Old 02-09-2013, 06:41 PM   #5041
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,325
I see a taper. I found a pic of the JD needle. Look at it, no taper and then it just stops. Bizarre.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 02-09-2013, 06:44 PM   #5042
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
No taper per se, just for the seat. KLX has a taper.
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 02-10-2013, 04:05 AM   #5043
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,911
Originally Posted by Aprilia View Post
If you are not changing the needle then yes...completely stock except for .22 cent mod. Only "kits" I recommend are the KLX and JD....not the Dynojet (DJ) kits. While the DJ needle is good their modifications (drilling slide to 1/8") and jets are all wrong. I've taken many DJ kits that were installed and simply replaced the DJ jets with OEM. The JD kit, as usual, is a great kit and the KLX is OEM and works great too.
+1. I tried jets and needles and the only difference was it used more gas. Re-set the carb back to stock (except the 22 cent mod) and am happy with the result - that was 35k miles ago.
Tsotsie is offline   Reply With Quote
Old 02-10-2013, 07:19 AM   #5044
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,266
I missed this reply somehow. Thanks, I ordered a 148 and 150 main, and a 40 pilot. Thanks!
sandalscout is offline   Reply With Quote
Old 02-10-2013, 07:25 AM   #5045
sandalscout
blah blah blah
Oddometer: 2,266
Thanks, that's what I'm doing. Stock needle, stock jets. I'll drill the slide and shim the needle with a #4 washer. I will probably modify the stock exhaust at some point, but for now I just de-tweeted it.
Old 02-10-2013, 10:28 AM   #5046
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
1/2 years of '05 KLR evolution.....
Just for kicks (and boredom) I made a list of all the improvements and mods I have done on my 05. When I made up the list I was surprised it was so long!
688 bore kit
ported head
1mm over SS valves
CV40 pumper carb
Lectron 44mm Power Jet carb
KLX needle kit
drilled slide
Big Gun Exhaust
Full Flow SS head pipe
Uni filter
Dual stage Uni sock
EM torsion Doohickey
Thermo-bob
14T countersprocket
Lo profile magnetic oil drain
SS brake lines
Ricor IAS rear shock
Ricor intiminators
Progressive springs
SS oil filter
Motion Pro vortex throttle
Subframe drill through bolt upgrade
SW Motech skid plate
IMS long shifter
SW Motech convertible foot pegs
Antigravity LiFe battery
IMS tank
KLX fairing
Vapor Stealth dash
Seat concepts saddle
Pro Taper bars
KFX rear fender
Acerbis front fender
Acerbis Pro Rally hand guards
LED brake/tail light
LED turn signals
Cortech tail bag
Shock sock
Whew! And only a few more things to do !!!
Old 02-10-2013, 10:34 AM   #5047
Tsotsie
Oddometer: 1,911
I even filled the drilled slide too in returning to stock. I recall that I did shim the needle.
Old 02-10-2013, 11:11 AM   #5048
Hessian42
Hessian42's Avatar
Oddometer: 170
just wanted to share. I got 8,500 miles out of this rear Kenda 270 on my 99 and could have probably squeezed out 9k. 75/25 pavement/dirt majority of with a 100lbs load and 210lbs rider fully geared. great tire! would def buy another set. now trying out a set of Shinko 244's
It's just a ride...
http://hessianforpatagonia.blogspot.com/
Hessian42 is offline   Reply With Quote
Old 02-10-2013, 11:23 AM   #5049
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Those Kendas look nice and good mileage! I think after these 606s are toast I will give them a try... Thanks!
Old 02-10-2013, 01:00 PM   #5050
Hessian42
Hessian42's Avatar
Oddometer: 170
they handle very well on /off road!
this is the cheapest place i've found them and the 244's from.
http://www.americanmototire.com/cata...th=200_239_240
no affiliation
just passing on the stoke
It's just a ride...
Old 02-10-2013, 01:02 PM   #5051
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,804
Thumb +1 on the Kenda's
Just about all I run on my '09 now Love 'em.
Shinko 244's Never again, They were on the bike for 850 miles and started throwing the center lugs off. Never again with the Shinko's. I was promised a refund after removing the tire and showing proof that it was destroyed. It never happened. I'll never purchase another Shinko tire.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 02-10-2013, 01:21 PM   #5052
rattis
rattis's Avatar
Oddometer: 1,229
newbie
Hi guys and gals
If I buy a stock KLR 2008 onwards and want to go to TDF what do I HAVE to do?
There seems to be so may improvements around that I don't know what from not.
What about jetting at high altitude in the Andes?
What what what what
HELP
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 02-10-2013, 01:38 PM   #5053
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,325
I'm the exact opposite. Kenda 270's are way too squirrly for me. I have 244's on 2 of my bikes and have at least 1 Shinko on all my other bikes. I have no complaints with them at all.
Old 02-10-2013, 02:08 PM   #5054
bete
misguided adventurer
Oddometer: 561
Kendas are squirrely as hell at first but seem to get better with some miles on them. bete.
bete is online now   Reply With Quote
Old 02-10-2013, 03:17 PM   #5055
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,325
270 on the rear is OK, but I won't go back after a 244. Tougher tire and cheaper. 270 on the front is scary.
Times are GMT -7.   It's 02:30 AM.
