
Pigford OP
British
Pigford's Avatar
Oddometer: 931
Bit more fiddling in the garage ....... Trying to get a rough idea of the set-up with the rear shox
Its a Showa off a Ducati 916...
Gonna turn my attention to the motor now - cleaning the sump gasket off - like "sh*te to a blanket"
Also stripped the clutch as the plates where stuck - the motor's been standing for a few years
Times are GMT -7.   It's 10:51 AM.
