Old 12-22-2012, 06:43 PM   #4591
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 672
Rhino Liner truck bedliner coating
I had my my gas tank and sidecovers sprayed with rhino liner this summer. They sprayed both sides of the side covers, and underside of the tank too, as suggested, basically fully encapsulating. I did all the prep myself... sanded the plastic thoroughly with rough 60 or 80 grit sandpaper. On the tank, I removed the decals, and sanded with about 120 grit. I thoroughly wiped 'er all down with acetone and brought it for spraying... cost me $100 to get done. No sign of lifting anywhere, and it's held up extremely well.
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned:
- '91 Honda GL1500 Goldwing with CSC Friendship sidecar (highway pig),
- '92 Kawasaki KLR650 with DMC Enduro sidecar (country cruiser).
GreatWhiteNorth is offline   Reply With Quote
Old 12-23-2012, 07:19 AM   #4592
Kawidad
Kawidad's Avatar
Oddometer: 3,821
Originally Posted by Aprilia View Post
Curious...did you encapsulate the entire plastic pieces? I ask as I have a neighbor who owns a local bed liner spray franchise and he said the only way he can get it to last on plastic bike panels is encapsulate the whole piece in a single application.
I was referring to the canned Duplicolor product not the commercial type of bedliner. I haven't tried that stuff, but whatever is chosen it has to maintain flexibility because the plastic is so flexible.
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Old 12-23-2012, 09:08 AM   #4593
WilsonGermany
WilsonGermany's Avatar
Oddometer: 69
I like the klr ;) look at this...
http://www.youtube.com/watch?v=cp6sO...=ULMWuEomAKYDc
Day1.1
WilsonGermany is offline   Reply With Quote
Old 12-23-2012, 11:17 AM   #4594
FAW3
Old wanderer
FAW3's Avatar
Oddometer: 311
Day1.1[/QUOTE]
Very nice video....thanks for sharing it. You had a great journey.
FAW3 is offline   Reply With Quote
Old 12-23-2012, 12:52 PM   #4595
Kent Glasscock
Kent Glasscock's Avatar
Oddometer: 116
Originally Posted by astrolump View Post
I had a similar problem this summer with my 01 klr.........all signs pointed to the carb but it turned out to be a failing voltage regulator. it was overheating and shutting down at higher speeds causing bad missing. once i replaced it the problem went away and i saw a rather dramatic increase in performance than i was feeling before. i guess it was going bad for some time.
another time i had a similar problem and it turned out to be a small flying insect in the float bowl..it would plug the main jet from time to time.
Thanks. I'll definately put that on the list. It's weird though being that this bike isn't as old so could be a defect which should be covered under the warranty. On another note, I put some fuel cleaner on a 6 hour ride Saturday. Didn't make a difference. However, I put some Supreme fuel in and it ran better but still skipped some. My mechanic assures me they cleaned out the whole carb and air box. Even drained the fuel tank. In summary. The bike runs. I had it to 78 on the interstate. Just every now and then. It will studder that lasts 2 to 5 seconds and stops. I do not seem to notice it when shifting. Only notice at cruising speeds. Next plan is to take it to a kawi dealer and have them pinpoint the problem. May help to get a second opinion. It's a learning process with this bike. I understand.
Kent Glasscock is offline   Reply With Quote
Old 12-23-2012, 04:03 PM   #4596
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,074
This concern sounds similar...
I fought a cutting out/stuttering problem on my 09 this past summer, Kept acting like I had contaminated fuel, I commute 55 miles one way and it would always occur after about 30 miles, drained the float bowl a couple of times, tried numerous attempts at fixing, I really didn't want to pull the carburetor, bike finally left me stranded one morning on the way to work, Had to have it towed home, came home that night and cleaned the carb. Never saw what the issue was but haven't had a repeat of the problem in the past 3K mikes.
On another note, checked my valve adjustment today, it's been 19,500 miles since the last adjustment Right side intake at .006, left side intake at .008 and both exh at .009 . I won't be messing with it again until about 45K Currently have just under 32K. Love this bike. Spark plug looked nice, tan colored regapped to .030 and put it back in. Much better than the light grey that it used to be with some of the other various items still bolted to the bike. Very nice improvement to rejetting and eliminating some items.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 12-23-2012, 04:26 PM   #4597
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 6,502
It has begun
The winter tear down,maintenance and upgrade of my 2007 KLR.
I had custom made my own crash bars and side case racks a few years ago. They were the first things I ever welded or fabricated and they have held up well so I decided to have them powder coated this year. So those will be the first things off.
Still trying to decide if I want to do the 685 upgrade or not, probably make a decision after the holidays.
How many of you guys are running center stands, any noticeable difference getting hung up off road?
PWRCRZR is online now   Reply With Quote
Old 12-23-2012, 08:30 PM   #4598
astrolump
astrolump's Avatar
Oddometer: 275
[How many of you guys are running center stands, any noticeable difference getting hung up off road?[/QUOTE]
defiantly. i took mine off after this
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 12-24-2012, 04:17 AM   #4599
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 874
Always carry a chainsaw......
Murphy Slaw is offline   Reply With Quote
Old 12-24-2012, 05:11 AM   #4600
Danger4u2
KX & CR 500 Rider
Danger4u2's Avatar
Oddometer: 312
I do. Chain saw, anti Al- Kida kit, dooms day prepper kit, extra bike in parts, just in case..................................
Go faster than everyone.
Only worry about what's in front of you.
'08KX500AFC(my favorite) '07KLR650
'04KX500(street legal) '97CR500R
'06KLX250(351cc kit) '08KFX450R quad
Danger4u2 is offline   Reply With Quote
Old 12-24-2012, 05:37 AM   #4601
Unstable Rider
World Wide Inmate
Unstable Rider's Avatar
Oddometer: 2,120
Lake Superior this fall.
´¯`·.¸¸.·´¯`·.¸ ><((((((º>
`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º>
´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º>
Everything happens for a reason. "Still seeking the reason"
Unstable Rider is offline   Reply With Quote
Old 12-24-2012, 07:58 AM   #4602
DirtyDog
Lust for dust...
DirtyDog's Avatar
Oddometer: 6,055
Epic top box.
... grease, grit, and mud are runnin' in my blood.
DirtyDog is offline   Reply With Quote
Old 12-24-2012, 08:42 AM   #4603
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 959
Is this the "my top box is bigger than your top box" thread.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 12-24-2012, 09:40 AM   #4604
Danger4u2
KX & CR 500 Rider
Danger4u2's Avatar
Oddometer: 312
I was transporting the box with the KLR to the welder to patch the holes from the previous owners install. I will cut the skirt just under the black line and belly mount it behind the battery box.
Old 12-24-2012, 10:53 AM   #4605
kojack
My bikes Suck!
kojack's Avatar
Oddometer: 787
Well, going to be back on a klr this spring. Trading my sled for one. Hopefully a new left over. There's a couple here so I may swing a deal even swap for one.
Sent from my ARCHOS 80G9 using Tapatalk 2
kojack is online now   Reply With Quote
Times are GMT -7.   It's 05:12 PM.
