Old 11-21-2011, 07:43 AM   #31
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
Originally Posted by toastmuncher View Post
http://www.ebay.co.uk/itm/Nissan-NAV...item35b18d0807
the wife is not happy with the seating in a kingcab, the back seats dont look good, our lad may end up being a 7 footer. This double, 4 door, cab above results in a 4'6 bed, what use is that, I dont ride a monkey by FFS. If the japs built a single cab with three seats.
The 4door Crew Cab is also available with the long bed... on Nissan Frontiers / Navaras
Never stop exploring
Doc.Snyder is offline   Reply With Quote
Old 11-21-2011, 07:46 AM   #32
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
The defender 130 bed looks similar to the 110 hcpu bed, but the 110 hcpu is longer (almost 2m).
and you have 3 seats in a row on the 110...
Old 06-01-2012, 01:44 AM   #33
toastmuncher OP
I be new round here! Ello
toastmuncher's Avatar
Oddometer: 617
Old thread revival.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180896470317
Just looking at this, dont suppose anyone knows how long the bed is? The guy is away and cannot measure it. I have tried google etc but cannot find the info.
Guzzi 1100 callifornia stone 2003
Guzzi 1100 california hedingham hack 1994
Ducati GT1000 2006
Suzuki GN250 hack, 'the tiddler'
Matchless g3ls 350 1954 and AJS Model 14 250 1961. IBA 40526
toastmuncher is offline   Reply With Quote
Old 06-01-2012, 05:29 AM   #34
W0X0F
W0X0F's Avatar
Oddometer: 35
Specs from Vehix.com: If you can get the VIN go here and it will give you the build sheet.
HTH
1997 Chevrolet S-10 Reg Cab 108.3" WB
Summary
Vehicle Name: Chevrolet S-10
Body Style: Reg Cab 6' Fleetside
Body Code: E63
Brakes
Brake Type: Power
Brake ABS System: 4-Wheel
Disc - Front (Yes or No): Yes
Front Brake Rotor Diam x Thickness (in): 10.5 x 1.03
Drum - Rear (Yes or No): Yes
Rear Drum Diam x Width (in): 9.5 x 2.0
Cargo Area Dimensions
Cargo Box Length @ Floor (in): 72.8
Cargo Box Width @ Top, Rear (in): 54.6
Cargo Box Width @ Floor (in): 54.9
Cargo Box Width @ Wheelhousings (in): 40.3
Cargo Box (Area) Height (in): 17.1
Tailgate Width (in): 54.9
Cargo Volume (ft³): 39.4
Cooling System
Total Cooling System Capacity (qts): 11.5
Electrical
Cold Cranking Amps @ 0° F (Primary): 525
Maximum Alternator Capacity (amps): 100
Maximum Alternator Watts: 1200
Engine
Engine Order Code: LN2
Engine Type: Gas L4
Displacement: 2.2L/133
Fuel System: SFI
SAE Net Horsepower @ RPM: 118 @ 5200
SAE Net Torque @ RPM: 130 @ 2800
Exterior Dimensions
Wheelbase (in): 108.3
Length, Overall w/o rear bumper (in): 189.0
Width, Max w/o mirrors (in): 67.9
Height, Overall (in): 63.2
Overhang, Front (in): 34.8
Overhang, Rear w/o bumper (in): 46.0
Front Bumper to Back of Cab (in): 105.6
Cab to Axle (in): 37.4
Ground to Top of Load Floor (in): 29.0
Ground Clearance, Front (in): 9.1
Ground Clearance, Rear (in): 7.2
Frame
Frame Type: Ladder
Fuel Tank
Fuel Tank Capacity, Approx (gal): 19
Fuel Tank Location: Inboard LH Frame
Interior Dimensions
Passenger Capacity: 3
Front Head Room (in): 39.5
Front Leg Room (in): 42.4
Front Shoulder Room (in): 57.2
Front Hip Room (in): 52.0
Mileage
EPA Fuel Economy Est - City (MPG): 23
EPA Fuel Economy Est - Hwy (MPG): 30
Steering
Steering Type: Power
Steering Ratio (:1), On Center: 15
Steering Ratio (:1), At Lock: 13
Turning Diameter - Curb to Curb (ft): 36.9
Turning Diameter - Wall to Wall (ft): 38.9
Suspension
Suspension Type - Front: Indep Coil Spring
Suspension Type - Rear: 2-Stage Multi-Leaf
Spring Capacity - Front (lbs): 2500
Spring Capacity - Rear (lbs): 2300
Axle Type - Rear: Semi-Floating
Axle Capacity - Front (lbs): 2500
Axle Capacity - Rear (lbs): 2900
Axle Ratio (:1) - Rear: 3.73
Shock Absorber Diameter - Front (mm): 32
Shock Absorber Diameter - Rear (mm): 32
Stabilizer Bar Diameter - Front (in): 0.98
Tires
Front Tire Order Code: QCE
Rear Tire Order Code: QCE
Front Tire Size: P205/75R15
Rear Tire Size: P205/75R15
Spare Tire Size: T155/90D16
Front Tire Capacity (lbs): 1452
Rear Tire Capacity (lbs): 1452
Spare Tire Capacity (lbs): 1453
Revolutions/Mile @ 45 mph - Front: 768
Revolutions/Mile @ 45 mph - Rear: 768
Trailering
Dead Weight Hitch - Max Trailer Wt. (lbs): 2000
Dead Weight Hitch - Max Tongue Wt. (lbs): 200
Wt Distributing Hitch - Max Trailer Wt. (lbs): 2000
Wt Distributing Hitch - Max Tongue Wt. (lbs): 750
Fifth Wheel Hitch - Max Trailer Wt. (lbs): 2000
Transmission
Drivetrain: Rear Wheel Drive
Trans Order Code: MW2
Trans Type: 5
Trans Description Cont.: Manual w/OD
First Gear Ratio (:1): 3.94
Second Gear Ratio (:1): 2.37
Third Gear Ratio (:1): 1.49
Fourth Gear Ratio (:1): 1.00
Fifth Gear Ratio (:1): 0.83
Reverse Ratio (:1): 3.65
Clutch Size (in): 9.13
Weight Information
Gross Axle Wt Rating - Front (lbs): 2500
Gross Axle Wt Rating - Rear (lbs): 2300
Curb Weight - Front (lbs): 1735
Curb Weight - Rear (lbs): 1294
Gross Vehicle Weight Rating Cap (lbs): 4200
Gross Combined Wt Rating (lbs): 5000
Wheels
Front Wheel Size (in): 15 x 7
Rear Wheel Size (in): 15 x 7
Spare Wheel Size (in): 16 x 4
Front Wheel Material: Steel
Rear Wheel Material: Steel
Spare Wheel Material: Steel
W0X0F is offline   Reply With Quote
Old 06-01-2012, 05:38 AM   #35
seriousracer
be a man dodge tree bark
seriousracer's Avatar
Location: i am not f***ng stupid,but i used too. niles mi.
Oddometer: 7,344
Send a message via AIM to seriousracer
racing is not real till your fighting for the line into the next blind corner,real roads, real trees, real fast, real men rally.
be a man dodge tree bark!
We’ve said it before, but it bears repeating; the GS handles in ways a two-story building was never meant to.
Taking collections for Faye Butler Training please spare some change.
www.kmotorwerks.com
Remember red and yellow make orange.so to think orange is better means you have to use two steps to get there.
________
seriousracer screwed with this post 06-01-2012 at 07:03 AM Reason: I was wrong
seriousracer is offline   Reply With Quote
Old 06-01-2012, 05:48 AM   #36
KeithinSC
KeithinSC's Avatar
Oddometer: 666
Definitely a shortbed. The stepside S10 was only a shortbed. Narrower also than a regular bed. I had a fleetside shortbed, about useless for a bike, well maybe a Scwhinn!
If you see an extended cab S10, that will also be a shortbed. Longbeds only available with a regular cab.
What about a Hilux? Cabs too small?
KeithinSC is offline   Reply With Quote
Old 06-01-2012, 01:43 PM   #37
toastmuncher OP
Oddometer: 617
Very quick helpfull info, thanks all. He says its 72'' by 40 within the wheelarches. a squeeze for two big bikes I guess, seems pretty frugal, by yank standards.
Ducati GT1000 2006
Old 06-01-2012, 07:24 PM   #38
KeithinSC
KeithinSC's Avatar
Oddometer: 666
You could get two MX bikes in that S10, but never two Guzzis. Unless you dont mind a few dents!
Other than the better gas mileage, I'd avoid the S10. ( I had one and loved it). I could never haul a bike in it, I'd borrow a trailer instead. CX500, Shadow 750 and a slew of others, the bed was just too short. If a trailer is not an option, a fullsize with a long bed would be my choice. The Dodge you showed would work fine, as would the Chevy or the Ford.
Not knowing how common repair parts are in your part of the world (brake pads, shock absorbers/dampers, etc) you might want to keep that in mind when you pick a brand. I can go into any auto parts store and get a brake disc for my Chevy off the shelf, but I'd have some trouble getting one for a Jensen Interceptor
Look each one over and see if it was maintained well. Any of the choices you mentioned have had examples run 300000+ miles, and many have died before 50,000. All depends on the driver and maintenance the truck had.
Old 06-02-2012, 07:41 AM   #39
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 6,103
Don't supposed you've thought of getting a Transit Van, they made 1 million variations throughout the years.
I used to be indecisive. Now I'm not so sure.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 06-02-2012, 08:30 AM   #40
toastmuncher OP
Oddometer: 617
The thought has crossed my mind. I am afraid I would be categorised as a gypsy should I get one of THOSE, and they get a pretty bad press over here!! A pickup also has a VERY high bed which will then need a VERY long ramp.
I fancy something different and a yank pickup has only been off the list due to fuel costs here in blighty. Jap stuff has either insufficient seating or dumpy beds. This C10 is really cool.
Ducati GT1000 2006
Old 06-02-2012, 08:40 AM   #41
vtwin
vtwin's Avatar
Oddometer: 6,103
Jeremy doesn't think too highly of american trucks.
unknown
Old 06-02-2012, 09:43 AM   #42
McB
Joe 40 ouncer
McB's Avatar
Oddometer: 15,223
Glad you didn't go for the Dodge V-6. I had a '98 that got 11 mpg on a good day and wouldn't pull a fart up a molehill.
McB is offline   Reply With Quote
Old 06-03-2012, 09:20 AM   #43
toastmuncher OP
Oddometer: 617
z71? thirsty?
http://www.ebay.co.uk/itm/CHEVROLET-...item19d0bd8d72
Ducati GT1000 2006
Old 06-03-2012, 10:18 AM   #44
mark883
Holding up Michoagán
Oddometer: 1,387
4wd are always more thirsty, even if driven in 2wd.
Doesn't say what size engine, but the small block Chevys are bullet-proof. Driven nicely, I bet you might be able to see close to 20mpg (your gallons) from that truck- if it doesn't have a low geared rear-end, and it has the smaller V8.
If the trans is the ZF 5 speed stick, that could be expensive if it blows up. I know, because I killed two or three behind a 6.5L diesel - but pulling a 37 foot trailer. So light duty work may be Ok. That is a short bed (6 footer) as well. Many a bike has been hauled with the rear wheel on a tailgate before, however. Shorter bed might be better for your type of streets.
200k miles can be routinely put on this era of Chevy pickup trucks, with proper maintenance.
mark883 is offline   Reply With Quote
Old 06-03-2012, 12:02 PM   #45
toastmuncher OP
Oddometer: 617
It says 5000cc. I am not sure what that equates to in cubic inches, I guess 5l is about 290CU. 20 IS NOT ENOUGH, and there I was about to HIT THE BUTTON. I really like the chevrolet 4 pot I posted but the aucton has a while to run.
Ducati GT1000 2006
Thread Tools
Times are GMT -7.   It's 09:55 PM.
