Old 01-25-2013, 06:33 PM   #4891
ParaMud
ParaMud's Avatar
Oddometer: 630
What tire tubes do you guys use and what size front and rear?
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 01-25-2013, 07:10 PM   #4892
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,423
Originally Posted by ANutt View Post
Nice setup. Is that an aftermarket tank, or just my bad eyes?
What did you have to do to mount the different cases to the racks? I've seen those on Ebay, but haven't seen anyone use them yet.
Great looking KLR!
Thanks. Stock tank minus graphics. The Dirt Racks are versatile. They include .T handle bolts that go into threaded holes in the racks. Since the gray bags are designed for KTM 950/990 ADV's, just had to drill a couple holes and get some aluminum spacers to make them fit , not too difficult. The plastic green ammo boxes just needed two holes popped in each then mounted right up.
The KLR seems to be more setup for adventure riding right out of the crate than the V Strom or Tiger XC I have had. I appreciate the simplicity of the bike, the larger gas tank and the big tail rack.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 01-25-2013, 08:19 PM   #4893
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 194
Heavy duty IRC or Kenda are good tubes.
Front tube size is 3.00-21. or 90.90-21 OEM
Rear tube size 130.80-17 OEM or 4.50/4.75/5.10-17
DesertDuster is offline   Reply With Quote
Old 01-26-2013, 08:44 AM   #4894
kdzidoc
Oddometer: 27
Originally Posted by PWRCRZR View Post
have a few of these and follow the instructions...enjoy "bonding" with your bike
Will do that for sure. Maybe even document it for future "don't know how to do this"ers.
kdzidoc is offline   Reply With Quote
Old 01-26-2013, 01:42 PM   #4895
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,683
Got around to checking my shock linkage (lever if you will) bearings today. The set the shock mounts to and the set the links mount to were rusted solid. It was cheaper to order an entire linkage rebuild kit through pivot works than it was to just get the two out of three sets from a Kawi parts house. The pivot works set includes all 5 bearings, 3 bushings and 6 dust seals needed to do the whole lever. List was $89 my local supplier is hooking me up with a much better deal though
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 01-26-2013, 02:15 PM   #4896
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,630
Did you pull the swingarm and long swingarm bolt off the bike ? Those almost always need attention and can be a bear to get out if it has never been serviced.
Edited-see below.
ST1300 - IRON BUTT # 23,716
GAS GUY screwed with this post 01-26-2013 at 02:38 PM
GAS GUY is online now   Reply With Quote
Old 01-26-2013, 02:37 PM   #4897
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,630
I'm sorry, not the swingarm bolt, but the big one under the frame caps that goes through the suspension rocker arm.
Old 01-27-2013, 04:43 AM   #4898
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,683
Yup pulled both, the suspension rocker arm as you call it is what I call the pivot lever. It was a bit of a bear to remove but everything is apart...
That is from when I first took it all apart...
Old 01-27-2013, 08:54 AM   #4899
kdzidoc
Oddometer: 27
Got the bars on with minimal trouble
But, they didn't send step by step instructions, which sucks. Fortunately, I found a video on youtube that showed step by step.
Good bars, bad instructions. It wasn't hard, but better instructions would go a long way for customer satisfaction.
Old 01-27-2013, 09:07 AM   #4900
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,683
Glad to here you got them on....
for me learning is what it is all about.
I am much more comfortable working with wood so most any time I am wrenching on my bikes I am scratching my head and fumbling along..but hey that's what makes it fun for me..
Old 01-27-2013, 11:33 PM   #4901
macdoc
Canuck in Cairns
macdoc's Avatar
Location: Jan- Apr Cairns Qld - May- Dec Southern Ontario
Oddometer: 272
Left my 2004 KLR650 with friends who were supposed to run it....that did not happen and temps run regularly to 30- 35 C in a tin building so think hot all the time ( tropical Australia ) 9 month storage - excellent dry building where they keep all their active farm gear.
so dead battery with water missing in a couple of cells - dry gas tank ( not left that way ).
Got it running with a 4x4 battery so I could drive it home with the old battery in place ( filled with water but did not charge ).
Fortunately despite no prep for a 9 month out of service - fresh gas and some juice and it fired up and ran smoothly on the 50 km ride home.
so
a) what battery given the circumstances?
either I go cheap and a battery tender this year or a GEL
if cheap - what's decent?
if GEL - what's good?
b) assuming the same conditions of storage next year. What steps to store it including gas/carburator - stabilant? or drain the tank since it seems to want to cook out.
c) is there anything I should run through now it to make sure the carb is is fine ( ran perfectly on the way home - brakes were fine, shocks smoooth - just need to lub the chain )>
TIA
Ontario Canada rider staying in Cairns Australian for 3 months each year Jan to April.
macdoc is offline   Reply With Quote
Old 01-28-2013, 06:47 AM   #4902
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
I like the AGM batteries, no mess no fuss. Put it or any other battery on a tender for storage, makes your life a bit easier after you chase the nesting koalas off
Drain the system- tank, carb, everything. May want to run some Sta-Bil or other stabilizing agent with the last fuel in the system to deal with the vestiges that don't get used. Another option may be to either pull the carb or turn it so you can get the bowl off and use carb cleaner on the jets. I'd lean heavily towards this myself.
If the choke works and it's not stumbling, sounds fine.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-28-2013, 07:33 AM   #4903
Kawidad
Kawidad's Avatar
Oddometer: 5,061
so
TIA
I too like the AGM batteries, however, since you are storing the bike for much of the year I'd pull the battery and store it separately in a handy refrigerator.
I also agree to draing the fuel system completely before storing in those conditions. Nothing will stop the fuel from evaporating, so just drain it.
Since the bike runs well, just run it. Fresh gas does have some cleaning properties to it.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-28-2013, 07:51 AM   #4904
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,547
RE: Storage. If rodents are a potential problem, consider closing some holes. Plug the exhaust pipe and air intake; coarse steel wool should do the job.
IDRIDR is online now   Reply With Quote
Old 01-28-2013, 10:47 AM   #4905
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,487
Why are you storing the battery in a refrigerator? That will surely kill it.
http://www.snopes.com/oldwives/battery.asp
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Times are GMT -7.   It's 01:25 PM.
