Old 12-21-2012, 02:31 PM   #4576
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 596
Originally Posted by astrolump View Post
i would recommend duplicolor truck armor water based spray on truck bed liner.
once you figure out the right distance to spray it from it creates a beautiful shark skin texture and is very durable.
last weekend i painted my entire f150 super crew with it and it looks absolutely amazing. like a $5k pro murder job. every time i come out of a shop there are people petting the truck and waiting to ask where i got it painted. there is some trial and error and basic prep involved so YMMV. but it is $11 a can and you could probabably do a klr in 2-3 cans. shake the hell out of it and shake it every 30 seconds or so while spraying....buy a can and practice and it will look the bomb. many light coats are the secret...let it build over time not a few thick coats...it will run.
So what do you mean by shark skin texture? I don't want a matte or flat finish, although i'm sure I could add a couple gloss layers. Do you have the exact name of the paint handy? cause I'm sure they have a couple different kinds and I want to get the right one. Another question... does it need a primer of any sort?
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 12-21-2012, 03:13 PM   #4577
astrolump
astrolump's Avatar
Oddometer: 787
oh...it is defiantly a matte finish...i thought that is what you were going for with the plasti dip.
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 12-21-2012, 03:16 PM   #4578
KamikazeKLR
Shorty on the 650
Oddometer: 596
Thats fine. I was gonna put clear on it anyway to protect the paint. So it actually shouldn't be a problem.
- Mel
Long Way Back
Old 12-21-2012, 03:24 PM   #4579
hh76
Oddometer: 29
I had a similar problem this summer with my 01 klr.........all signs pointed to the carb but it turned out to be a failing voltage regulator. it was overheating and shutting down at higher speeds causing bad missing. once i replaced it the problem went away and i saw a rather dramatic increase in performance than i was feeling before. i guess it was going bad for some time.
another time i had a similar problem and it turned out to be a small flying insect in the float bowl..it would plug the main jet from time to time.
One mantra I've learned when dealing with old bikes is "when it feels like a carb issue, check the electrical"
Two things water can do easily
-mess with fuel/ air
-mess with electrical connections
hh76 is offline   Reply With Quote
Old 12-21-2012, 04:06 PM   #4580
Hessian42
Hessian42's Avatar
Oddometer: 169
Originally Posted by Hessian42 View Post
So i'm currently in california on my "miami to patagonia trip" and i've put roughly 7 thousand miles on my 99 with no issues what so ever (totall miles 14k). Recently i started noticing a intermittent slight loss of power around the 3-5k band in any gear. To me it feels like a fuel issue though it's hard to tell. the idle is set at 1,500 but seems a bit erratic (though i blame the constant changes in altitude) The carb was soaked/cleaned and a new full kit was thrown in before i began the trip. I'm also running two .40 needle shims and drilled the slide hole. i'm running a raptor 660 petcock and threw in a iridium NGK plug at home. i run strictly 87 octane and have ran a bottle of sea foam half per full tank 2 tanks in a row at every oil change. Been changing the oil every 2k on the trip with rotella 15/40. it's always come out clean. magnetic drain plug is also clean. (doohikey and torsion spring done). thought maybe the gas cap vent might be clogging up? didn't touch it before the trip. is there more ethanol in the gas in california could this be the cause? The bike is getting about 180-200 miles per tank before reserve and i'm carrying around 80lbs of gear, i'm 210lbs fully geared up. so the millage isn't bad. not sure where to look other than breaking the carb apart and the also the gas cap.
any clues would be greatly appreciated!!!!
so to keep it fresh i quoted myself. Anyhow so it's gotten a bit worse as today in 3rd/4th anywhere below 5k it would bog bad. On a unrelated but related note my primus omni fuel stove hadn't been running as it should and this morning while breaking camp i decided to break it apart. (i run it on the same gas as the bike 87) Well there was a big ball of gummed up ethanol restricting the fuel where the fuel line meets the brass flame control knob/ valve. it was almost completely blocked. I'm wondering if my constant change of altitudes sea level to as high as 9,000ft as well as the temp fluctuations 15-70 degrees has anything to do with the ethanol doing what it did?! Anyhow i'm buying a couple of cans of carb cleaner and taking the fucker apart tonight. I'm also checking my plug just to see how she's burning and was wanting to clean out the gas cap vent system.
does anyone have a link handy for the gas cap cleaning procedure?
my petcock seems fine. i turn it off every night and it was a brand new manual raptor 660 unit when i started the trip. in any case i'm carrying a rebuild kit for it.
It's just a ride...
http://hessianforpatagonia.blogspot.com/
Hessian42 is offline   Reply With Quote
Old 12-21-2012, 04:55 PM   #4581
coop74
Deal's Gap Junkie
coop74's Avatar
Oddometer: 2,215
Originally Posted by Kent Glasscock View Post
Okay. Got the bike back this evening. Still doing the studder. The shop had photos where there was water in the air box and carb. So that was diagnosed and cleaned out. But basically between 45 to 65 it just stats to stutter for a few seconds and then clears out. It was doing it on the 25 mile ride back home. I'm taking it to the beach this weekend so I'll just deal with it. I'm now guessing valve clearance or jetting, maybe a choke thing? I ride it every day to work. This is really starting to piss me off. Thanks.
did you drain any water out of the float bowl in the carb? It is very easy to do.
Robert "Coop" Cooper
Vstrom 1K
KLR650
coop74 is offline   Reply With Quote
Old 12-22-2012, 08:44 AM   #4582
Kawidad
Kawidad's Avatar
Oddometer: 4,811
I did this on my side panels and it didn't work all that well. Because they are made out of flexible plastic, the liner stuff would flake off. The liner is made to attach to rigid steel and not flexible plastic. I did it several times in several different ways, including an adhesion promoter and nothing worked. In the end, I had to strip it off and go with paint.
You'd be better off with the rubberized sound deadener sprays.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-22-2012, 08:46 AM   #4583
Kawidad
Kawidad's Avatar
Oddometer: 4,811
Did you try Sea Foam or Techron or alike fuel additives? California gas blends are horrible and age very quickly. It is very easy to get bad gas in Commiefornia, especially the winter blends.
Old 12-22-2012, 09:06 AM   #4584
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,911
Originally Posted by Danger4u2 View Post
My choke cable froze up 2 weeks ago, it would not return to the off position. Since it is not a true chock (it's a fuel enrichment circuit) it wasn't a problem driving home until I would hit a stop light. I decided to take it the way of the kick stand/ clutch safety switches. Out of the equation. I ordered the start plunger for a 2006 KLX300R (KLX300- A6F) Part # 16016- 1068. http://www.servicehondapsn.com/fiche...006&fveh=27705
It might take some getting used to, reaching for the carb but if you own a dirt bike or a KLK250S it won't be a problem, you've done it before. The tip looks a little different but it still works just like the original. Plunger was $23.00 compared to the cable at $16.17. I used angled needle nose pliers after removing the gas tank.
Independently, I just bought the same part to replace my broken choke cable.
With the IMS tank, I'm troubled that it will be a PITA to choke the bike. Also, I'm wondering if, when installed, your new choke plunger stays "out" or does the spring snap it back in? If it's difficult for me to reach AND I have to hold it out, it might be a deal-braker for me.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 12-22-2012, 10:01 AM   #4585
Kawidad
Kawidad's Avatar
Oddometer: 4,811
No problem with either of those. It snaps into the outer position and then springs back in with just a touch of the finger. Pulling it out is kind of a pain, but pushing it back in is very easy IMO. There is no half choke as previously mentioned.
Old 12-22-2012, 04:02 PM   #4586
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 633
It stays out. No half choke unless you hold it.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 12-22-2012, 04:19 PM   #4587
SteelB12
SteelB12's Avatar
Oddometer: 2,717
WTF?!! I only got 206 miles before I had to hit reserve. I didn't think I was that heavy on the throttle recently. Wonder if its something else
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is online now   Reply With Quote
Old 12-22-2012, 04:30 PM   #4588
Kawidad
Kawidad's Avatar
Oddometer: 4,811
Have you rejetted? When I switched to a KLX needle I noticed that a single clip setting affected the MPG quite significantly.
Old 12-22-2012, 05:23 PM   #4589
SteelB12
SteelB12's Avatar
Oddometer: 2,717
I did that 22 cent deal 3 years ago and this is the worst gas mileage I have gotten. I didn't do any off roading, just commuting. I guess I have been heavyon the wrist and just don't remember it
2009 KLR650
Old 12-22-2012, 07:07 PM   #4590
Aprilia
Oddometer: 707
Curious...did you encapsulate the entire plastic pieces? I ask as I have a neighbor who owns a local bed liner spray franchise and he said the only way he can get it to last on plastic bike panels is encapsulate the whole piece in a single application.
Aprilia is offline   Reply With Quote
Times are GMT -7.   It's 10:10 PM.
