11-25-2012, 05:52 AM
#4366 | |
Oddometer: 303
Yep. What he said. .
The older I get, the faster I was. It's all about attitude & timing. I'm not sure where we're going, but this road seems to be paved with good intentions. |
11-25-2012, 07:25 PM
#4367 |
Oddometer: 1,777
Just curious. I picked up a new to me 2009 KLR 650 this afternoon, rode it about 13 miles, and noticed the temperature gauge didn't move. Is this a normal thing, or do I need to start checking connections?
11-25-2012, 07:48 PM
#4368 |
Gorilla Adventurer
Oddometer: 1,951
Sounds normal. It doesn't move much. Don't worry about it.
bikes |
11-25-2012, 07:56 PM
#4369 | |
Oddometer: 372
Regardless... http://www.watt-man.com/Information__Articles.html (Buy and install a Thermo-bob) |
11-25-2012, 08:08 PM
#4370 |
Gorilla Adventurer
Oddometer: 1,951
I was wondering how long it would take for someone to suggest that.
OK, you're also going to NEED a doohickey, fork brace, lowering links, raising links, 16t sprocket, extended shifter, sarg seat, heat, offroad pegs, new tires, gps outlet, bar risers, locktite, highway pegs, 705 kit, tall shield and on and on. Better sell it now. They're all lemons and NEED another $1500 dumped into them to keep them on the road.
bikes |
11-25-2012, 08:31 PM
#4371 |
Artful Tagger
Oddometer: 3,423
Don't think many would argue with needing loctite :-)
Adam 86 KLR250 01 KLR685 06 K1200LT As ever, buyer and seller of all things KLR KLR Doohickey Wrench available! The North Florida Tag-O-Rama wants YOU! |
11-25-2012, 08:37 PM
#4372 |
Oddometer: 372
If I were to leave a KLR650 as stock as possible, no matter what I'd still want to upgrade the doohickey with EM parts, upgrade the subframe bolts, and install a Thermobob, and adjust the idle mixture screw...all those mods go a long way while still keeping things as simple as possible. That's all just my opinion. And I myself think Watt-man's site makes a pretty damn good case for the Thermobob especially if you do any cold-weather riding.
11-26-2012, 04:55 AM
#4373 | |
Keyboard Adventurer
Oddometer: 344
11-26-2012, 06:42 AM
#4374 | |
Oddometer: 1,076
When (if) we get a somewhat nice day here I'll pull the windshield off and try it, then after that pull the front fender and try again. Can't hurt to try it. I keep hearing good things about the fork brace, I'll probably get one over the winter depending on how work goes. There are no leaks that I can see. I'm only 150lbs, shouldn't be an issue. The suspension still feels soft to me though, I'm used to motocross bikes. |
11-26-2012, 07:05 AM
#4375 |
Tire Tester
Oddometer: 6,190
I corner real hard and you can see the forks flex without the fork brace.
But if it wobbles even riding more "sedately" I think it is likely the big honking shield. My wobble didn't come until well past 75 with the stock shield and/or fender.
Roll The Bones IV- What's coming next? http://www.rollthebonesrally.com/ "If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy screwed with this post 11-26-2012 at 07:11 AM |
11-26-2012, 11:13 AM
#4376 |
'tard bike restos
Oddometer: 435
244 rear, K270 front: here's why
I like the Shinko 244 on the back because the outer lugs are bigger/flex less than the Kenda 270 when the bike is leaned over on pavement. However, I like the Kenda K270 on the front because it comes in a bigger size (3.25 vs. 3.00) than the Shinko.
08 KLR, 06 KLR w/Sputnik sidecar, 72 CB350F |
11-26-2012, 03:15 PM
#4377 | |
Wannabe
Oddometer: 928
Although I don't think the fork brace would have mattered. I believe it was truly an out of balance problem. |
11-26-2012, 05:13 PM
#4378 |
Tire Tester
Oddometer: 6,190
Ahhh. That brings up another hopefully remote possibility. Jules. Have you checked your spokes? I had to have my Big Ugly BMW GSAdv wheel re-trued to get rid of a disconcerting wobble. I have had a spoked wheel collapse on me before. Not fun. That'll make you shit yourself.
11-26-2012, 05:14 PM
#4379 |
Where to next?
Oddometer: 593
Shock Swap
Can anyone tell me if a 1st Gen rear shock will fit on a 2nd Gen KLR?
I can get a Cogent shock from a 1 Gen for a good price but need to know if it will fit my 2nd Gen. I've heard the only difference is a longer lower bolt.
On two wheels....That's my Happy Place! |
11-26-2012, 06:06 PM
#4380 |
Oddometer: 372
They list different shocks for Gen 1 and Gen 2 bikes on their website. I'd call them, if they don't know the answer off-hand someone should be able to look at both and tell you if they are compatible.
