Old 04-03-2012, 04:07 AM   #1741
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
Originally Posted by BERZERKOWITZ View Post
Gentlemen, get rid of those sucky KLR fuses or this could be you!
LOL
Great picture. Sorry for your issue.
Kawasaki doesn't make the fuses though.
I've blown a couple, but that's because I tried using too much stuff.
The fuses saved my harness.
I've simply replaced the fuses.
What exactly caused your issue?
Are your fuses constantly blowing?
If so, maybe you have a short and need to start checking the harness for it.
Or did you fry the harness?
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 04-03-2012, 04:09 AM   #1742
RandoCommando
Wannabe
Oddometer: 1,394
Originally Posted by NHMatt View Post
I started a blog about my first time at re-building my 08's engine. http://myklr.wordpress.com/ It will be all about how I am doing it and what kind of problems I run into along the way. If you want, check it out. If not, then don't. Thank's.
A 500 pound rack???
LOL
Might want to edit that.
And change balk to back?
Oh. And the dates on your pictures are older than your bike. Heh heh
MySPOT
RandoCommando screwed with this post 04-03-2012 at 04:14 AM
Old 04-03-2012, 09:15 AM   #1743
BERZERKOWITZ
BERZERKOWITZ's Avatar
Oddometer: 479
Originally Posted by RandoCommando View Post
LOL
For the first time since I bought the bike, I decided to open the fuse box. Immediately after witnessing that abortion I ordered a blade fuse upgrade kit. You know how it goes. When you change the oil on a car with 200k miles that was probably never changed, yer fooked. The last ride I took was in the rain, I'm guessing water got in someplace. The new kit is in and everything works again, so we'll see.
BERZERKOWITZ is offline   Reply With Quote
Old 04-03-2012, 10:36 AM   #1744
nakedwaterskier
nakedwaterskier's Avatar
Oddometer: 263
Everybody upgrades the headlight fuse to blade AND to 15 amps from 10.
There are also automatically resetting circuit breakers avail at auto parts stores.
Then, you don't have to ever touch the fuses...though you would have to figure out what is
causing it--with luck after you make it home.
nakedwaterskier is offline   Reply With Quote
Old 04-03-2012, 01:54 PM   #1745
NHMatt
NHMatt's Avatar
Oddometer: 271
A 500 pound rack???
LOL
That was my lame attempt at sarcasm. Yea I never set the damn date on my camera. I think that's a sign of getting old. Like the old clock on the VCR thing in the 80's.
Sent from my BlackBerry 9650 using Tapatalk
Check out my KLR650 engine rebuild @ http://myklr.wordpress.com/
NHMatt is offline   Reply With Quote
Old 04-03-2012, 08:26 PM   #1746
Mile Maker
Mile Maker's Avatar
Location: Southern Alberta, only 150 km to a curvy road
Oddometer: 100
Originally Posted by lgottler View Post
New KLR owner. First bike with water cooling.
Anyways, took it for a 30 minute ride tonight temps in 50's and temp gauge reads about 1/4 above C. Got home and let it idle for about 2 minutes while I walked it into the garage and temps rose to the middle of the dial and the fan kicked on. I left it idling to see if it would over heat, but it just stayed in the middle and the fan kicked on twice more. It also kicked on after the bike was turned off.
Is it normal to jump so fast to hot from normal riding temps? Coolant levels were good.
Also, few more ?'s.
1) If I can start it in gear with clutch pulled in with the kick stand down or up, has the safety switch mod been done? Or does it have something to do with the clutch lever being let out?
2) Adjusting the foot brake until it is only about 1/16" away from hitting the engine and the pedal is still not in line with the foot pegs....could I have aftermarket foot pegs? Mine are dark grey wide with steel serrations, no rubber. Very annoying position of pedal, any ideas how I can get it adjusted up better besides trying to bend it out away from the engine cover?
3) Gear shifter, I'm going to weld an extension on it about 1" longer. Any issues with that?
Lucas
KLRs use a sucky cooling system. They came from factory with a relatively cool thermostat. 160 deg. The fan doesn't kick on till way hotter, I don't remember the temp off the top of my head, but i'm guessing around 210?
Sounds like you have aftermarket foot pegs. There are a few of companies that make longer shifters. The IMS one looks like a quality made piece, but if you want to extend the stock one, i don't see why it wouldn't work.
Mile Maker is offline   Reply With Quote
Old 04-04-2012, 08:31 AM   #1747
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 4,971
My bike seems to run hot. 70-75 on the interstate and its at the half way, slightly higher. Stop for a few minutes in traffic and climbes to just off red. Take off and it goes back to where it was before. New fan last summer when the original died. I'm wondering if the original radiator isn't somewhat clogged being as old as it is.
I know myself and one other person who had an issue with getting the bolt tight enough on the IMS shifter. Even with loctite mine would eventually "wobble" on the shift mechanism. Don't know if the bolt stretched or what but I got a longer bolt and put a nut on it to tighten it up and so far after 150 miles all is well.
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is offline   Reply With Quote
Old 04-04-2012, 09:08 AM   #1748
XDragRacer
Oddometer: 3,042
YMMV, CH, but . . . as long as the coolant temperature remains within safe limits, What? ME worrry?
Radiator flush wouldn't hurt, but--as long as your fan is cycling and you stay out of the red . . . no problemo, AFAIK.
XDragRacer is offline   Reply With Quote
Old 04-04-2012, 09:27 AM   #1749
Chicken Helmet
I'm A Stumper™
Oddometer: 4,971
Kind of the approach I have been taking but I "seem" to remember it reading lower when I first got it a couple years ago. I checked the w/p impeller, replaced the radiator cap and topped it off along with purging the system. I think i'll pull the radiator, have it flushed and replace the hoses that look like they are fresh from 1988.
Old 04-04-2012, 10:39 AM   #1750
nakedwaterskier
Oddometer: 263
The IMS shifter is softer metal than the stock shift lever. You have to take it off a few times a year and sand between the contact points.
You are better off welding a washer on the stock shift lever(to keep it from breaking the stator side case cover in case
of a wipeout on that side)
Old 04-04-2012, 10:41 AM   #1751
nakedwaterskier
Oddometer: 263
The impeller shaft corrodes after 30K miles even with good strong coolant. It cleans up pretty easily. But, you have to pull the side case to do the water pump seals.
Follow Marknet's instructions carefully.
Old 04-04-2012, 01:11 PM   #1752
n9udl
n9udl's Avatar
Oddometer: 398
Mini KLR Tech Day in SW Wisconsin
http://www.advrider.com/forums/showp...&postcount=911
"A Chupacabra? But there isn't a goat to feed on for miles!" - Dib
"Better a smart-ass than a dumb-ass, if you have to choose." - Me
Check out the cool Tent Space thread: http://advrider.com/forums/showthread.php?t=149585
n9udl is offline   Reply With Quote
Old 04-04-2012, 02:01 PM   #1753
SeanPNW
Water Bear
SeanPNW's Avatar
Oddometer: 474
KLR Tank
Originally Posted by 1 lunger View Post
What color is the tank and how much do you want? Thanks
I am here: http://tapatalk.com/map.php?m2jy03
Life is good!
I've got a fair amount of parts off my '04 KLR that I'm looking to sell. A tank being one of them. Tank is pristine, no rust, no scratches, etc. I used the petcock though for my IMS tank.
If you are interested let me know.
"In life sometimes you just need to value adventure above security and comfort."
No-Moto-Boundaries, Tanning A Ginger Tip-to-Tip, '04 KLR 688
SeanPNW is offline   Reply With Quote
Old 04-04-2012, 08:01 PM   #1754
FixerDave
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 386
My bike seems to run hot. 70-75 on the interstate and its at the half way, slightly higher. Stop for a few minutes in traffic and climbes to just off red. Take off and it goes back to where it was before. New fan last summer when the original died. I'm wondering if the original radiator isn't somewhat clogged being as old as it is....
I won't take credit for this diagnostic advice... it was a response by broncobowsher to my queries here: http://www.advrider.com/forums/showthread.php?t=767986
The key is that the thermostat is at the top and the fan sensor is at the bottom. Thus, if it says hot but the fan is not on, then you have coolant flow problems - the water coming out of the rad is cool but there's not enough of it because it's not flowing fast enough. That means plugged passages, impeller, thermostat, etc.. If it says hot and the fan is on, then hot water is flowing quickly through the radiator but you are generating too much heat or the rad is not cooling enough. That means fuel mixture etc., or, OR... as in my case (so far, I'll know for sure this weekend when I get my first ride in) the radiator is losing efficiency. My radiator looked near perfect but, again according to broncobowsher, the solder holding the fins on can degrade with age and lose proper contact with the radiator tubes. I replaced my radiator with a Chinese aluminium unit and the bike idled for near 15 minutes before getting hot enough to turn the fan on. It's looking good... can't wait to confirm.
Hope this helps,
David...
FixerDave screwed with this post 04-04-2012 at 08:07 PM
FixerDave is offline   Reply With Quote
Old 04-04-2012, 08:53 PM   #1755
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,213
Originally Posted by two trackin fool View Post
I'm sure this has been asked but ,
After a chain adjment and with a pileon (daughter) I notice the chain seemed a bit tight with us both sitting on the bike.
If I loosen it just alittle it seems to loose.
What do you guy's use to regulate the chain with the bike on the side stand - how do YOU check it?
My dirt bike mentality is way to loose .
Check your owners manual.
When the suspension is compressed, and the axle, swingarm pivot, and countershaft all align, your chain slack can be zero. The owners manual will give the allowable slop completely unloaded, or on the stand.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Times are GMT -7.   It's 07:15 PM.
