Old 01-09-2013, 09:12 PM   #4741
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,201
Originally Posted by Randal Gobs View Post
I will tell you this though, I love every minute I'm on my bike, it has changed my life.
lol . You are so screwed. Welcome to the asylum.
Roll The Bones IV- What's coming next?
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 01-09-2013, 10:31 PM   #4742
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 929
I just bought my first bike ever (KLR 650) last year when I turned 60. I haven't worked on a vehicle since I was 23. I need to ease into the maintenance, though, cause stuff like oil change, lube, adjustments etc. is just too expensive at the dealer. I want to get started. Where to begin.
e.g. My electrical system went totally hay wire the other day. Wouldn't start, no juice, so I push started it and got it going. It was at night in traffic so when I turned on turning signal, the High beam started blinking, when i hit the low beam switch the engine wanted to die and a few other wierd things started to happen. The dealer said that it was all caused by a faulty battery and $200 parts and labor for a new battery. Shame on me for not knowing more about how to work on this bike.
The good thing: You bought one of the easiest bikes to work on.
The bad thing: You bought one of the easiest bikes to work on.
Like slowoldguy said: Welcome to the asylum.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (soon to be named)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 01-10-2013, 03:30 AM   #4743
tommu56
tommu56's Avatar
Oddometer: 787
Start here
http://www.bigcee.com/klr650faq.html
and the klr650 forum good guys over there too.
http://www.klr650.net/forums/index.php
tom
tommu56 is offline   Reply With Quote
Old 01-10-2013, 04:20 AM   #4744
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,066
Originally Posted by tommu56 View Post
Start here
tom
Don't forget KLR World as well.
- Jonathan
'88 KLR650
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 01-10-2013, 06:36 AM   #4745
beemerjim
beemerjim's Avatar
Oddometer: 300
I found ://www.klr650.marknet.us/ very helpful too.
Jim
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 01-10-2013, 07:08 AM   #4746
ANutt
Keyboard Adventurer
Oddometer: 347
Originally Posted by astrolump View Post
i forgot to mention...if you are using crash bars...then drill through is the way to go...the crashbars put a lot of stress on the upper subframe bolts....
yes sweet potato pie is dangerous...i have moved on to coconut ice cream.
Do all crash bars do this, or just certain brands?
ANutt is offline   Reply With Quote
Old 01-10-2013, 07:38 AM   #4747
IDRIDR
Occasional Venturing
IDRIDR's Avatar
Oddometer: 670
Originally Posted by GAS GUY View Post
Actually, that should be fine, as that is how the stock unit works also.
I am considering this mod, I am going to have to throw my 10 gallon tank on and make sure I will be able to get to it.
Can you post a picture of it on your bike ? Also how many inchs does it stick out from the carburetor?
I didn't measure the length, but here are some images:
The pics above show the cable eliminator enricher (choke) unit purchased off fleabay recently.
IDRIDR screwed with this post 01-10-2013 at 01:38 PM
IDRIDR is offline   Reply With Quote
Old 01-10-2013, 12:57 PM   #4748
Randal Gobs
Randal Gobs's Avatar
Oddometer: 6
Thanks for the info.
Looks like some great info to start getting familiar with.Much appreciated. by the way, I am in Laguna Niguel, CA anyone nearby?
Randal Gobs is offline   Reply With Quote
Old 01-11-2013, 10:20 AM   #4749
Hessian42
Hessian42's Avatar
Oddometer: 131
99 KLR headed to south america with a 205lbs rider (fully geared) and about 100lbs gear/ luggage. Already swapped the rear shock spring to a 8kg spring however the forks are untouched. I have roughly $200 to spend on the forks what's my best bet???
Miami to Patagonia before the end of the world....
http://www.advrider.com/forums/showt...5#post19867595
http://hessianforpatagonia.blogspot.com/
Hessian42 is offline   Reply With Quote
Old 01-11-2013, 10:30 AM   #4750
TengaiJohn
TengaiJohn's Avatar
Oddometer: 3,092
Nothing!!! But since you gringos like to modify the heck out of your bikes I would recommend progressive front springs with Ricoh Intiminators (don't kow if there still is a discount for KLR riders). That's what I did on my front forks and I love them (250lb rider here).
Good luck on your trip and say hello to the minas (you'll get it when you reach Argentina or Uruguay)!!!!
TengaiJohn is offline   Reply With Quote
Old 01-11-2013, 10:30 AM   #4751
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,120
$12 on some BelRay 10w and $188 on Beer w/Shrimp tacos!
Seriously, the stock KLR suspension will get you there and back.... Progressive springs will help prevent bottoming while you're doing any "Ricky Bobby" hero maneuvers.
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 01-11-2013, 10:35 AM   #4752
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,422
New seals...$23
Progressive springs...$80-120
Fork oil...$8 or 25
Heard good things about the Ricor Intimidator valves, but they are ~$170-190 new. Where are you currently located?
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-11-2013, 11:59 AM   #4753
Hessian42
Hessian42's Avatar
Oddometer: 131
Originally Posted by newcastleadam View Post
New seals...$23
Fork oil...$8 or 25
i changed the fork oil to 10W before i left 8k miles ago. will be doing it again before heading south, i'll switch to belray. The seals are in good shape and i'm carrying spares so not touching those unless i have to. Was looking into the springs and maybe a fork brace. or the gold tech emulators and the fork brace. not sure which set up would be the best bang for the buck but i cant afford all three.
Hessian42 screwed with this post 01-11-2013 at 12:16 PM
Old 01-11-2013, 12:40 PM   #4754
Skowinski
Tetrapod
Skowinski's Avatar
Oddometer: 3,424
Pardon my ignorance, but do these devices has set points, e.g. full choke and half choke, or do they slide smoothly so that you can set the choke at the level you want?
"It's not what you look at that matters, it's what you see."
- Thoreau
Skowinski is offline   Reply With Quote
Old 01-11-2013, 12:44 PM   #4755
IDRIDR
IDRIDR's Avatar
Oddometer: 670
This particular model slides smoothly from open to closed and the little nut allows adjustment of the friction. There's no "detente" feeling at open or closed. It will stay in any partial-open position.
Stead Engineering has one too. I know nothing about how it operates. http://www.steadengineering.com/prod...2&categoryId=1
Ignorance duly pardoned - no worries
Times are GMT -7.   It's 03:33 AM.
