Old 01-07-2013, 03:46 PM   #4726
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 809
Thinking of trading for another KLR
I keep getting KLR's and then trading for something else, and then coming back to the KLR. Right now, I'm thinking maybe I should have just stuck with a KLR.
Anyone interested in a trade for a 2009 KLX 331 that has about every aftermarket part made thrown on it?
nigelcorn is online now   Reply With Quote
Old 01-07-2013, 04:13 PM   #4727
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,365
Don't feel bad, I'm on my 3rd Klr.
This time I'm staying.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-07-2013, 04:14 PM   #4728
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,209
Yep, me too.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 01-07-2013, 04:36 PM   #4729
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 809
Yeah, I've said that before too. One of these trades it will be true.
Sent from my Nexus 7 using Tapatalk 2
Old 01-07-2013, 04:41 PM   #4730
firewatermetal
firewatermetal's Avatar
Oddometer: 32
I wanted a KLR but i bought a vulcan. I still wanted a KLR. I sold the vulcan (it never needed anything but gas and oil). Now I bought a KLR, working on it all the time, still prefer the KLR.
day job...fwmcreative.com
steed:2004 KLR650
1998 Dodge 2500
firewatermetal is offline   Reply With Quote
Old 01-07-2013, 04:41 PM   #4731
astrolump
astrolump's Avatar
Oddometer: 818
Originally Posted by PWRCRZR View Post
I haven't seen any 12.9 break but again it depends on a lot of other variables. I often load my KLR down with entirely to much stuff then go pound it around all of our trashed back roads, dirt and gravel. So once mine broke I went for what seemed like the strongest repair I could make.
i think the 12.5s should be fine...unless you really like sweet potato pie..then go drill through.
they usually break when they come loose...so red lock-tight and torque them down and you should be fine.
i did the drill through on my 01 klr and i have NO interest in doing it ever again. if i need more that the 12.5 strength ill just weld the subframe on my 04
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is online now   Reply With Quote
Old 01-07-2013, 05:00 PM   #4732
Reagan
Oddometer: 18
I'm on my 3rd KLR too, I was thinking of selling it the other day. Although I would probably regret it. I like to take it out when there is rain, sand, slush, mud or snow on the roads. Otherwise I usually use one of my other bikes. There is something about a KLR, you want to keep one around.
Reagan is offline   Reply With Quote
Old 01-07-2013, 05:28 PM   #4733
Myfuture_yourdebt
Oddometer: 372
I had a forward/upper subframe bolt break while I was riding offroad. Talk about a ruined ride. A screw extractor got it out no problem thank god. I replaced it with Eagle Mike's upgraded bolts (not the drill thru kit) and haven't had a problem since...and I flog my bike offroad like it's 100 pounds lighter than it really is (catch 6" of air every so often).
Myfuture_yourdebt is offline   Reply With Quote
Old 01-07-2013, 06:38 PM   #4734
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,461
Plenty of red and torqued to HT specs. Thanks.
I've never had sweet potato pie.
IDRIDR is offline   Reply With Quote
Old 01-08-2013, 01:18 AM   #4735
XDragRacer
Oddometer: 3,168
Then, I think astrolump would conclude, you're less likely to achieve "OVER GROSS" status in the weight department!
Don't start; sweet potato pie is seductive, delicious, and . . . fattening!
XDragRacer is online now   Reply With Quote
Old 01-08-2013, 03:18 AM   #4736
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,585
IMHO if you carry a heavy load of camping gear and ride a lot of rough roads and some off road loaded as well you "may" still have a problem. That's what I was doing the weekend mine broke loose.
But I agree loose bolts are probably the source of a lot of failures. That is part of the maintenance routine I am doing on my KLR this winter...lots-o-locktite
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 01-08-2013, 07:22 AM   #4737
IDRIDR
IDRIDR's Avatar
Oddometer: 1,461
45 yrs old here and losing weight. Wife left a year ago. I'm on the divorce diet. Works pretty well.
I'll stay away from the sweet potato pie.
Old 01-09-2013, 06:57 PM   #4738
astrolump
astrolump's Avatar
Oddometer: 818
i forgot to mention...if you are using crash bars...then drill through is the way to go...the crashbars put a lot of stress on the upper subframe bolts....
yes sweet potato pie is dangerous...i have moved on to coconut ice cream.
Old 01-09-2013, 08:59 PM   #4739
Randal Gobs
Randal Gobs's Avatar
Oddometer: 6
Be my own mechanic.
I just bought my first bike ever (KLR 650) last year when I turned 60. I haven't worked on a vehicle since I was 23. I need to ease into the maintenance, though, cause stuff like oil change, lube, adjustments etc. is just too expensive at the dealer. I want to get started. Where to begin.
e.g. My electrical system went totally hay wire the other day. Wouldn't start, no juice, so I push started it and got it going. It was at night in traffic so when I turned on turning signal, the High beam started blinking, when i hit the low beam switch the engine wanted to die and a few other wierd things started to happen. The dealer said that it was all caused by a faulty battery and $200 parts and labor for a new battery. Shame on me for not knowing more about how to work on this bike.
I will tell you this though, I love every minute I'm on my bike, it has changed my life.
Randal Gobs is offline   Reply With Quote
Old 01-09-2013, 09:11 PM   #4740
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,949
Pass it my way. Thanks.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Times are GMT -7.   It's 06:39 AM.
