Old 08-31-2012, 07:05 PM   #3781
SteelB12
SteelB12's Avatar
Oddometer: 2,979
Originally Posted by Simple. View Post
My 2012 with 1500 miles smells like coolant when I fire it up. Also see some dried coolant residue on the front down tube, and under the right fairing. (not coming from the engine) I have not investigated it yet, but I was wondering if this was a common problem? I'll take it to the dealer because its under warranty still, but if its just a clamp or something stupid i'd rather just fix it myself to avoid leaving it for who knows how long at the dealer.
Jon
Every so often I notice that smell from my 09 and see a little bit of green on the skid plate. Its been awhile since this first started and I just can't seem to tell where it is coming from. The overflow bottle is still at an acceptable level, so I guess its not that bad. I suppose I should look a little better one of these days.
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is online now   Reply With Quote
Old 08-31-2012, 08:50 PM   #3782
Adiventure
Oddometer: 70
Well, I tried most of the above to no luck. Ended up finding a shop that went at it for half an hour with a hammer and punch and only got as far as screwing a screw into the bolt remains. Seems like it will hold for the near future, and when I get around some tools I'll see about a real fix. I would have been annoyed but they did it on the house (late on a Friday three day weekend).
Now when I do actually grind it off, do I need to track down a barrel/nut the same height as stock?
Adiventure is offline   Reply With Quote
Old 09-01-2012, 10:08 AM   #3783
kckeeny
Poor Bastard
kckeeny's Avatar
Oddometer: 3,662
Crash bars on the 08 were rattling where they join in the front. I so thought it was engine (bad) noise. Just discovered that it was the crash bars so ...Pulled the bars and used KLR approved electric tape on the joining part. No more rattle.... From there. Now I'll work on the dash rattle.
Don't Add quirky statement here.
kckeeny is offline   Reply With Quote
Old 09-01-2012, 09:13 PM   #3784
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Originally Posted by redog1 View Post
...on my 1990. Ground the remaining bolt down flush, carefully drilled it oversized and welded a new nut on, reinstalled the sheild. No problem since.
Like you and CycleDog I agree that is an ideal scenario... I busted mine off when I replaced it with an 08 headpipe, I figured, so what, aint using it. Since I have installed an AF headpipe and kinda forgot about a shield...... Always thought about what I would do and my first inclination was to just drill the existing bolt out and tap a size bigger, wouldn't that work?
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 09-01-2012, 11:04 PM   #3785
XDragRacer
Oddometer: 3,188
Worked for me (on another threaded hole on KLR); even used small drill bit and same-size tap. Better to go bigger, but thought--if this pulls out, I'm no worse off; THEN I'll go bigger!
XDragRacer is online now   Reply With Quote
Old 09-02-2012, 07:40 AM   #3786
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 665
Grind it off and mig weld a stainless steel nut in it's place. It just needs a tack on each side.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 09-02-2012, 02:35 PM   #3787
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,389
So I came close to buying a KLR a few years back, when they updated it. I bought a VStrom instead. Which I loved. Sold it this year, because I wasn't using it. I have a 250 Sherpa that will go where I want, but it's a little bike with a little gas tank, not really good for 2-up stuff. The VStrom was brilliant 2-up, I've ridden an older KLR by myself, how would it compare to the new ones, and do they work fine with a passenger and luggage?
And have you seen the 2013's? I think the best looking graphics they have done yet.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is online now   Reply With Quote
Old 09-02-2012, 06:32 PM   #3788
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,802
Thumb Yep, would work fine, but you know that.
I noticed you didn't have the sheild. You could always do header pipe wrap also, On your bike, That would look pretty good also. IMHO.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 09-03-2012, 12:42 PM   #3789
Hessian42
Hessian42's Avatar
Oddometer: 169
10,000 mile capable KLR tires share what you got!
Hessian42 is offline   Reply With Quote
Old 09-03-2012, 01:19 PM   #3790
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,802
Kenda K270's
Getting right at 9K front and rear primarily highway miles running at 30-35 psi. Very happy with them. Road worthy and plenty capable if I hit the trails on this bike.
redog1
Old 09-03-2012, 05:16 PM   #3791
jeepsandbikes
loneadventurer
jeepsandbikes's Avatar
Oddometer: 148
i got a used one for cheap , the shipping might be $$ cause im in canada
Originally Posted by Adiventure View Post
Seems like someone done fuck up, possibly me, but I'm not pointing fingers.
How would one go about fixing this problem?
A bad day of riding is better then a good day of work
jeepsandbikes is offline   Reply With Quote
Old 09-03-2012, 05:26 PM   #3792
Blackheart58
Oddometer: 3
MAYBE the Heidenau? I'm trying one on the back...only about 500 miles so far, but, I can't detect any wear, yet!
Blackheart58 is offline   Reply With Quote
Old 09-03-2012, 05:36 PM   #3793
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,312
Well I would hope not!
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 09-03-2012, 06:52 PM   #3794
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,252
A local buddy with an F800GS had a 10,000 mile K60 on his bike yesterday, said he loved it. I have a feeling it will be my next tire. It's twice as much as the Shinko 705, but I bet I get twice as much wear, and it is possibly a little better off road. Heck, even if they act the same, cost exactly twice as much and I only get exactly twice the mileage, it'll be nice not changing the tire every 4000 miles.
sandalscout is online now   Reply With Quote
Old 09-03-2012, 09:13 PM   #3795
XDragRacer
Oddometer: 3,188
Just a suggestion, replace the hex-head machine screws holding the heat shield with hex-socket (Allen head) bolts. More torque available for loosening with a hex key; less likelihood of snapping off the bolt head.
Times are GMT -7.   It's 08:55 AM.
