Old 11-30-2011, 05:39 PM   #256
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,431
Pannier Rack
I've never noticed a pannier rack like this one yet. Anyone have one? Worth it? I'm assuming not necessarily since a HT side rack can be had from 200 to 270 (depending on model).
http://boise.craigslist.org/mcy/2727667496.html
IDRIDR screwed with this post 11-30-2011 at 05:44 PM
IDRIDR is online now   Reply With Quote
Old 11-30-2011, 05:54 PM   #257
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,149
Originally Posted by veloriumcamper View Post
Thank you kindly, all you guys who gave me advice regarding gearing ratios. This has been a huge help, and more importantly the only help I've been able to get. My resources are very limited, being a young guy and a noob with few riding buddies...and a tight budget. I realize that responding to questions like mine can be cumbersome for you folks who have been here a long time, but I want to reiterate my appreciation of this favor--I don't take it for granted. Cheers
.. just to add to the confusion .. if you are going more for "adventure" riding/touring you might want to consider going with a 16 front and 39 rear ..
.. just so it's not "my opinion" .. from one pretty reliable source: "My KLR is now geared up 16-39 (from stock 15-43 ) 60 mph is now 3200 rpm. (was 4,000 rpm)" .. that particular guy is riding with a pretty radical fairing, but the guy that set him up knows what he is doing ..
If you want to play around with gear sizes/ratios you can punch up your own numbers here and see what the changes do for differing size gear combinations ..
http://woodsware.aciwebs.com/gears/gears.asp
.. find the KLR 650 in the drop menu and add your own front and rear gear sizes and you'll see where it puts you .. pretty good site .. you can even check how tire size changes affect your ride too ..
.. hope this answers more questions rather than causes you any grief ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill is offline   Reply With Quote
Old 11-30-2011, 07:16 PM   #258
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
The side bracing looks like small-diameter rod. Tube is better in many ways. Having just had a wonderful experience bolting on some HT farkles, I can tell you, they can't be beat. Their instruction pages are a bit sketchy, but the stuff fits and is completely legit.
The HT OSR system is now on sale for under a hundred. I'm a big fan of the soft stuff, and for $98, you simply can't go wrong. It's grape flavor. . .
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 11-30-2011, 07:23 PM   #259
XDragRacer
Oddometer: 3,093
Stock gearing final drive ratio (43/15) is 2.87; his setup (39/16) gives 2.44; 2.44/2.87 X 4000 rpm = 3400 rpm; pretty close.
XDragRacer is offline   Reply With Quote
Old 11-30-2011, 07:46 PM   #260
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
Rather weird question here. Just spent some time with Bro-Bro, who uses my shop to manufacture custom guitar and harmonica amps. He's an early iron-head, who's run Yamaha XS 650s for about thirty years. Today, he went off on carb combos on the XS. I get lost within five minutes of his talk, but one thing piqued my interest. He spoke of putting a smaller, single carb on an XS twin with an appropriate two-to-one manifold. Reportedly, the rig would not pass 85 mph, but was putting out massive low end and rode at about 65 mpg. Is this a possibility for the KLR? Most of us want more upper end, but could the torques and the mileage be achieved through carburation rather than gearing?
The Rock 2013 RR
Old 11-30-2011, 09:17 PM   #261
Aarono2
Oddometer: 76
Ok, question for the KLR minds.
I just got back from the Barstow to Vegas ride where my '00 KLR gave about about 3/4 of the way through. I just pulled the head today and all 4 valves are bent from the piston making contact with them. (Ill get some pics soon). Anyway, what the heck would cause that to happen. The bike has relatively low miles, about 8,300 and I had just checked the valve clearances within the last 1k miles. Ideas?
Aarono2 is offline   Reply With Quote
Old 11-30-2011, 09:33 PM   #262
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
How hard were you twisting it over those long, barren flats? I've been there, and know it's a place where you can go all-out. Even in the current config, the KLR's an old-school single, and really doesn't like to ride at much over 5-6k rpm for extended periods. You can make short forays to the red-line. but a heavy piston such as is fitted into the KLR's cast-iron bore will start to spank things in a hurry. If you want to scream to the casinos, I suggest something with at least another cylinder, or preferably another three. I've said it before, but you cannot whup piston speed, no matter how hard you hope to.
The Rock 2013 RR
Old 11-30-2011, 09:43 PM   #263
nakedwaterskier
nakedwaterskier's Avatar
Oddometer: 263
KLR650 Only Thread......
Some of the 15T sprocket lovers claim a 16T doesn't do much for you on the fwy but I believe it does much...the big Lincoln 460ish piston of the KLR has inertia. But 280ish less rpm with the 16T makes me feel much safer on the fwy.
The aftermarket pistons/big bores actually weigh less so I would feel a little safer revving those. But, not for a long time.
My 2004 blew from the doohickey side at 35K miles. Well maintained engine--my thinking is all the counter weights just spun the balancer shaft bearing despite Mobil 1 15-50 in the motor.
Mine is up and running with a USMC gas engine with supposedly 258 miles on it; just had to rebuild the water pump and adjust valves...the Marines scavenged some parts off it before it was sold by govt. liquidators I believe.
About to do the doohickey on it.
As far as your engine goes...take off the doohickey side case and see if anything blew there and messed up your timing chain...if still seeking cause.
Good luck on finding a new engine...if you want any R & R tips...I have them fresh in my mind
nakedwaterskier is offline   Reply With Quote
Old 11-30-2011, 09:44 PM   #264
nakedwaterskier
Oddometer: 263
Blown engine
Mine blew after lengthy fwy high speed riding though you should have been doing lower speeds/revs on dirt.
Old 11-30-2011, 09:48 PM   #265
Aarono2
Oddometer: 76
The ride was all dirt so no highway the whole day. But to be honest, I do ride this bike hard. We were set to finish the ride around 4PM doing ALL the hard routes which means we were hauling a$$. (If you've done the ride you'd know.) Although I still don't feel like I was too hard on the motor, I didn't run over 5k for long periods.
So looks like Ill be rebuilding her. Would a 658/705 kit help to prevent this? What about larger valves and stiffer springs? Or does anyone want to to buy a heavily modded KLR with a fresh motor rebuild? haha
Old 11-30-2011, 09:51 PM   #266
Aarono2
Oddometer: 76
Yeah, Ill be asking you for help since Ill be rebuilding it myself. Good Idea about the doohickey, Ill pull that side of the case soon. I did spin the motor around a few times and the chain looks fine so far.
Old 11-30-2011, 09:52 PM   #267
nakedwaterskier
Oddometer: 263
Blown engine
it isnt the heavy piston's fault unless your rod broke...otherwise how did it touch the valves?
timing chain issue?
valve train broke?
Old 11-30-2011, 09:55 PM   #268
Aarono2
Oddometer: 76
timing chain issue?
valve train broke?
Besides all the bent(and now stuck open) valves, everything in the topend looks just fine?
Old 11-30-2011, 10:41 PM   #269
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 405
I may be mistaken but I think he is talking about this:
http://www.advrider.com/forums/showthread.php?t=745396
Not hammering it on the slab. Happens every year after Thanksgiving.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 11-30-2011, 10:47 PM   #270
Aarono2
Oddometer: 76
Yuuuuup.
Times are GMT -7.   It's 09:14 AM.
