Old 10-03-2012, 09:04 AM   #4051
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,462
Originally Posted by Argentian View Post
And the bottom end - is it connected to anything or not?
Nope. Just hangs out the bottom to drain onto the roadway.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 10-03-2012, 09:06 AM   #4052
RandoCommando
Wannabe
Oddometer: 1,462
Originally Posted by y0y02369 View Post
Genius! I shall try that! Any idea on what to look for?
I like these
http://www.harley-softails.com/2009_...s_468x351b.jpg
But I'm sure you can find other pegs similar.
http://www.hdforums.com/forum/attach...r-p7171181.jpg
http://www.customdynamics.com/Images...egs_clevis.jpg
http://img398.imageshack.us/img398/7909/jan053rd3.jpg
http://images1.americanlisted.com/nl...e_11003704.jpg
This is what I have on my bike
http://www.happy-trail.com/KLR650/PDNerf-KLR650A.aspx
But you can buy the highway peg without the nerf bars.
MySPOT
RandoCommando screwed with this post 10-03-2012 at 09:15 AM Reason: Added links
Old 10-03-2012, 09:11 AM   #4053
Aprilia
Oddometer: 751
Anyone out there happen to have an idea how to change the seat to peg height other than highway pegs?
Contact eaglemike.com as he offers a replacement peg mount that drops and pushes back some. Several company's offer pegs that drop slightly. You're 6'3" do as I did and simply add a couple inches to the seat. Nice time to add a couple inches of width as well. Passenger pegs work very well for 'change of position' on long rides.
Aprilia is offline   Reply With Quote
Old 10-03-2012, 11:36 AM   #4054
y0y02369
y0y02369's Avatar
Oddometer: 1,225
I would love to get those bars but being on a budget, not gonna happen... where you suggest i mount just the pegs...?
y0y02369 is offline   Reply With Quote
Old 10-03-2012, 11:38 AM   #4055
y0y02369
y0y02369's Avatar
Oddometer: 1,225
the biggest concern for me is just that my knees are a little too bent when i ride... so with the leathers, it's a bit uncomfortable...
i wanted to find something that allowed less bending on my knees.
Old 10-03-2012, 12:48 PM   #4056
RandoCommando
Wannabe
Oddometer: 1,462
Well you're really limited on mounting those clamp on highway pegs as the only tubing you could clamp them too is under the engine area.
Does your KLR have an aluminum skid plate?
If so, you can buy different highway pegs that bolt on and drill a hole in the skid plate on each side for each highway peg.
MySPOT
Old 10-03-2012, 12:50 PM   #4057
RandoCommando
Wannabe
Oddometer: 1,462
Go to that auction sight and do a search on KLR 650 foot pegs.
You'll come up with a boat load of listings.
Some of them are one piece pegs that bolt right on and sit lower than the stock pegs.
Just remove the old pegs and replace with the new ones.
I'm not sure of the quality though.
And if you do change your stock foot pegs, you could always reuse them for a highway bar or bolt them to the skid plate.
MySPOT
Old 10-03-2012, 03:46 PM   #4058
Licky
Licky's Avatar
Oddometer: 82
thats a good start
Originally Posted by redog1 View Post
Looks like they bolt up the same and the rear subframe appears to be the same. I have a 1990 and a 2009 setting in my garage but I'm not going to swap them to see. Sometimes you just have to try something on your own.
Was this a one eye closed with one thumb up or did you happen to use a measuring tape?
Licky is offline   Reply With Quote
Old 10-03-2012, 07:54 PM   #4059
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,803
Question Eye balling it...
with the 2 bikes setting about 5 feet apart. Seriously, I see no difference but unless I actually swap them over I'm only about 95% sure. That's as far as I'll step in it.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 10-04-2012, 05:08 AM   #4060
jules083
jules083's Avatar
Oddometer: 3,986
I'm just thinking out loud here, but I'm getting a small collection of used front sportbike tires in the garage that have some life left and are almost the right size for a klr rear. 120/70 17. Thinking about mounting them on the rear just to finish them off and get rid of them. Most are around 1/3 to 1/2 tread, some a bit cupped, but good enough for daily riding/commuting duties.
Good idea, or accident waiting to happen? I believe they should be mounted backwards when used like this.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 10-04-2012, 08:02 AM   #4061
y0y02369
y0y02369's Avatar
Oddometer: 1,225
depends on how long they have been sitting there in your garage? If tires aren't used continuously, they tend to harden, which limits the flexibiliy of the tire and also the pressure once inflated... If not too long it should be ok. Just test them out well before you hit freeway... better safe than sorry
Old 10-04-2012, 08:26 AM   #4062
jules083
jules083's Avatar
Oddometer: 3,986
Two years or less on them. I have 3 right now sitting. 2 are half ish tread and are the stock take-offs that were removed when the original tears wore out and the bikes were switched to pr2's. One is a bit more worn, it was cupping weird and causing headshake on my fjr.
The main reason I'm thinking this is because I would prefer to change tires on my ninja and dad's gsxr as a set rather than have a new rear and worn front. If I had a use for the takeoffs I wouldn't feel bad about removing a good tire. I'll give it a shot soon, I'm about due for a swap. I may end up missing the off road ability and abandon the idea anyways.
Old 10-04-2012, 06:21 PM   #4063
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,648
Arrowhead low fender mod just works!
It would be the wrong decision for sticky mud conditions, but in the loose/damp/slimy/wet conditions here in the Northeast, the Arrowhead superbike low fender mod simply works, especially if you machine some spacers for it as I posted some moons ago. All day ride in the rain, with a clean rad and cooling system, and my toes were dry.
[IMG]http://i1157.photobucket.com/albums/...h/DSC00827.jpg[/IMG]
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman screwed with this post 10-04-2012 at 08:01 PM
Canuman is offline   Reply With Quote
Old 10-04-2012, 11:18 PM   #4064
ctb619
Oddometer: 3
Anyone in N. Colorado have an extra inner chain adjuster for a 1st gen? I'm currently in the Fort Collins area but need to get home to California ASAP.
ctb619 is offline   Reply With Quote
Old 10-05-2012, 12:32 AM   #4065
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,498
Dang, that headlight is bright. Couldn't even see the fender!
IDRIDR is offline   Reply With Quote
Times are GMT -7.   It's 03:46 AM.
