Old 01-05-2013, 10:10 AM   #4666
phideaux
phideaux's Avatar
Oddometer: 3,090
Send a message via Yahoo to phideaux
Originally Posted by RandoCommando View Post
Ok KLR gurus.
I'm in contact with the inmate selling this sidecar
http://advrider.com/forums/showthread.php?t=853271
I'll be heading over to look at it, but wanted to ask any of you what your thoughts are as far as mounting it to my 99 KLR.
Anything to look for? Anything I need to buy? Any changes needed to the KLR?
Any and all help would be appreciated it.
Contact DirtDabber!
http://www.advrider.com/forums/member.php?u=63437
Fido
Iron Butt Association No. 22913
Mrs. Phideaux to her octogenarian friend when the granny wants to know if she can sit on one of my bikes:
"It's Okay, they only fall over when HE'S on them."
North GA Tag-O-Rama Map
Georgia Tag-O-Rama Map
phideaux is online now   Reply With Quote
Old 01-05-2013, 10:26 AM   #4667
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 667
Not a good match
Ok KLR gurus.
I have basically the same sidecar (mine is actually a newer Friendship 1 that opens up to climb in) on my Goldwing GL1500. They are way too big and heavy IMO for a KLR. For a KLR you want something lighter like a Velorex, or a DMC Enduro. Here is a link to DMC's Enduro page (no affiliation but I have one and like it a lot): http://www.dmcsidecars.com/sidecars/enduro/
... and a pic of my setup:
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned:
- '91 Honda GL1500 Goldwing with CSC Friendship sidecar (highway pig),
- '92 Kawasaki KLR650 with DMC Enduro sidecar (country cruiser).
GreatWhiteNorth is offline   Reply With Quote
Old 01-05-2013, 12:07 PM   #4668
mr. matteeanne
mr. matteeanne's Avatar
Oddometer: 13,716
My 09 has a leak on the cooling fins of the radiator, can I just apply JB weld or something else to the affected area to stop the leak?
Don't be surprised.
mr. matteeanne is offline   Reply With Quote
Old 01-05-2013, 12:22 PM   #4669
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 933
I'm really looking to use the sidecar for taking the pooches out. Not a lot of riding.
I want the sidecar to be enclosed for them.
The DMC is nice, but not a good match for my two dogs.
When I'm not taking them for a ride, the sidecar will be off for riding solo.
The fact that this sidecar I want to buy has no seat or carpet inside is a good thing.
With that said, what do you think?
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (soon to be named)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 01-05-2013, 12:45 PM   #4670
DirtyDog
Lust for dust...
DirtyDog's Avatar
Oddometer: 6,039
Yes. To get it to seal properly, I took my rad off completely, rinsed it well (inside and out), baked it in the oven for a half hour to dry, and then applied JB to the hole. Been holding for a year now.
... grease, grit, and mud are runnin' in my blood.
DirtyDog is offline   Reply With Quote
Old 01-05-2013, 01:54 PM   #4671
jtwest
jtwest's Avatar
Oddometer: 898
thanks
[QUOTE=jules083;20400412]Sorry, I took the pictures then forgot to post them.
thanks that gives me some ideas
jtwest is online now   Reply With Quote
Old 01-05-2013, 01:57 PM   #4672
Tsotsie
Semi-reformed Tsotsi
Oddometer: 783
While the JB weld might hold hold for a while, I personally would only do that in an emergency to get home. I would not trust the expansion and contraction of the different materials for hold for too long. I have used a company out of UT called Myler's to weld the AL and fix a bent radiator on my 08.
Tsotsie is offline   Reply With Quote
Old 01-05-2013, 02:45 PM   #4673
Aprilia
Oddometer: 341
See your local radiator shop about using an epoxy specifically for radiator repairs, however, the real fix is to send it out to Mylers for a proper fixing and updating. The stock, genII in particular, is cheaply made/bonded together.
Aprilia is offline   Reply With Quote
Old 01-05-2013, 02:54 PM   #4674
GreatWhiteNorth
Oddometer: 667
Hacks forum
Check out the "hacks" forum sometime. Concensus is taking sidecar off not best idea (for a couple of reasons). For the KLR you need a subframe to bolt the sidecar to (DMC sells a nice one). The CSC sidecar is a nice sidecar, but better suited to a larger motorcycle. Lots of folks use Velorex sidecars to transport their pooches - numerous threads (and pics) on this in the hacks forum.
Old 01-05-2013, 04:17 PM   #4675
MOTOSIERRAGORDA
MOTOSIERRAGORDA
MOTOSIERRAGORDA's Avatar
Oddometer: 3
Send a message via MSN to MOTOSIERRAGORDA
Klr pressure tires
My first post in this forum, i present myself, eduardo ruiz corzo, from jalpan, queretaro, mexico, the sierra gorda, plenty of off roads, plenty of road curves, plenty of scenery, if someone likes to come just tel me.
To the matter..., can somebody tell me the right tire pressure for dual purpose, this is my first klr and is just great!! But the tire dealer says 21 psi is too low....
Help will be appreciated...
EDUARDO RUIZ CORZO
www.transierragorda.net
transierragorda@hotmail.com
MOTOSIERRAGORDA is offline   Reply With Quote
Old 01-05-2013, 04:24 PM   #4676
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,197
Motosierra. Heading down to your area in a couple of weeks with my nephews on our big bikes. I will send you a message about plans.
As to your question I usually keep my KLR tires in the middle of the range for dual sport 30/32. Paved only rides I bump it up to 34/36.
I would be afraid of rocks at 21 lbs.
Edit: I never drop below 24/26 but rarely air it down that low.
Further edit: But I weigh 245. That may change things.
Roll The Bones IV- What's coming next?
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy screwed with this post 01-05-2013 at 04:35 PM
slowoldguy is offline   Reply With Quote
Old 01-05-2013, 04:30 PM   #4677
Aprilia
Oddometer: 341
Welcome! While the KLR is certainly no dirt bike the manufacturers recommendation is about right for all around/light offroad usage with standard recommended tires... 21 front and 28 rear. I've run a bit less with some tires (more dirt oriented while offroad 18-22psi) and more with others. My street tire setup is 32/34psi.
Old 01-05-2013, 06:29 PM   #4678
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 6,499
I am looking for a set of first generation rear turn signals...I have one with a broken housing and no idea how it happened
also looking for input on fork oil weight. Running stock fork tubes with racetech gold valves and straight rate springs for my weight and riding style.
Thinking I am going with Belray 10W unless someone has something to add.
PWRCRZR is offline   Reply With Quote
Old 01-05-2013, 06:43 PM   #4679
MacNoob
MacNoob's Avatar
Oddometer: 1,007
I think you should contact Racetech and ask them what they recommend....
Originally posted by Mark Twain: "There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact."
MacNoob is offline   Reply With Quote
Old 01-05-2013, 07:06 PM   #4680
GAS GUY
GAS GUY's Avatar
Oddometer: 2,047
Belray 10 weight is perfect.
2008 KLR 705
2001 GAS GAS 321
GAS GUY is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
