12-11-2012, 04:46 PM
#4516 |
Oddometer: 126
The biggest thing is that if you decide to do a 685 kit (or alone those lines) I think you need a different cylinder. Beyond that, check the doohickey and broken/missing bolts, and ride the wheels off it. As far as parts, very little has changed on these bikes in 25 years. Finding parts really isn't an issue.
Lincoln "Motorcycles are no more dangerous than cars, they are just less forgiving of mistakes" |
12-11-2012, 05:26 PM
#4517 | |
Oddometer: 667
KLR FAQs
This is well worth reading: http://www.bigcee.com/klr650faq.html#knownissues I would pull the valve cover, check the valve clearances and pull the cam bearing journal caps one at a time to ensure they're still in good shape. There's some pics in this thread showing what it looks like when the journals start galling: http://www.advrider.com/forums/showthread.php?t=671941 If the cam bearing journals are showing signs of galling, repair is very expensive (requires a new head). I guess what I'm trying to say is that what initially might appear to be a good deal may not be if you need to throw a lot of money at it later.
Spending my daughter's inheritance one motorcycle at a time. Bikes currently owned: - '91 Honda GL1500 Goldwing with CSC Friendship sidecar (highway pig), - '92 Kawasaki KLR650 with DMC Enduro sidecar (country cruiser). |
12-11-2012, 06:21 PM
#4518 |
Oddometer: 2,047
Actually,1996 got the newer cylinder and other updates.
Its 1996-2007.
2008 KLR 705 2001 GAS GAS 321 |
12-11-2012, 06:38 PM
#4519 |
Artful Tagger
Oddometer: 3,423
Provided it doesn't need anything, $800-1000 for a runner ain't bad.
Adam 86 KLR250 01 KLR685 06 K1200LT As ever, buyer and seller of all things KLR KLR Doohickey Wrench available! The North Florida Tag-O-Rama wants YOU! |
12-11-2012, 07:29 PM
#4520 |
aka Shifter
Oddometer: 218
The conclusion: There was still air in the system. We took the lever off. Used a 1/4" ratchet extender to push the piston farther than the lever was capable of. There was basically about an 1/8" of travel. Once that pushed the rest of the air out, we continued a couple more pumps and pressure built right up.
The really good news is that it was all worth it because this new CZR system is much more powerful than my stock system was. Thanks to all for the help.
Thanks flea market. |
12-11-2012, 08:50 PM
#4521 |
Oddometer: 341
12-12-2012, 07:27 PM
#4522 |
Oddometer: 2,047
12-13-2012, 05:10 AM
#4523 | |
KX & CR 500 Rider
Oddometer: 311
A land speed record on a KLR yea right. http://www.youtube.com/watch?v=evOOEnOYuOk
Go faster than everyone. Only worry about what's in front of you. '08KX500AFC(my favorite) '07KLR650 '04KX500(street legal) '97CR500R '06KLX250(351cc kit) '08KFX450R quad Danger4u2 screwed with this post 12-13-2012 at 08:09 AM |
12-13-2012, 08:02 AM
#4524 |
Oddometer: 506
Ok, a question for the KLR electrical gurus......
According to the factory and Clymer manuals there is a yellow/black wire running from the CDI to the starter relay. This is only present on 1990 and later models. What purpose does it serve, and will there be any issues running a 96 harness (with the wire) on an 89 motor???? Thanks for any input. .
SRX600 SRX250 SR500 KLR650 |
12-13-2012, 08:24 AM
#4525 | |
Oddometer: 2,019
Before you swap out wiring harnesses, I'd suggest you take your ohm-meter and run a continuity check between the CDI and the starter relay connections and ground, with and without the BLACK/YELLOW wire connected to each terminal. If the terminals show continuity with ground without the wire, looks like machts nichts to me, suggesting the '90-and-later connection might be for redundancy and insuring a low-resistance path to ground. Postulation and inference, only! XDragRacer screwed with this post 12-13-2012 at 08:31 AM |
12-13-2012, 08:43 AM
#4526 |
Oddometer: 506
But very much appreciated That diagram looks very different from the one shown in the Clymer... they show it as being a direct connection, not tied into the normal ground circuit ![]() .
12-13-2012, 08:56 AM
#4527 |
Oddometer: 42,616
http://www.youtube.com/watch?v=C6cxNR9ML8k |
12-13-2012, 09:24 AM
#4528 |
mcpenner
Oddometer: 115
Speaking of wiring, I was looking behind my fairing (05 klr) and noticed two open wires with connector plugs. Are these open and available to connect things to? If no, what is missing on mine. If yes, can I use them for lights of usb charging port or ??
12-13-2012, 09:32 AM
#4529 | |
Forever N00b
Oddometer: 1,603
I use mine to turn on a relay in my extra dashboard The relay controls a larger-gauge circuit and provides power to GPS, jacket, etc. that I don't want powered when I turn off the ignition. If it was only USB (5V, .5A or 1A) I'd connect the two city-light terminals directly to the USB converter.
Motorcycles are magical. |
12-13-2012, 09:41 AM
#4530 |
mcpenner
Oddometer: 115
[QUOTE=Grinnin;20240898] They ARE available. One is positive and one is ground. The positive is switched with the ignition.
Thanks Grinnin, that makes me happy I was about to start wiring up from the battery to install a charger and a plug for my vest. So much easier. How much can those little wires take? I think my max would be electric vest, GPS or phone, and heated grips??
