12-18-2012, 07:13 PM
#4561 |
Oddometer: 115
Water in the Air Box and Carb
Hey guys, My 2012 has 4000 miles on it and I just tested it a month ago through some off roading. I'm very much a novice at this but I'm learning. Anyway, I made it through a deep water crossing (it was awesome). DIdn't notice until later on the highway the bike was stuttering at around 55 to 70 MPH. Figured it was the carb (hopefully not a manufacturing defect) took it to my local shop and they said there was water in the air box and carburator and they cleaned it out as well as the air box (no defects). The only thing I did before was open the carb float drain which did seem to help. I have the Clymer manual and I'm slowly figuring stuff out. I can do the float drain and possibly the air box but as of right now, getting into the carburator I'm hesitant to do. I enjoy water crossings and I'm guessing this is something I'll need to learn (love the pics of guys crossing a river with the level up to the seat). However, I was wondering if you know of some good preventative measures I can take for future water crossings? PS. I love this bike (may need to get another for backup). Thanks!
12-18-2012, 07:25 PM
#4562 | |
Oddometer: 2,047
Watch your wheel bearings if your in the water often, especially the rear one. The bike is easy to work on, learn to do it yourself.
2008 KLR 705 2001 GAS GAS 321 |
12-18-2012, 07:57 PM
#4563 |
Oddometer: 2,019
+ 1, except . . . Tee mod essential on Generation 1 (2007 and prior) bikes crossing water, because carb vent opening is about 10" above the riding surface. Generation 2 carb vent openings sit about 30" above the ground, under the seat. Tee mod not as essential on the latter-day bikes, IMHO.
12-18-2012, 10:10 PM
#4564 | |
Oddometer: 3,812
Sent from my DROID RAZR using Tapatalk 2
"Deeply flawed people make deeply flawed decisions." |
12-19-2012, 05:30 AM
#4565 |
KX & CR 500 Rider
Oddometer: 311
My thought also. With no increase in idle rpm I'm thinking no increase in enrichment gas. I want to eliminate any out in the field problems that may occur. With the exception of my street bike all my bikes have the chock at the carb. I'm used to reaching for the carb. Makes carb. service easy, don't have to worry about breaking the cable entry at the carb. One less cable under the tank.................
Go faster than everyone. Only worry about what's in front of you. '08KX500AFC(my favorite) '07KLR650 '04KX500(street legal) '97CR500R '06KLX250(351cc kit) '08KFX450R quad |
12-19-2012, 06:50 AM
#4566 | |
Occasional Venturing
Oddometer: 665
12-19-2012, 07:37 AM
#4567 | |
Oddometer: 2,047
http://www.steadengineering.com/prod...2&categoryId=1 This piece uses the spring and piston from your stock cable.I think this is the proper set up.
12-19-2012, 06:32 PM
#4568 | |
Oddometer: 115
12-19-2012, 07:24 PM
#4569 |
Artful Tagger
Oddometer: 3,423
Gotta have some sand or debris in the carb jets, also double check the choke fitting is on correctly.
Adam 86 KLR250 01 KLR685 06 K1200LT As ever, buyer and seller of all things KLR KLR Doohickey Wrench available! The North Florida Tag-O-Rama wants YOU! |
12-19-2012, 09:14 PM
#4570 |
Luminous nut
Oddometer: 285
BUT... Think about when all of that gas is dumped into the storage tanks... It is now "blended" again ;)
My current garage: -2004 Kawasaki KLR650, Rigid Dually LED lamps (DD) -1996 Jeep Grand Cherokee 5.2L V8 (Donor) -1989 Jeep Wrangler, stripped to the bone (Transplant-ee) -A boatload of 80's 3 wheelers |
12-20-2012, 06:31 AM
#4571 | |
Oddometer: 3,812
12-20-2012, 07:04 AM
#4572 |
Oddometer: 2,019
No advocacy, just one approach to simplifying the "choke" situation; Drag Specialties cable; stem shortened, threaded and re-knobbed for KLR service; stock enrichment plunger and spring attached:
![]() Cable friction adjustable. Made for Harley CV40 application; fits seamlessly with KLR CVK40. |
12-21-2012, 12:33 PM
#4573 |
Shorty on the 650
Oddometer: 462
Hello everyone - I don't post on this thread very often but I need some help with paint.
last summer I painted my ugly green KLR red with Krylon Fusion plastics paint. It came out horribly so I am thinking about using Plastidip. Any tips or tricks? Anybody have experience painting bikes? Let me know!
- Mel Long Way Back - Ongoing Not all those who wander are lost 2002 Kawasaki KLR650 |
12-21-2012, 01:16 PM
#4574 | |
Oddometer: 277
another time i had a similar problem and it turned out to be a small flying insect in the float bowl..it would plug the main jet from time to time.
HEY. did you see something fall off my bike? I mean other than me. "They see me coming on my KLR......They hide their daughters and their PBR...... I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. " |
12-21-2012, 01:23 PM
#4575 | |
Oddometer: 277
once you figure out the right distance to spray it from it creates a beautiful shark skin texture and is very durable. last weekend i painted my entire f150 super crew with it and it looks absolutely amazing. like a $5k pro murder job. every time i come out of a shop there are people petting the truck and waiting to ask where i got it painted. there is some trial and error and basic prep involved so YMMV. but it is $11 a can and you could probabably do a klr in 2-3 cans. shake the hell out of it and shake it every 30 seconds or so while spraying....buy a can and practice and it will look the bomb. many light coats are the secret...let it build over time not a few thick coats...it will run.
