03-19-2012, 09:53 PM
#1501 | |
Oddometer: 12
03-19-2012, 09:56 PM
#1502 |
Wannabe
Oddometer: 930
My replacement doohickey kit came from Happy Trails.
It was the EagleMike kit. You can order direct from EagleMike. http://www.eaglemike.com/ |
03-19-2012, 10:08 PM
#1503 | |
Oddometer: 256
2011 KLR650 2008 VFR800 |
03-19-2012, 10:38 PM
#1504 | |
Oddometer: 12
The holes looked pretty crusty. If a screw holds don't touch them. If not try a heli-coil. My original 87 klr was on it's third tank because the rear mount broke and it would leak gas. It had 16000 on it when I sold it. I brazed the mounting bracket and to my knowledge it never broke again. If I wanted to preserve my tank I would get a plastic one and save the original. |
03-19-2012, 10:42 PM
#1505 |
DualSport Crazy !!
Oddometer: 825
Very many, me included. It is rare it causes catastrophic failure, but it does happen. Is it worth risking a total engine lock up at 60 MPH? Easy, cheap job. Just do the doo.
"Where ever you are, there you go..." |
03-19-2012, 11:27 PM
#1506 |
Scott
Oddometer: 778
Did mine ! She's a 2009
Doohicki was fine at 5000miles but the spring was just sitting there not doing a dam thing ! Your choice . To me, I ride all over - It's cheep Insurence . |
03-20-2012, 12:25 AM
#1507 |
AKA Woodman
Oddometer: 462
my doo spring was broken and just hanging there at about 18000kmsish.
Was quiet etc but the internet said i should replace it so of course i did because it was on the internet.
03-20-2012, 06:59 AM
#1508 |
KLRider
Oddometer: 41
Re: Checking or replacing the Doo hickey
I ordered a kit with the torsion spring from Eagle Mike to have on hand. I checked mine at 1,700 miles while at a tech day with Lt. Dan at GSM Moto Rent. I adjusted it. After that first adjustment, the spring was slack and would not have adjusted anymore. Instead of pulling it down later, I went ahead and replaced it with the one from E.M. Glad I did.
2010 Ebony KLR 650
03-20-2012, 07:31 AM
#1509 | |
Oddometer: 338
You're tank in my opinion is in great shape. Personally, I'd still pick up the POR15 product. As for threads...yes, run a tap through it. For drying I tape a hair dryer to the inlet. The KLR tank has some deep recesses that take a while to dry out. Good luck! |
03-20-2012, 08:25 AM
#1510 | |
Wannabe
Oddometer: 930
Yeah. The tank is in great shape compared to most, if not all of the rusty tanks I saw on YouTube videos. Can I buy POR15 at a local store? Or is it something I have to order off the net? I want to protect this tank for future use by me or someone else. After all, aside from a few scratches, this tank is in great shape. No dents or dings anywhere. If it wasn't for the scratches, it would look new. Even the paint is nice on it. When I pull the tank out of the tub later, I'm going to see how the threads are for the petcock. If they need to be tapped, I'll go buy a one size bigger tap, and new screws for it. |
03-20-2012, 08:41 AM
#1511 |
Occasional Venturing
Oddometer: 659
03-20-2012, 09:19 AM
#1512 | |
Oddometer: 338
Why tap to larger size? I'd re-tap current threads regardless. Once done you can quickly determine their condition. In my experience the treads will be just fine. |
03-20-2012, 09:27 AM
#1513 |
Oddometer: 175
When I used Valvoline 20w-50 in my '11 it would use/burn oil like crazy (with around 3K miles on the bike). After and oil change I could ride a hundred miles or so i'd have to add so I didn't plan on getting to far from some place I could buy oil. Pissed off I was! Switched to Rotella T and haven't had issues since. I may have to add just a little at the 1200-1500 mile mark with aggressive riding but nothing like the Valvoline. Next oil change is coming due and thinking on giving the plain jane Castrol GTX 10w-40 a try.
03-20-2012, 09:46 AM
#1514 |
Has anyone actually had a problem with the stock Doo hickey??
Yes...But, when I had my doohickey side blow up it was caused by the heavy counterweights wearing out the bearings. I had done the upgrade. If I went into this topic any further, I might start criticizing another forum. |
03-20-2012, 09:55 AM
#1515 |
KLR650-2009
Oddometer: 1,070
+1 same with mine
Did mine at 12K and had the same situation, no tension at all on the spring.
No, I don't know where that road goes, let's find out! redog1 |
