Old 02-10-2012, 09:32 AM   #46
Pigford OP
British
Pigford's Avatar
Oddometer: 970
Finally got the phone call - so rushed and collected me bitz....
Ignore the "washed out" colours..... crappy Nokia
Got 2 x busy weekends ahead so won't be much happening until MARCH
Pigford is offline   Reply With Quote
Old 02-11-2012, 06:24 AM   #47
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,094
Looking good man.
Carter Pewterschmidt is offline   Reply With Quote
Old 02-11-2012, 10:15 AM   #48
nanno
Oddometer: 273
Piggy... that Magnum 1 is coming together absolutely lovely!
Let the world change you and you can change the world - Che Guevara
nanno is offline   Reply With Quote
Old 02-15-2012, 09:18 AM   #49
Pigford OP
British
Pigford's Avatar
Oddometer: 970
I finally got round to drilling out the broken/rusted bolt remains & re-tapping - this is to hold the side stand kaboodal
Next is fitting the brakes.... I've gone thru' a few options, this being one that I've now rejected.....
It's a proper MICRON adaptor - converts the forks to use common Nissin 4-pots, etc.
I'm gonna use the lower caliper mount as a direct fit - just need 5mm shaved off the inside to align it - then make a small adaptor lug out of 10mm alloy plate, then JOB DONE I had wanted to get a new lug welded on, but the chap reckons alloy fork sliders will most likely deform/shrink if welded and the fork action may suffer
Old 02-15-2012, 02:26 PM   #50
gearheadE30
gearheadE30's Avatar
Oddometer: 944
holy cow, how do you find all this stuff! I would love a harris frame for my (zuki) GS bits...
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 02-16-2012, 04:44 PM   #51
Oddometer: 1,094
That stuff is more common in Europe because people build sportbikes a lot. Over here most people build choppers and bobbers and other such BS...
Old 02-16-2012, 05:29 PM   #52
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,663
Looking good, is the frame the same color as the rims?
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 02-17-2012, 12:40 AM   #53
Pigford OP
British
Pigford's Avatar
Oddometer: 970
Nearly - but not quite They match better in "real life" - me camera phone is a bit naff
Must admit, there's plenty of quality "bolt-ons" to be had over here - but you American lads have access to the top notch engine kit
Old 11-14-2012, 05:42 AM   #54
anotherguy
anotherguy's Avatar
Oddometer: 6,631
What happened? Wife find out how much yer spendin'?
you don't see luggage racks on a hearse..........act accordingly
Old 11-19-2012, 10:28 AM   #55
Pigford OP
British
Pigford's Avatar
Oddometer: 970
Has been a bit quiet recently - but finally got the front end sorted, Harris clip-on's & brakes all plumbed in, etc......
I've also mounted the fiberglass electrics tray & covered it in hi-tech heat reflective tin stuff....
Next on the list was the rear shock.....
... turns out its an old SHOWA unit - so I sent it off to an old boy who has a few years of experience and he's re-furbished it with a new rod & seals, plus fresh oil, reduced the rebound damping and re-charged with nitrogen (or summink like that). Have to sort the mount to the swingarm now
Old 11-19-2012, 10:49 AM   #56
England-Kev
Oddometer: 3,652
looking good there Mark
England-Kev is online now   Reply With Quote
Old 12-19-2012, 10:39 AM   #57
Pigford OP
British
Pigford's Avatar
Oddometer: 970
At last - the Rolling Chassis is completed (more or less)
The chaps at Faulkner Springs measured the rate of the one me SHOWA had fitted and sure enuff it was a 450lb effort - what normally gets fitted to a Harris Mag 1 I contacted Harris for a bit of advice - and Lester himself called me back for a chat :victory: 450lb is right for a 2:1 leverage ratio, but with the JMC its just over 3:1, so I ordered a 650 lb spring to try...... Anyhow after weeks & weeks of trying to suss out sorting the shock mounting to the JMC - I finally decided to uses some M20 studding, knocked up summink to fit the shock and made an alloy block to fit to the top brace.....
A local bike Engineer cut & welded it for me.... This friggin' JMC has cost me an arm & a leg :
SO, fitted it all together and it's looking OK....
You can see the typical adjustment range as it is at the mo' - but I can lower it another 50mm by taking off the backing nut if needed .....
LOWEST:
HIGHEST:
Also got hold of a proper Harris seat unit......... just gotta decide if I'm gonna use it :shrug
Finally checked on GROUND CLEARANCE for hacking down to the chippy on a Summers evening
Old 12-19-2012, 10:48 AM   #58
England-Kev
Oddometer: 3,652
Nice work Mark, looking forward to seeing it all together.
Old 12-19-2012, 11:46 AM   #59
limeymike
Who Me?
Oddometer: 653
Lookin' good Mark, very nice work.
limeymike is offline   Reply With Quote
Old 12-20-2012, 07:13 AM   #60
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,886
That thing is fookin' sweet!
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'75 Kawi 900 Z1...'90 Kawi ZX11...'03 Kawi ZRX 1200...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Times are GMT -7.   It's 03:23 PM.
