Old 11-04-2012, 08:14 AM   #4171
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,844
Originally Posted by mcpenner View Post
No. It had faded red plastics.
The front frame down pipe split into two about 1/2 way down and then went under the motor to the swingarm area. He said that had stiffened up the frame a lot. My beef with the KLR is not so much the motor, but frame flex when loaded and at 80+. The RBR seen one had an aftermarket pipe on too.
Tsotsie is offline   Reply With Quote
Old 11-06-2012, 12:37 AM   #4172
Tsotsie
Oddometer: 1,844
Found it- the KLRsys at the RTB Rally!
I apologise - I guess the plastics were not that faded - but after about 50+ miles of dirt, it had accumulate some honerable dirt by then! Super nice guy!
Old 11-06-2012, 05:04 AM   #4173
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 645
Build thread.
http://www.advrider.com/forums/showthread.php?t=640772
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 11-06-2012, 06:11 AM   #4174
Drybonz
Oddometer: 4
Pissed Super stiff clutch action,
Howzit, I'm new to the forum and new to the KLR.
Picked up my 'new' toy, 07 klr 650 27000km on Saturday, and took her out for a quick ride, after 350km I had no clutch!
The lever just flopped about, ( like a snapped cable), made a u-turn an d completed the 350km home trip.
On closer inspection, I found the lever (end that goes into side casing) had sheared !
Innitially i did think the lever was a bit on the stiff side, but figured i was just used to my Gixxers action,
I made up a new arm, but the clutch action is super stiff, which cant be right.
clutch plates and springs are all within spec, fitted new bearing
Any idea on what the possible problem could be
has anyone had a similar experience ?
Any help/advice would be appreciated.
Drybonz is offline   Reply With Quote
Old 11-06-2012, 07:13 AM   #4175
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,952
Any chance the clutch was upgraded to a "heavy duty" or offroad aftermarket one? From my experience (and I've read it on here before), the aftermarket clutch springs are WAY too stiff. I had to go back to the OEM ones with the aftermarket plates and discs. I had the same symptoms. Super stiff clutch and it actually bent the little arm on the case.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 11-06-2012, 11:02 AM   #4176
jonyfi
21st century adventurer
jonyfi's Avatar
Oddometer: 410
Carb rebuild
Well I have been experiencing what seems to be quick moments of fuel starvation (1993, aprox 30,0000)...I figured I'd start with a carb rebuild, its an old Moto so it could certainly use one anyway. All is going good with that, it certainly can use it...
Then I wanted to review the de-californication I did to it because it could certainly be something with that?...
I confirmed positive fuel from the tank to carb
I remember reviewing someone's diagrams...
I blocked the red hose coming off tank
I left the blue hose dangling/draining...
Plug air box
...but whenever I remove the tank I find fuel in the red hose, any reason why I can't leave that draining?
I am wandering if I have some breathing issue??? I thought if you reversed the blue and red hoses (with standard emission crap on) the bike can run crappy or even stop running???... So it goes to show something could be wrong?
Anyway, wanted to throw all this out there to see what comes back... I prob. won't have it back together for a few days, so no immediate results coming...
I realize it could be a slight electrical issue but sense it seems evident only in steady road riding at about 4000 rpms and not super consistantly I am thinking fuel....
jonyfi is offline   Reply With Quote
Old 11-06-2012, 11:24 AM   #4177
NHADV
NHADV's Avatar
Oddometer: 554
I was wondering if anyone out there has put a taller shock on the 2nd KLR to prevent rear end sag when fully loaded?
-Gary
NHADV is offline   Reply With Quote
Old 11-06-2012, 11:32 AM   #4178
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,952
Look into raising links. If you're a large rider and are maxing out the preload setting while loaded, then maybe a different (not longer) shock is the answer.
-DustyRags
Old 11-06-2012, 01:02 PM   #4179
rustynut2
Oddometer: 486
or just put a new spring on from topgun
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is offline   Reply With Quote
Old 11-06-2012, 02:21 PM   #4180
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,952
Good call. I have a heavier progressive brand spring on mine.
-DustyRags
Old 11-06-2012, 02:47 PM   #4181
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,466
And even though the weight is on the rear, you probably want to up the spring rates in the forks and shock. Proper spring weights make a world of difference!
IDRIDR is online now   Reply With Quote
Old 11-06-2012, 03:18 PM   #4182
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,259
Wired my headlight with a relay. Still only comes on with low beam, but at least I'm getting nearly a full 14 volts to it, versus the original ~12 volts. Will eventually wire the lamp with the LED's so the low beam stays on all the time.
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 11-06-2012, 03:23 PM   #4183
CA Stu
CA Stu's Avatar
Oddometer: 47,503
Originally Posted by icepick62 View Post
i've seen that some are using a 520x106 drive chain, my manual calls for a 525x106 drive chain, which one? I can't find a size on the existing chain or sprockets.
520
http://youtu.be/C6cxNR9ML8k
CA Stu is online now   Reply With Quote
Old 11-06-2012, 06:06 PM   #4184
XpressCS
XpressCS's Avatar
Oddometer: 1,259
Update, swapped headlight with a Sylvania Silverstar. MUCH better improvement over the stock bulb. Can comfortably drive with low beam on now!
2004 KLR650
Old 11-06-2012, 07:19 PM   #4185
XDragRacer
Oddometer: 3,172
Glad you found improvement in your lighting!
Not trying to one-up your modification, just pointing out another approach to Generation 1 lighting, this bulb:
http://www.tpimotorcycleparts.com/in...category_id=29
Draws 80 watts on low beam, 60 watts on high; low beam projects a "box" of light, creating a lighted rectangle where the beam strikes the riding surface; "day and night" difference compared with OEM lighting.
Bulb can be inserted, "plug-and-play," but much better with a dual relay harness; brighter, and spares the handlebar switchgear the full filament current.
XDragRacer is offline   Reply With Quote
Times are GMT -7.   It's 05:31 PM.
