Old 08-07-2012, 07:55 AM   #3511
KneeKicker
KneeKicker's Avatar
Oddometer: 2,630
Originally Posted by tommu56 View Post
Take a voltage reading at the plug
Then to the frame for ground and on the plug
I'd bet you have a bad ground
tom
Checked it both ways and even added another ground at bulb......no difference
Getting almost 12v at both high and low.
everything looks cool on motorcycle
"I got so drunk last night I woke this morning and someone had shit my pants" Ron White
KneeKicker is online now   Reply With Quote
Old 08-09-2012, 12:18 PM   #3512
Asatrur
Newbie KLR adv rider
Asatrur's Avatar
Oddometer: 1,249
odd rattling
On my 00 KLR, I have developed an odd rattling that only happens at certain speeds/RPMS 3-5th and mainly lower on the throttle side versus opened up. This also does not happen when I am not in gear or the clutch in. I have been going through the bike looking for loose parts, but nothing yet. Also verified the oil is full, though it is time for a change. Any ideas on how to go about finding this?
00 KLR650
04 Connie - Sold, but looking again!
I wonder what is over that dirt thingamagig?
http://share.findmespot.com/shared/f...Op8LhphYfeBJ9I
Asatrur is offline   Reply With Quote
Old 08-09-2012, 12:26 PM   #3513
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,857
Any crashbars or aftermarket stuff?
I finally found the source of my "odd rattling"...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 08-09-2012, 12:28 PM   #3514
Asatrur
Asatrur's Avatar
Oddometer: 1,249
Nope, nothing other than hand guards and a skid plate, which have been tested as good.
00 KLR650
Old 08-09-2012, 01:09 PM   #3515
jonyfi
21st century adventurer
jonyfi's Avatar
Oddometer: 426
Denver area this coming weekend...
I will be traveling thru the Denver region this coming weekend (truck/trailer/klr) on my way to the east coast... Anyone up to showing me around some of the high country roads/ trails and camping out in the mountains for the weekend or longer?....
I realize this isn't the rides category but since I am riding a klr I would prefer to ride with others with same moto, but not neccessary....
Klr/ fully loaded with hard boxes....
jonyfi is offline   Reply With Quote
Old 08-09-2012, 02:52 PM   #3516
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
Have you been inside lately to check the balance shaft spring?
Even if the "doohicky" was done/spring changed, it should be
opened and checked from time to time to be sure the spring
is doing it's job. Also, if there are a lot of miles on the bike, the
balance chain can eventually start to hit a bolt-boss at the bottom of
the case..... (may not be your rattle, but checking in there is wise)
CycleDoc59 is offline   Reply With Quote
Old 08-10-2012, 12:47 AM   #3517
two trackin fool
two trackin fool's Avatar
Oddometer: 1,289
Do you know that they will replace that bar under warrenty ?
two trackin fool is offline   Reply With Quote
Old 08-10-2012, 09:01 AM   #3518
WARRIORPRINCEJJ
Oddometer: 9,857
Yes, I do. I've got two, new "rubber-mount" bars on the way.
I appreciate you posting, though. If I hadn't have known that, I sure woulda' hoped someone would've shared that info.
Old 08-10-2012, 10:50 AM   #3519
kckeeny
Poor Bastard
kckeeny's Avatar
Oddometer: 3,663
Question
Anyone here have any tips or tricks to adjusting the head lamp aim on the 08+ years? Pull off the wind guard on the bottom of the fairing and squeeze hand and a ratchet in it?
Also, when installing/swapping lowering links; is there any part of the bike that should be suspended? In other words, when I take out the 1st bolt is it going to be spring loaded?
Don't Add quirky statement here.
kckeeny is online now   Reply With Quote
Old 08-10-2012, 11:24 AM   #3520
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,971
You'll need to do two key things.
1. lift the bike (via the skid plate, frame, or footpeg brackets) until the rear suspension is hanging completely slack (shock fully extended, rear wheel slightly off the ground). Make sure that the bike is stable and secured. It will take some torque on the bolts, so it sucks to have a bike fall on you during maintenance. I generally put jackstands under the footpeg brackets for this.
2. Use a floor jack under the axle adjustment area on the swingarm (probably the kickstand side, since the nuts are on the other side). The floor jack will allow you to adjust and hold the position of the rear wheel for alignment of the holes and for moving the whole system so you can get to the fasteners easier.
When you take the bolts out, mind the needle bearings and inspect/grease the hell out of them while you're there.
Have fun.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 08-10-2012, 01:07 PM   #3521
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 665
Use water proof grease.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 08-10-2012, 03:22 PM   #3522
kckeeny
Poor Bastard
kckeeny's Avatar
Oddometer: 3,663
Thanks. Think I'll attack it right now while the almost dry battery gets some amperage. Do the doo while I'm sitting next to her too.
Old 08-11-2012, 07:08 AM   #3523
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 193
preload and rebound setting
Does anyone have any recommendations on the stock rear shock preload and rebound settings (2009 model)?
Instead of me experimenting to find the best setting I thought I would ask around.
My current settings are:
preload = 3 (seems to be good for me. 200 lb rider)
rebound = 2 turns out (I think it might be high)
Factory settings: (based on 160 lb rider)
preload = 1
rebound = 1.25 turns out
dd
DesertDuster is offline   Reply With Quote
Old 08-11-2012, 07:43 AM   #3524
kckeeny
Poor Bastard
kckeeny's Avatar
Oddometer: 3,663
Shit! I need a flywheel puller! 22mmX1.5 bolt will work if I can get one of those on a Saturday. Always a wrench thrown in any project.
Old 08-11-2012, 08:02 AM   #3525
Aprilia
Oddometer: 749
preload = 1
Preload should be determined by Race Sag. From experience you'll need to be on #4 at least. Rebound...I have a way to determine by feel/bounce by hand but in general terms as little as possible before the bike wallows in the corners.
Aprilia is offline   Reply With Quote
Times are GMT -7.   It's 11:09 AM.
