Old 09-20-2012, 08:49 PM   #3946
Argentian
Oddometer: 71
22 cent question
Hey all,
All that recent stuff about carbs and what to do about the main jet needle etc has been fantastic and has me doing some thinking.
So if I go ahead and do the 22 cent mod, how will it effect my fuel usage? Also, what happens if I do it without opening up the airbox and I keep the stock pipe? Not that I wouldn't like to change the pipe sometime but I can't afford it now and anyway the rear suspension upgrade has to come first. I don't really want to start smashing holes in it with a big screwdriver or whatever either.
My '08 has definitely been popping on decels and sometimes seems to surge a little at mild throttle as someone was talking about here recently.
Thanks.
Argentian is online now   Reply With Quote
Old 09-20-2012, 08:54 PM   #3947
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,048
The .22 mod will richen you up some and help with the lean condition, drilling the slide will help with throttle response. Better to do it that way than like alot of guys put the pipe on without any carb mods and lean it out further. go ahead. Later you can buy a full flow pipe and butcher your airbox.......
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 09-20-2012, 09:15 PM   #3948
Sandman7925
Oddometer: 4
So I've got a few hundred miles on my KLR now and I have a few questions.
It shifts loud from 1st to 2nd, is that normal?
Is there any do it you're self mods to remove any kind of power restriction that I should know about?
Sandman7925 is offline   Reply With Quote
Old 09-20-2012, 09:18 PM   #3949
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,256
Originally Posted by DeusExMachina View Post
It's kind of the same tire as a 606 isn't it? Does it have better wear life?
The MT21 is unidirectional so when the tire starts to cup you can flip it and get alot more use out of it. And it grips MUCH better on road and off. There's no reason to get the front 606 over the front mt21.
Rear 606 is great though!
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 09-20-2012, 09:24 PM   #3950
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,256
Extended shifter smooths out the shifting considerably. Moose makes one.
Google KLR .22 mod and frugle exhaust mod. Read up, then ask questions. They put some pep in the KLR's step!
Old 09-20-2012, 09:25 PM   #3951
Aprilia
Oddometer: 670
Most motorcycle transmissions are a bit noisy. Other than the overly lean carb settings there are no 'restrictions' on the bike.
Aprilia is offline   Reply With Quote
Old 09-20-2012, 09:27 PM   #3952
Argus16
Fake n00b
Argus16's Avatar
Oddometer: 428
First to Second? Mine clunks a bit too, and I often miss that shift (into Neutral). Nothing abnormal imo.
I removed the snorkel (rubber sleeve) from the airbox and installed a DynoJet Stage 1 (142 main, 7/64 drillbit, idle mixture screw 2 turns out, e-clip 2nd grove from the top), low-buck exhaust and noticed a significant difference w/o anymore popping on decel).
Best $100 I've EVER spent.
Argus16 is offline   Reply With Quote
Old 09-21-2012, 07:23 AM   #3953
jules083
jules083's Avatar
Oddometer: 3,576
Two quick questions here. Bike is a 2005.
1. I installed a dynojet kit according to their recommendations for my bike, with stock airbox and big gun exhaust. 140 main, new needle, drill slide, 3.5 turns out on air screw. The bike seems to run ok, but there is the occasional decel pop and the idle is higher, around 1800. Should I lower the idle, or mess with the.air screw? Idle was good before.
2. I am thinking of getting the tank nerf bars and the soft luggage rack from happy trails. Looking at the cheaper of the racks, basically a heat shield almost. Good enough for soft bags? The other part is the nerf bars. Are they worth buying? The PO installed the engine guard with highway pegs. Putting the small bags on the bars would be nice I think, but if the bars don't protect much I don't see the point of spending money and adding weight.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 09-21-2012, 07:28 AM   #3954
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
The nerf bars saves me from expensive repairs a couple times.
There are other bars out there, but I like my nerf bars.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 09-21-2012, 08:04 AM   #3955
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,141
I don't care much for the Nerf bars, and I've seen a few posts of people bending the crap out of them and the bends pushing into the tank/plastics and doing damage. I'm planning on getting this set, instead of the nerf bars:
http://www.happy-trail.com/KLR650A/E...l-KLR650A.aspx
$120 cheaper, seems like a good alternative, and the don't look as "in the way" as the PDs. I think it'll make the bike easier to work on too.
My KLR650
Matt's Trippin' in Peru
sandalscout is offline   Reply With Quote
Old 09-21-2012, 09:50 AM   #3956
tommu56
tommu56's Avatar
Oddometer: 1,330
I got the HT nerf's and it has been a good buy.
No bends in them my last get off left me hurting and about 10 lbs of sod and dirt wedged in the bars but they and the plastics and radiator were fine!
tommu56 is offline   Reply With Quote
Old 09-21-2012, 09:52 AM   #3957
Argus16
Fake n00b
Argus16's Avatar
Oddometer: 428
Do both... go in with your air screw one more turn, then adjust your idle imo.
http://www.dbzproducts.com/index.htm
Dirt Bagz complete w/racks. 15 litres each, (Rangers) waterproof if you spray them with a silicone spray from WallyWorld.
Excellent quality.
http://www.youtube.com/watch?v=HDfA4_CocjM
Check this out... he's got small bags on the nerf bars.
Old 09-21-2012, 10:37 AM   #3958
firewall738
Kawasaki long range
Oddometer: 2
klr 650 windshield upgrade
i just got a 2012 and i'm looking to put a taller windshield for better touring, should i go with the one kawasaki makes that is 4 inches taller or should i go with the moose racing windshield??
firewall738 is offline   Reply With Quote
Old 09-21-2012, 11:07 AM   #3959
mxboy96
mxboy96's Avatar
Oddometer: 65
Pretty normal
It's pretty normal. Mine does it too. I'd rather have a good firm/crisp shift than a worn out/don't know if you'll get stuck in nuetral or not shift,lol.
Tanman
mxboy96 is offline   Reply With Quote
Old 09-21-2012, 11:09 AM   #3960
wyoly
Oddometer: 20
Thumb windshield
I have an 08 and put a Cee Baily's on it and love it. I can adjust it for when I hit the slab or dirt. I am 6'1" and it directs the wind over my head. It is a little spendy but mounts real easy.
wyoly is offline   Reply With Quote
Times are GMT -7.   It's 10:13 AM.
