09-06-2012, 07:41 AM
#3826 | |
KLR650-2009
Oddometer: 1,070
+1
No, I don't know where that road goes, let's find out! redog1 |
09-06-2012, 08:31 AM
#3827 |
Oddometer: 341
.22 mod will certainly help with MID throttle surging but according to my A/F sniffer going to the KLX needle is a better way to go as it also allows you to lean out that main jet. Kawi had to over compensate due to lean MID throttle fueling dictated by EPA. Mild throttle...mid throttle
09-06-2012, 08:36 AM
#3828 | |
KX & CR 500 Rider
Oddometer: 311
Go faster than everyone. Only worry about what's in front of you. '08KX500AFC(my favorite) '07KLR650 '04KX500(street legal) '97CR500R '06KLX250(351cc kit) '08KFX450R quad |
09-06-2012, 09:14 AM
#3829 |
NoMoTDM still Gary
Oddometer: 3,710
The KLX adjustable needle is only used on the off road KLX 650r version. All years are the same. 1993-1996? Without a dyno or an AF sniffer, it is all trial and error. It will work for a KLR as the carbs are the same, but the jetting is different, a KLXr has 155mj. Air box mods and free flowing exhaust make a huge difference in jetting for your bike.
Every bike with a cap on the pilot setting is done to meet EPA emissions. They don't want you tampering with it. A consequence is the stock bikes are lean. The pilot controls the first 1/8 throttle, actually more than that. Get an extended screw to set it correctly while the bike is warm and running. screw it in and then out until it wants to stall. The correct setting is in between. Usually about 2 1/2 turns out. The main jet augments the pilot. The needle controls where and how much it kicks in. The proper MJ can be determined under WOT. Too big and high rpm is soft. It you back off a bit and the bike accelerates it is too rich. It won't reach top speed if too lean. After you have done that and it surges at steady state throttle, it is a needle height issue. The air box and exhaust mods changes at what point the power comes on. I own a KLX 650c model. No adjustable needle. I did the washer mod while removing the the air box lid and added a free flowing exhaust. It killed the bottom end, but the bike was a rocket at high rpm. It also surged. Instead of fiddling with the fuel I added a baffle to the exhaust. I got my low end torque back, the bike was quieter and the surge went away. For the 2 hp gained in all of these mods, a DJ kit is probably money well spent over the PIA testing to find the right set up.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 09-06-2012 at 09:51 AM |
09-06-2012, 09:52 AM
#3830 | |
Oddometer: 341
09-06-2012, 12:22 PM
#3831 | |
mcpenner
Oddometer: 116
09-06-2012, 12:41 PM
#3832 | |
Oddometer: 2,022
A finger knob (or Kobuta T-handle) fuel screw allows adjustment of the idle air/fuel mixture. Useful, perhaps, at altitude, but--primarily only up to 1/8 throttle. XDragRacer screwed with this post 09-06-2012 at 12:58 PM |
09-06-2012, 03:55 PM
#3833 | |
Oddometer: 341
09-06-2012, 09:02 PM
#3834 |
Oddometer: 30
I've read a couple posts on here about mpg on the KLR. I have an '03 with 19,770 miles and I'm getting about 33 mpg. Mostly hwy averaging about 70 mpg at 4500 rpm. Why is this so bad compared to what other people are getting? I run 91 in it. Thanks
Andy |
09-06-2012, 09:24 PM
#3835 | |
KX & CR 500 Rider
Oddometer: 311
09-06-2012, 11:58 PM
#3836 |
Tightass KLR rider
Oddometer: 799
I get 5L/100km or near enough to 47miles/gal on my 08 running D606's. It has stock gearing, stock jets and 110km/h is the upper speed limit.
Only real mod I have done is to pull the snorkel and open out the exhaust a bit. I too would give it a service, check the plug, re-shim the valves, screw in the main jet and then back it out the 2 1/2 turns and make sure the choke/enricher cable is lubed. If it isn't disengaging then you will be using more fuel than you should. Has a previous owner messed with the jetting at all? |
09-07-2012, 08:45 AM
#3837 |
Oddometer: 341
What main jet is installed? Is it stock needle or aftermarket? Based on mileage I'd guess you have a 150 or 152 main jet. Stock main jet is too rich but needed with stock needle....
09-07-2012, 08:49 AM
#3838 |
Oddometer: 30
Not that I am aware of of. I pulled the air filter and plug this morning and they both looked good. I ended up replacing the plug just for good measure. I will have the valves done in the next couple of weeks.
Andy |
09-07-2012, 08:51 AM
#3839 |
Oddometer: 30
Everything is stock.
09-07-2012, 12:38 PM
#3840 |
Oddometer: 341
Did you visually verify? I've had two bikes in the past two weeks in my shop who also swore theirs was completely stock. One had an adjustable fuel screw and both were rejetted by 'someone' who had no idea what they were doing other than bigger must be better.
