Old 10-19-2012, 11:05 AM   #4111
MrGoldfish
MrGoldfish's Avatar
Oddometer: 506
Crap Man!
I asked my dealer about it and they told me that the problem had been fixed. Now that I'm reading this I'm beginning to think that I need to do the doo now. I've got an '08 with almost 13,000 miles on it and I haven't had any issues... yet. I should probably get on this.
MrGoldfish is offline   Reply With Quote
Old 10-19-2012, 12:07 PM   #4112
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,914
"I asked my dealer about it and they told me that the problem had been fixed" ... there you go!
At least they acknowledged that there 'was a problem' - more than many have been prepared to! The too short spring has been like that since the 08's came out and has not "been fixed" yet!
While in there, do a decent job , put the EM one and torsion spring on and forget the rest!
Tsotsie is online now   Reply With Quote
Old 10-19-2012, 02:14 PM   #4113
the kawasaki kid
the kawasaki kid's Avatar
Oddometer: 232
I guess I'll be doing the doo after break-in...
the kawasaki kid is online now   Reply With Quote
Old 10-20-2012, 09:03 AM   #4114
Nitro1970
Nitro1970's Avatar
Oddometer: 191
Checked the doo on my '11 at 13K miles... The spring had no tension left... EM torsion spring and doo installed
Nitro1970 is offline   Reply With Quote
Old 10-21-2012, 06:18 PM   #4115
mcpenner
mcpenner
Oddometer: 262
trunk mileage
Just wondering, does a large square top box effect gas mileage?
mcpenner is offline   Reply With Quote
Old 10-22-2012, 04:56 AM   #4116
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 695
Some, I would guess but not enough to worry about. Big top box or take the car or truck to the grocery store, your still saving gas. I know my side boxes make a wind drag.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 10-22-2012, 05:03 AM   #4117
McB
Joe 40 ouncer
McB's Avatar
Oddometer: 15,440
At 60, probably not. At 80, most likely.
McB is offline   Reply With Quote
Old 10-22-2012, 11:09 AM   #4118
Grinnin
Forever N00b
Oddometer: 2,894
My large square top box sits directly behind me. I made it tallish, but no wider than my Darien jacket (which is not the slimmest jacket in the wardrobe).
If I needed the best fuel economy, I'd take off the side cases and use the top box.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 10-23-2012, 06:05 AM   #4119
Wasca
Adventurized!
Wasca's Avatar
Oddometer: 611
Rear Master Brake Cylinder Cover
Hi Fellow KLR riders
I'm fairly new to the forums, my new KLR and riding in general.
I have a fairly basic question. Can anyone tell me where I can get a rear master brake cylinder cover for my brand spankin new 2013 KLR 650?
I want something that looks purdy, perhaps with holes and in aluminium.
Wasca
Wasca is offline   Reply With Quote
Old 10-23-2012, 09:54 AM   #4120
Aprilia
Oddometer: 761
Wasca
Welcome! Most of us go for function than looks. www.eaglemike.com offers a much better rear brake mount. Stock one will snap with little provocation. The purdy covers help protect but I've seen a number of mounts snap even with those purdy covers.
Aprilia is offline   Reply With Quote
Old 10-23-2012, 10:02 AM   #4121
rustynut2
Oddometer: 495
The new bikes have the master cyl mount as part of the steel frame, it will not snap like the old ones. Got my cover from happy trails I thinks.
Work harder, millions on welfare depend on you.
12 T800XC, 14 DRZ 400s
rustynut2 is offline   Reply With Quote
Old 10-30-2012, 10:09 AM   #4122
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,804
Is this thread dying?
7 days and no posts.
Bump.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 10-30-2012, 10:20 AM   #4123
Tsotsie
Oddometer: 1,914
Front brake binding
2008 - 45 K miles, 320 front disc, SS wound line. The front brake is binding very slightly. Cant determine why.
Galfer pads are properly sized to fit the caliper and broken in - 1000 miles.
The caliper slides are properly greased.
Caliper and pistons are clean.
Rotor runs true.
It appears that the 2 pistons might not be retracting slightly after use?
Old 10-30-2012, 10:27 AM   #4124
twinjet
Oddometer: 306
Rotor runs true.
Check your hand lever free play.
twinjet is offline   Reply With Quote
Old 10-30-2012, 10:49 AM   #4125
CA Stu
CA Stu's Avatar
Oddometer: 47,753
Rotor runs true.
Do the quick and dirty bleed:
Kneel next to the bike, press the caliper inboard, towards the hub
Pump the lever
Repeat if necessary.
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Times are GMT -7.   It's 03:29 PM.
