Old 01-02-2013, 09:53 AM   #4651
jules083
jules083's Avatar
Oddometer: 3,895
Originally Posted by jtwest View Post
I just bought myself a 2007 KLRs and I am trying to do a "go through" repair replace and maintain. I noticed there is no guard over the radiator. Is it supposed to have one? Where would I get a replacement? I can only see one piece (on the bottom front of the radiator) that would hold onto one.
Here's a pic of mine. I think that support bar was installed by the po, I'm not too sure. Ignore the cardboard, its in the 20's right now. Figured maybe it would help with temp swings.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 01-02-2013, 10:01 AM   #4652
jtwest
Redneck Adventererer
jtwest's Avatar
Oddometer: 2,883
thanks
yeah..mine has the little clip at the bottom but no grill and no screw holes or screws...are those connected to the plastic or the radiator itself?
jtwest is offline   Reply With Quote
Old 01-02-2013, 10:37 AM   #4653
jules083
jules083's Avatar
Oddometer: 3,895
It's all connected to the radiator. I'll get some better pics here shortly.
Old 01-02-2013, 03:49 PM   #4654
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,408
Yes. There is a flimsy radiator screen. Ask me how I know it's flimsy!
Needless to say, another inmate made a steel one for his KLR, and then he made one for mine at my request.
I never installed it as I'm getting as much use out of the $50 replacement OEM one I installed.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 01-02-2013, 09:45 PM   #4655
astrolump
astrolump's Avatar
Oddometer: 821
Originally Posted by ausfahrt View Post
all i can say is....WARP SPEED MR SULU.....ENGAGE!
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is online now   Reply With Quote
Old 01-03-2013, 02:29 AM   #4656
APJ757
APJ757's Avatar
Oddometer: 306
Originally Posted by tommu56 View Post
Same question here 6'3" and I'm pretty far back on seat (no 2 up for me).
Yeah I'm only 5'10 185lbs with a 32" inseam and even I need highway pegs to be comfy 2 up going any kind of distance.
But as far as the bucket on the seat goes the guy who makes them will put it where you want it.
APJ757 is offline   Reply With Quote
Old 01-03-2013, 06:43 AM   #4657
jtwest
jtwest's Avatar
Oddometer: 2,883
I think I see now the plastic is bolted to the radiator but (could) hold a guard as well. Easy fix. Easier than what I noticed happened to the reservoir on the other side. Looks like the bike had been dropped on that side bent the brackets and put a very small unnoticable crack in the res. the PO corrected the problem by not replacing a screw that wouldn't allign.
Are these reservoirs pressurized?
Old 01-03-2013, 06:48 AM   #4658
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,212
Coolant overflow tank. No pressure.
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned: '91 Honda Gold Wing with sidecar, '92 Kawi KLR650 with Enduro sidecar, '94 KLR650, KL250 Super Sherpa.
GreatWhiteNorth is offline   Reply With Quote
Old 01-03-2013, 01:06 PM   #4659
SteelB12
SteelB12's Avatar
Oddometer: 2,851
94 Barbie Throttle cables
I am having a hell of a time getting my throttle cables to work on this bike. The throttle cable setup is different than the 09, and I only have a manual for the 09, so I am working on this on what I think is correct. They are basically the same, but for some reason I just can't get this to work right. The throttle will open the carb, but will not snap back to closed position. I have adjusted the nuts on carb and throttle end several times and can't get it. Any suggestions?? Such a simple procedure and its driving me nuts
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is online now   Reply With Quote
Old 01-03-2013, 02:35 PM   #4660
RandoCommando
Wannabe
Oddometer: 1,408
The cable could be pinched/tight under the gas tank.
MySPOT
Old 01-03-2013, 03:23 PM   #4661
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,398
Disconnect the closing cable off the carb and see if it closes ok without it.
If it does, then adjust open cable properly so you have proper adjustment.
Now reconnect the closing cable and adjust it.The closing cable is for safety in case the return spring on the carb breaks.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-03-2013, 05:00 PM   #4662
SteelB12
SteelB12's Avatar
Oddometer: 2,851
That sounds waaay too simple, it must work. Will try it tomorrow. Thanks for the tip
2009 KLR650
Old 01-04-2013, 04:19 AM   #4663
Grinnin
Forever N00b
Oddometer: 2,779
Tell me how to keep chain adjuster covers moving on my '01.
Silt and fine grit wedge in and bind between the sheet-metal covers and the swingarm. The actual adjusters inside the swingarm stay clear enough. It's easy enough to adjust the chain; turning the nuts pulls the whole assembly along pretty well. But each time I remove the axle, the sheet metal parts are bound about solid.
They fit tight enough -- it doesn't look like I can bend them any tighter and still have them fit on. I use the word silt, because beach sand wouldn't fit. When I clean it all up and reassemble, the covers slide very well.
I'm fishing for someone to tell me of some substance that will keep the grit out. I assemble them dry. Grease would just attract more crap. Anti-sieze may work but it would be messy and would eventually also attract grit. A weak glue may even break free easier than the silt-packed covers.
Anyone else get silt in there?
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 01-05-2013, 05:08 AM   #4664
jules083
jules083's Avatar
Oddometer: 3,895
thanks
Sorry, I took the pictures then forgot to post them.
Old 01-05-2013, 09:09 AM   #4665
RandoCommando
Wannabe
Oddometer: 1,408
Sidecar
Ok KLR gurus.
I'm in contact with the inmate selling this sidecar
http://advrider.com/forums/showthread.php?t=853271
I'll be heading over to look at it, but wanted to ask any of you what your thoughts are as far as mounting it to my 99 KLR.
Anything to look for? Anything I need to buy? Any changes needed to the KLR?
Any and all help would be appreciated it.
MySPOT
Times are GMT -7.   It's 06:04 PM.
