Old 01-16-2013, 02:59 PM   #4801
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Changing fork seals to get my project 1993 KLR ready for sale, and the leaky one ain't budging with 120 psi in it. Gonna wait it out, then find something with a 24mm or 15/16" end to fully disassemble. Saw one guy made a universal holder out of a 1x1 piece of wood, sharpened like a tent stake to wedge onto the damper rod top. So there's that option
The non-leaky one popped fine of course .
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-16-2013, 03:43 PM   #4802
Hatley Rocket
Hatley Rocket's Avatar
Oddometer: 349
When I did the forks on my '01 concours, I believe the trick was to get some 5/8" threaded rod, like 24" or so long, with double nuts jammed against each other on each end. The 5/8" nut will give you your 15/16" end, as long as you get a standard nut, don't get X-tra heavy nuts. Use a 15/16" wrench on one end to hold the rod still, and the other jammed nuts fit into your damper rod. I hope it helps.
T
Hatley Rocket is offline   Reply With Quote
Old 01-16-2013, 04:37 PM   #4803
newcastleadam
Artful Tagger
Oddometer: 3,455
Was able to pick the dust seal out, then nicked the oil seal enough to allow the air pressure to pop it.
Adam
Old 01-16-2013, 07:25 PM   #4804
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,174
Originally Posted by GAS GUY View Post
What did your oil look like when you changed it ??
I just took my shock apart with 10,000 miles on it and it was black.
The damping quality is going to suffer with broken down oil.
Yes, mine was black like that.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is online now   Reply With Quote
Old 01-16-2013, 07:27 PM   #4805
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,174
Next time, keep it pressured up and warm the fork lower with a gentle torch. It'll pop.
Wrap a rag around the seal so you don't make a mess.
Worked for me.
-DustyRags
Old 01-17-2013, 06:46 AM   #4806
ADW
'tard bike restos
ADW's Avatar
Oddometer: 577
Worked for me.
Agreed, was gonna suggest that as well. I use a heat gun. Heat on the area of the fork where the seal is located really helps loosen up the "grip" that the seal rubber has on the ID of the fork tube. Works every time.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is online now   Reply With Quote
Old 01-17-2013, 06:54 AM   #4807
newcastleadam
Artful Tagger
Oddometer: 3,455
Good tip. I did wrap the seal in a rag, mama didn't raise no fool
Adam
Old 01-17-2013, 07:20 AM   #4808
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
The aluminum inside the shock is not hardened or coated like a high end shock so it breaks down and contaminates the oil.The oil in my shock was like a frothy black oil with some trace of aluminum residue.Also,there is not alot of oil in the shock,so it doesnt take much for it to break down.
Its like if you take some mothers aluminum polish and rub it on a piece of aluminum that is raw your white rag will be black,but if you do the same thing on a coated or treated piece your rag will be clean.
My shock has a modified 2 stage valve stack and proper spring also so the fact that it is working more efficiently may also contribute to the oil breakdown.
Got it - makes sense . . . . . .thanks!
Ilearned something today -- must be time for a nap.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-17-2013, 08:36 AM   #4809
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,557
Race Tech Shock Shaft Assembly
Have any of you done the Race Tech Shock Shaft Assembly? I'd like to hear your thoughts.
http://www.racetech.com/page/title/S...t%20Assemblies
IDRIDR is offline   Reply With Quote
Old 01-17-2013, 09:13 AM   #4810
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,656
current project
ST1300 - IRON BUTT # 23,716
GAS GUY is online now   Reply With Quote
Old 01-17-2013, 03:10 PM   #4811
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,760
Road my KLR to work for the first time this year
Almost made it, before I lost all power :(
Looks like troubleshooting time. Thinking main fuse, maybe short in the wiring. Bike has been pretty troublefree for the 12,000 miles. Wish me luck!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 01-17-2013, 03:19 PM   #4812
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,656
Good luck, I'm sure it will be something simple.
Be sure to let us know what you find.
Old 01-17-2013, 04:02 PM   #4813
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,174
Any reason this shouldn't be mounted 1) horizontally or 2) lower than the shock body?
Just curious, because I don't technically know how it works. Extra gas volume, or does it have oil and seals inside?
-DustyRags
Old 01-17-2013, 04:23 PM   #4814
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,656
It can be mounted in any position.
It does have a floating piston in it separating the nitrogen from the oil.
Now, the shock will get completely filled with oil along with the hose and approximately 1/3rd of the reservoir.
The other 2/3 rds of the reservoir gets the nitrogen charge.
This will probably double my oil capacity and add compression adjustment.
Old 01-17-2013, 05:45 PM   #4815
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,488
The 2008 and newer KLRs had an issue with the wiring harness rubbing in certain spots.
Did you have the recall done for the armoring?
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
