Old 10-08-2012, 09:48 PM   #4081
y0y02369
y0y02369's Avatar
Oddometer: 1,185
Originally Posted by Grinnin View Post
Make some peg mounts.
You don't have to mount BOTH peg mounts at the same time unless you want to take a picture showing the difference.
For me 1.5" down and 1" back made a huge difference.
that'd be exactly what i need! how did you make it??
y0y02369 is online now   Reply With Quote
Old 10-08-2012, 09:50 PM   #4082
y0y02369
y0y02369's Avatar
Oddometer: 1,185
Originally Posted by RandoCommando View Post
Go to that auction sight and do a search on KLR 650 foot pegs.
You'll come up with a boat load of listings.
Some of them are one piece pegs that bolt right on and sit lower than the stock pegs.
Just remove the old pegs and replace with the new ones.
I'm not sure of the quality though.
And if you do change your stock foot pegs, you could always reuse them for a highway bar or bolt them to the skid plate.
might have missed it... but what auction site..?
Old 10-08-2012, 09:52 PM   #4083
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
fleabay
Be forewarned, that the prices for a lot of the pegs are high if you're on a budget.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 10-08-2012, 09:54 PM   #4084
y0y02369
y0y02369's Avatar
Oddometer: 1,185
fleabay
Perfect! Kinda am but we will see. thanks anyway!!
Old 10-09-2012, 05:37 AM   #4085
Grinnin
Forever N00b
Oddometer: 2,630
The part that holds the peg is 1 1/4 inch square tubing with 3/16 inch wall thickness. This provides the 7/8" (22mm) inside dimensions for any peg that fits the Kawasaki mounts.
The part that touches the frame is 3/4" square tubing.
The bolts go through 1/2" OD round tubes -- i.e. the bolts cannot crush the 3/4" square tube. The 1/2" round tubes go all the way through the 3/4" square and also through one side of the 1 1/4" square. This makes the 1 1/4" tube "keyed" to the bolt sleeves. Theoretically this "keyed" construction lets me get the angle exactly the same as the original, but you can see from the comparison photo (in other posts) that I missed by over a degree.
Cut parts to length then remove metal that's not needed.
You might be able to see that the front 1/2" tube is longer than the back one. (The back bolt head shows a little in the shadow.) This allows a larger bolt head to clear the angled cut on the 1 1/4" square.
The way all the parts came together I didn't have good access for any kind of welding (wire-feed and oxy-acetylene are the options here) so I brazed it all together.
The whole mount weighs about as much as a stock mount. I forget if it's 1/16" wider or narrower, but it's about as wide as stock too.
I completed these just over a year ago and they were on when I was riding nearly daily on eastern Maine's ATV trails. Total 12 to 14 thousand miles so far.
Motorcycles are magical.
Grinnin screwed with this post 10-09-2012 at 08:13 AM Reason: Replaced photo
Grinnin is offline   Reply With Quote
Old 10-14-2012, 08:46 PM   #4086
y0y02369
y0y02369's Avatar
Oddometer: 1,185
I shall make that my winter project!!! thank you!
Old 10-16-2012, 06:27 PM   #4087
Nitro1970
Nitro1970's Avatar
Oddometer: 191
So what brand chain do y'all run??
Nitro1970 is offline   Reply With Quote
Old 10-16-2012, 07:49 PM   #4088
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
EBay X-ring special.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 10-16-2012, 10:23 PM   #4089
Myfuture_yourdebt
Oddometer: 372
http://www.rockymountainatvmc.com/p/...XW-RING-Chain/
$68 for the 520x106, and that's for a good chain. They also have Primary Drive sprockets, $9 for a 15t front and $20 for a 43r rear (those are stock numbers). That's $98 for the three, add a small item to bring the total to $100+ and then you get free shipping.
Myfuture_yourdebt is offline   Reply With Quote
Old 10-16-2012, 10:42 PM   #4090
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,733
DID, XV, Gold chain!
Tried the Rocky Mtn Primary Drive special and it was throwing O rings at 12K - not good! My chains normally last at least 20K+.
Tsotsie is offline   Reply With Quote
Old 10-16-2012, 10:47 PM   #4091
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,194
Ran out of gas today, drained the tank empty. Miles from home, and even more miles from a gas station. Somehow the carb must have filled with just enough go juice to get me about a mile from home, then it was huffin it from there.
I'm such a badass that I pushed the bike the whole mile uphill back home.
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 10-17-2012, 04:14 AM   #4092
XDragRacer
Oddometer: 3,044
Didn't exploit the SECRET RESERVE?
(Lay bike on left side, petcock lever in RESERVE position; fuel drains from bottom right side reservoir over to petcock and fuel line connection, lower left of fuel tank. Set bike upright, ride on.)
A few miles can be coaxed from the residual fuel languishing in the lower right recesses of the tank.
Just curious; at what point did you switch to the RESERVE petcock lever position? Were you on reserve when you initially left your house?
XDragRacer screwed with this post 10-17-2012 at 04:26 AM
XDragRacer is offline   Reply With Quote
Old 10-17-2012, 08:57 AM   #4093
Aprilia
Oddometer: 670
A few miles can be coaxed from the residual fuel languishing in the lower right recesses of the tank.Just curious; at what point did you switch to the RESERVE petcock lever position? Were you on reserve when you initially left your house?
He was aware he was already on reserve and best part....he had just tried jump starting the dead battery on his Jeep with his KLR.
Aprilia is offline   Reply With Quote
Old 10-17-2012, 09:18 AM   #4094
XDragRacer
Oddometer: 3,044
I hear you; just wasn't sure he was aware of the additional fuel volume, the "secret reserve," available from laying 'er down on the left side.
Old 10-17-2012, 09:25 AM   #4095
XpressCS
XpressCS's Avatar
Oddometer: 1,194
I knew there was a smidgen of gas left in the bike, I could hear it, that's why I was all WTF when it just quit for the second time.
What, you've never jumpstarted a car before? You really can't, you have to let the bike do double duty and charge the battery just enough, which is why you keep the RPM's up so the stator is at a more peak output.
2004 KLR650
Times are GMT -7.   It's 09:38 AM.
