Old 03-20-2012, 09:59 AM   #1516
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,825
I've tried several different oils...
Originally Posted by Nitro1970 View Post
When I used Valvoline 20w-50 in my '11 it would use/burn oil like crazy (with around 3K miles on the bike). After and oil change I could ride a hundred miles or so i'd have to add so I didn't plan on getting to far from some place I could buy oil. Pissed off I was! Switched to Rotella T and haven't had issues since. I may have to add just a little at the 1200-1500 mile mark with aggressive riding but nothing like the Valvoline. Next oil change is coming due and thinking on giving the plain jane Castrol GTX 10w-40 a try.
and have the best luck with plain ol' Castrol GTX 10w-40. Change my oil every 2500 miles and don't add any in between unless I'm riding hard, then about 1/2 qt used in 2500 miles.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 03-20-2012, 10:15 AM   #1517
phideaux
phideaux's Avatar
Oddometer: 3,360
Originally Posted by CA Stu View Post
Guys, knock it off.
From the rules: "12. No forum wars. If you have beefs with inmates in other forums, this isn't the place to air them out."
This is not the place for that drama, please let it go.
CA Stu, Thumpers Mod
THANKS STU!
Fido
Iron Butt Association No. 22913
Mrs. Phideaux to her octogenarian friend when the granny wants to know if she can sit on one of my bikes:
"It's Okay, they only fall over when HE'S on them."
North GA Tag-O-Rama Map
Georgia Tag-O-Rama Map
phideaux is offline   Reply With Quote
Old 03-20-2012, 10:51 AM   #1518
Thanantos
Ride hard.
Thanantos's Avatar
Oddometer: 3,700
Enough guys. This could go on forever.
The ADV mods have enough to deal with on this awesome, free (and adfree) site.
Let's not make it harder on them.
2013 V-Strom
Thanantos is offline   Reply With Quote
Old 03-20-2012, 10:58 AM   #1519
CA Stu
CA Stu's Avatar
Oddometer: 48,030
Originally Posted by DirtyDog View Post
It's the touring with heavy luggage/ass/passenger that is gonna stress these parts. Offroad riding (unless you are doing HUGE jumps and crashing ALOT) is not likely to do near the damage to your subframe or hardware as touring. If you read the manual and see the manufacturer's suggested weight limits, you'd probably agree that most touring KLR riders are on overburdened bikes.
From experience, I speak.
I'm on my 3rd subframe in 70,000 miles. Failures were not due to hardware.
Never broken an upgraded bolt and I have NOT done the drill-through mod. My bolts are from ACE.
As long as you keep the upper bolts tight you probably won't ever break them regardless.
I am willing to bet that If everyone yanked the seat off and checked them, at least a few of them could use a turn or two to crank them down.
BTW, I did the drill-through upper subframe mod (on a couple of frames now), and I don't know if it's all in my head or what, but the bike just feels more solid. I reckon it's a good upgrade.
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 03-20-2012, 11:42 AM   #1520
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,165
Yeah, my seat is removed frequently... I guess I probably check them fairly often.
There's a joke in there about "in your head" and loose screws, but I'll resist.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is online now   Reply With Quote
Old 03-20-2012, 12:55 PM   #1521
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,487
Originally Posted by Aprilia View Post
My local Auto Paint supplier keeps the kit in stock but plenty offer it online. Even Amazon carries it... POR15 KIT
Why tap to larger size? I'd re-tap current threads regardless. Once done you can quickly determine their condition. In my experience the treads will be just fine.
I figured I would have to tap to a larger size because of the rust making the threads smaller.
I guess when I pull it out and look at it, I'll see if the threads need to be tapped or not.
Then I'll try re-tapping the same size.
If that doesn't work, then I can move up a size I suppose.
If I'm able to keep the same screws and threads, that's a bonus!
Thanks again Aprilia!!!
RandoCommando is offline   Reply With Quote
Old 03-21-2012, 05:50 AM   #1522
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,952
Can you give us more information on these breakages- the sub frame being that part which bolts onto and rear of the tank ? Or, pics of where the breaks occur?
I have not seen breaks on the KLR 'frame' other than those just before the top engine mount and the front down tube where it splits into two under the engine. Those two areas I can believe and are due to the frame flexing there - the cause of the instability under load and at speed. Loaded with panniers and standing still that 'mid frame' flex can be replicated. Those breaks are on heavily loaded bikes on long rides.
Tsotsie is online now   Reply With Quote
Old 03-21-2012, 06:40 AM   #1523
Kawidad
Kawidad's Avatar
Oddometer: 5,069
The project KLR I now own did just that for the PO. I think its due to excessive loading at that specific point. There are a lot of different forces at work on the backbone of the bike at that one spot. I had a professional welder weld up the crack and then weld a plate onto the top of the frame. IMO, that's what Kawasaki should have done at the factory and would be a must do if I were planning on long trip with heavy loads.
Also, on my bike the DOO cut loose on the PO at around 12k miles. The DOO itself broke and took out parts of the counter balancer assembly and the cam chain assembly. Why it cut loose is anybody's guess since the PO was a total douche when it came to motorcycle care and maintenance.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 03-21-2012, 09:30 AM   #1524
jonyfi
21st century adventurer
jonyfi's Avatar
Oddometer: 428
[QUOTE=Kawidad;18268078]The project KLR I now own did just that for the PO. I think its due to excessive loading at that specific point. There are a lot of different forces at work on the backbone of the bike at that one spot. I had a professional welder weld up the crack and then weld a plate onto the top of the frame. IMO, that's what Kawasaki should have done at the factory and would be a must do if I were planning on long trip with heavy loads.
Hey Kawidad, another picture request...can you post any pics on the reinforcments you had welded to the frame. I need to do a little more research on where commom failure areas are (while touring with a heavy load)...I have an friend who is a steele worker/welder and I might be up for having him do some reinforcing...
jonyfi is offline   Reply With Quote
Old 03-21-2012, 09:54 AM   #1525
nakedwaterskier
nakedwaterskier's Avatar
Oddometer: 263
I have an extra low mile US Marine frame. It came with the like new engine and I don't need the frame.
It is painted green. Anybody want it?
$75
nakedwaterskier is offline   Reply With Quote
Old 03-21-2012, 06:15 PM   #1526
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,674
El Cheapo Tool Tubes
Remember these? The Tractor docs tube that used to be available at Tractor Supply for a coupla bucks? Some Jocko got hold of a case and is selling them for a twenty on line. That's nuts.
I bought three of them for under $25 shipped. I gave one to my manic mechanic for a docs holder on his hill-climbing rig.
Nice folks, very fast service and cheap tubes. Big gasket, long threads, and that stupid weep hole that you need to dab some silicone or Shoe Goo into before use.
They are found here:
http://www.ebay.com/itm/110833323557...8#ht_500wt_969
Looks like this:
Fits a liter fuel bottle or a tool roll. The shipping seems high, but they reduce it a lot for bulk orders. As I said, three tubes cost me under $25 USD to my door.
Trust this helps.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 03-21-2012, 06:29 PM   #1527
thomas.tc.young
Oddometer: 866
Does anyone know the size of the bypass hose for thermo-bob. I cut mine a little too short and need to replace. I figure I can go to napa and pick it up. I guess I need the o/d and the I/d.
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 03-21-2012, 07:03 PM   #1528
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,674
Cut a snippet off and I'm sure they will match it. Nothin' beats original dimensions..
The Rock 2013 RR
Old 03-21-2012, 07:27 PM   #1529
thomas.tc.young
Oddometer: 866
It's a catch 22 I need the bike to get to the auto store. Maybe I have the scraps though...
2013 Ninja 650
1987 XR600R
2001 TTR-125L
Old 03-21-2012, 07:40 PM   #1530
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,165
Like I vaguely implied, my 2 previous subframe failures weren't due to frame-to-subframe hardware breakage. One (the most recent) was due to a welding modification I made to the mounting points when the M6 bolts stripped out. I could have re-tapped them, but went a different direction.
But the original was an outright breakage. My tailbag came loose while riding in the desert. The bag (still partially tethered to my rack) was sucked in with the rear tire and snapped the frame.
I have also cracked the main frame on the spine right in front of the top subframe attachment area. Ran a bead over this one. Been riding on it ever since.
-DustyRags
Times are GMT -7.   It's 05:29 PM.
