Old 11-12-2012, 07:26 AM   #4231
Aprilia
Oddometer: 746
Originally Posted by The Stew View Post
Yeah I screwed up royal and drilled down and to the front busting threw the plug for about a inch before I noticed I was way off. Was able to wallow it back true though via the other side but now there is a hole in the plug in the center. Everything is back up and installed and it feels stronger then hell but I just feel bad that I manged to screw up that bad.
Now to finish poping the dent out of my gas tank (from the PO) and painting it red to match the plasic. Hoping to get it all sanded and preped today. Siphon the gas out, sand with 150 wet then 1000 then hit it with cleaner. Hoping it isnt as time consuming as it sounds.
I'm not a professional painter but I have painted for many years. As always you should refer to the Materials Data Sheet available for you paint product but in all the years painting with many types of paint no manufacturer will suggest going from a 150 grit to 1000 grit. Two issues....you'd spend way way way too much time trying to remove 150 grit scratches using 1000 grit and no paint will properly adhere to a surface properly sanded to 1000 grit. Most manufactures do not want anything finer than 400grit for best adhesion and final look. Always use the least amount of grit paper to do the job then use each and every grit subsequent till you arrive at the recommended sanded substrate. Example: If the job/fix requires 100 grit then sand with 150, 220, 280 then 320. If you can get away with starting with 220 then you only have to use 280 then 320.
1000 grit is used as a step in the final polish of the clear coat. I generally start with 1500 then 2000 then 2500 before breaking out my machine polisher which also goes through a number of compounds before final buff.
Paint job outcome is directly proportional to the time spent prepping. You can teach a monkey to paint but takes time/experience to prep for a nice outcome.
Aprilia is offline   Reply With Quote
Old 11-12-2012, 10:54 AM   #4232
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,970
Originally Posted by Drybonz View Post
All clutch components are stock !! a mod was done on lever, to cure excessive clutch travel.
I've ordered in new bits in the meantime, somehow i get the feeling ill be sitting with excessive travel soon
Still, something is causing the difficulty squeezing the lever. I too have the 2HE clutch arm mod. (2-Headlight Ernie is an inmate here. You might contact him about the breakage.)
Have you taken the clutch cover off yet to take a peek?
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 11-12-2012, 11:37 AM   #4233
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,250
Or even just pulled the clutch arm out of the case? I've seen pictures of one that someone tore up, ended up just being the arm needed to be replaced.
sandalscout is offline   Reply With Quote
Old 11-12-2012, 12:05 PM   #4234
The Stew
Why not Zoidberg?
The Stew's Avatar
Oddometer: 50
Fantastic, thanks man. Im a complete noob when it comes to painting and I was just going off of what I was told by another newbie. Thanks again!
2006 KLR650 Aztek Red / SW Motec Bars, Givi Top Case, Tank Bag, PMR Rear Luggage Guard, IMS Pro pegs, Mirror Relocation mod, Moose Folding Shift Lever, Gold Valve Cartridge Fork Emulators, T-Mod, Coleman Seat Cover, Tusk D-Flex Handguards, Horse Saddlebags, Drill Through Subframe Upgrade, 12.9 Bolts, Doohickey, 16TFS, AGM Battery, AeroLED Tail Light
The Stew is offline   Reply With Quote
Old 11-14-2012, 06:45 AM   #4235
Drybonz
Oddometer: 4
I took the cover off had a look, the flat section on the end of the clutch rod was lying in the sump
the clutch arm/actuater (that connects to the cable) is chewed up
2 of the stalks (that the springs bolt onto) in the clutch hub are cracked at the base
It almost seems as if the clutch arm was turning two far and broke the clutch rod,
my new bits will arrive on Tuesday, hopefully everything will come right
I want to ride my bike !!!!!!!
Drybonz is offline   Reply With Quote
Old 11-14-2012, 07:53 PM   #4236
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,285
So for a total idiot when it comes to motorcycle tires, what do you guys suggest as an AT style tire that handles well in damp weather conditions as well?
2004 KLR650
Team Hitec, Customer support Representative.
XpressCS is offline   Reply With Quote
Old 11-14-2012, 08:35 PM   #4237
lexluther11
Ride,Eat,Rest-Repeat
lexluther11's Avatar
Oddometer: 1,197
K60 Scout
lexluther11 is offline   Reply With Quote
Old 11-14-2012, 10:16 PM   #4238
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 409
Opinions on replacing the stock spark plug??
Are the upgraded type (Irridium, E3, Split Fire) worth the money for a stock 09 KLR?
I am tearing into the bike this weekend to complete a few projects and will have the tank off.
So I figured this would be the time to replace it for good of service.
Thanks,
Craig
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 screwed with this post 11-14-2012 at 10:17 PM Reason: punctuation
schaffer40 is offline   Reply With Quote
Old 11-14-2012, 10:21 PM   #4239
ParaMud
ParaMud's Avatar
Oddometer: 628
Just ordered a bunch of stuff for the klr last weekend and have been receiving it. Go happy trails nerf kit/highway peg/ bash plate for one of the bikes. Got a new Brake lever for the other KLR, and took the battery back to cycle gear to warranty it. The battery only lasted 2 months. Also got a bigger windscreen for me. And a carb vent for the other bike. And luggage for the other bike.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 11-15-2012, 04:33 AM   #4240
2whlrider
2whlrider's Avatar
Oddometer: 965
Thanks,
Craig
On two wheels....That's my Happy Place!
2whlrider is offline   Reply With Quote
Old 11-15-2012, 05:01 AM   #4241
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,868
Thanks,
Craig
I have used the Irridium exclusively from day one. Yes, it gives 3 more HP, cleans the pipe out and lasts forever!
Actually, I have used it exclusively fr 45K miles - change it out at 15K. Buy it at your local auto parts store- much cheaper that on-line. Never had any issues with them. Are they any better than regular - who knows? Why do I use it - because I like the technology associated with it.
Tsotsie is offline   Reply With Quote
Old 11-15-2012, 05:04 AM   #4242
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,213
Thanks,
Craig
Originally Posted by 2whlrider View Post
Like anything, its up for argument. But in my very humble opinion... no. There's no noticeable benefit to an "upgraded" spark plug. The recommended NGK will give very reliable spark and excellent longevity, assuming proper jetting.
Again... MHO.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 11-15-2012, 05:22 AM   #4243
Gallowbraid
Gallowbraid's Avatar
Oddometer: 832
Originally Posted by lexluther11 View Post
K60 Scout
The K76's are also VERY good in wet, but are more street oriented. They do well off road in everything except mud. YMMV
You might be a KLR owner if:
You think mud is a good paint protector
Winterizing just means putting a tarp over it till tomorrow
You hit Home Depot and Tractor Supply for parts before you go to the motorcycle shop.
Every time you look at anything square shaped you think "Could that be a pannier?"
You like humvees and hate H2's
You've gone into an Army Surplus store to look for riding gear.
Gallowbraid is offline   Reply With Quote
Old 11-15-2012, 05:24 AM   #4244
Gallowbraid
Oddometer: 832
That's good stuff right there.
Old 11-15-2012, 09:08 AM   #4245
XpressCS
XpressCS's Avatar
Oddometer: 1,285
That's what I have on the rear right now, and IMO the handling is absolutely dreadful off anything but pavement. Will the K60's work with the stock wheel (since I see they are tubeless)?
Like I said I'm somewhat clueless when it comes to motersickle tires
Any other suggestions? Something that wears well on the road would be nice.
2004 KLR650
XpressCS screwed with this post 11-15-2012 at 09:20 AM
Times are GMT -7.   It's 02:21 AM.
