Old 05-08-2012, 05:14 AM   #2266
kingcobra65
kingcobra65's Avatar
Oddometer: 34
Sharkfin rotor guard
Thinking of picking up a Sharkfin for a bit of rough terrain I will get into this summer. I'd appreciate any insight.
"HOKA HEY"!
kingcobra65 is offline   Reply With Quote
Old 05-08-2012, 04:52 PM   #2267
nakedwaterskier
nakedwaterskier's Avatar
Oddometer: 263
sharkfin for rear master shouldn't be on the top of your list
I would worry about catching rear brake pedal on a rock more.
nakedwaterskier is offline   Reply With Quote
Old 05-08-2012, 08:29 PM   #2268
Hatley Rocket
Hatley Rocket's Avatar
Oddometer: 330
Pro-Taper ATV high bars
Hey,
For those of you whom have added the pro-taper se atv high bar, how much higher is it than the KLR stock? I would like more height for standing up while riding. Do they make a difference? I'm not worried about adding barkbusters, just the bars, and looking for more height. Thanks for your input.
Second thought, I was going to order some heavy duty tubes for my KLR also, do you need to order a size smaller to fit the tube, or the same size you would for a normal tube?
T
Hatley Rocket screwed with this post 05-08-2012 at 08:31 PM Reason: Second thoughts
Hatley Rocket is offline   Reply With Quote
Old 05-09-2012, 04:05 AM   #2269
kingcobra65
Oddometer: 34
Made all the usual mods over the last couple years. Have a chance to p/u a used sharkfin cheap and was wonderin' if it's worth it.
"HOKA HEY"!
Old 05-09-2012, 04:19 AM   #2270
By-tor
remember 6/6/44
By-tor's Avatar
Oddometer: 256
Originally Posted by Hatley Rocket View Post
Hey,
T
I almost got the ATV high bars but went with the Renthal Jimmy Buttons. I wish that I got the ATV highs now. The Buttons are not much higher than stock, plus I had to add risers. I am still not happy with the bars.
Please let me know how the ATV high bars are if you get them.
Thanks.
Eric
By-tor is offline   Reply With Quote
Old 05-09-2012, 04:57 AM   #2271
CA Stu
CA Stu's Avatar
Oddometer: 47,475
I have never seen a damaged rear rotor on a KLR, but if it's cheap insurance, why not?
Plus, they look cool.
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 05-09-2012, 04:57 AM   #2272
CA Stu
CA Stu's Avatar
Oddometer: 47,475
T
Same size
Old 05-09-2012, 08:15 AM   #2273
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,210
Need some help with tube routing
Hey all,
Just getting my bike buttoned back up after doing a ton of maintenance and needed things, noticed a drain/vent tube that is not connected. I read that there are 3 lines that should run down through the swing arm retainer, this one makes a fourth.
The 3 lines references are:
battery overflow
airbox drain with catch bottle and cap
gas tank cap vent
All three of the above are accounted for and connected. This mysterious 4th line runs through a hole in the lower part of the fender liner, and when I found it, it was routed behind the sidestand switch cover and was simply lining next to the carb. It's a big line, about the same size as the airbox breather, too big to be any sort of carb line.
Any ideas? I can't find a vacuum hose routing diagram and poking around on various fiches is not netting any results.
sandalscout is offline   Reply With Quote
Old 05-09-2012, 08:18 AM   #2274
NHMatt
NHMatt's Avatar
Oddometer: 271
Originally Posted by sandalscout View Post
Hey all,
battery overflow
gas tank cap vent
Think its the drain hose for the float bowl on the carb.
Sent from my BlackBerry 9650 using Tapatalk
Check out my KLR650 engine rebuild @ http://myklr.wordpress.com/
NHMatt is offline   Reply With Quote
Old 05-09-2012, 08:56 AM   #2275
sandalscout
blah blah blah
Oddometer: 2,210
You could be right, the float bowl does not have a tube on it. It just seems far too big for it. I think it will fit, but the thickness of the hose is much more than I'm used to seeing on a carb. I'll test it out and report back.
Old 05-09-2012, 10:15 AM   #2276
CA Stu
CA Stu's Avatar
Oddometer: 47,475
CA bike?
Could be part of the fuel evaporative system, black hose?
Edit: here's a pic of the carb showing vent lines and the vacuum line to the petcock...
Old 05-09-2012, 10:31 AM   #2277
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,209
Hey,
T
Pretty similar to stock. I put the Eagle Mike (tallest size) bar risers on. Very nice, and a great fit both seated and standing (I'm 6 feet).
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned: '91 Honda Gold Wing with sidecar, '92 Kawi KLR650 with Enduro sidecar, '94 KLR650, KL250 Super Sherpa.
GreatWhiteNorth is online now   Reply With Quote
Old 05-09-2012, 11:26 AM   #2278
sandalscout
blah blah blah
Oddometer: 2,210
Originally Posted by CA Stu View Post
CA bike?
Non-CA bike, but the hose is black. Pretty sure the carb vents/drains, etc are all there (looked right when performing the T-Mod) except the bowl drain. Will have to dig in a little bit more later. I think that the key to verification on my part is that it's only hose that runs THROUGH the inner fender, there is a hole in the lip of the fender that retains it.
Old 05-09-2012, 11:49 AM   #2279
CA Stu
CA Stu's Avatar
Oddometer: 47,475
If I was at home I'd run out to the shop and look at one of my parts bikes and tell you....
If you don't have an answer sooner, this evening you will.
Old 05-09-2012, 12:00 PM   #2280
sandalscout
blah blah blah
Oddometer: 2,210
You rock, thanks!
Times are GMT -7.   It's 05:33 AM.
